Everything posted by All_talk
decking the block
In general, 0.030 is the standard for deck clearance, so depending on compressed head gasket thickness some piston hight above the block may be fine, I know the EJ22T has some. Be sure to check for valve clearance. Gary
That ticking sound...
Do a search on "tick of death" or "TOD". Truth is Subies will run forever with the HLA tick... its more like the Tick-O-Life. Gary
Strange- idle drops when oil cap is removed
+2 This should be true of any engine with a closed PCV system, if you open the cap and the idle doesn't change that means the air was already getting in somewhere else or the rings are so bad they are alowing a lot of air by at idle... not good. Gary
Question about de-yellowing headlights (in the process now)
All_talk replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't use the clearcoat, sure it could provide some UV protection but it takes years for them to yellow without it (as they came stock) and you can just sand them again. And it will only make them transmit less light. Mine were pretty bad, I progressively wet sanded from 400 to 2000 and hit them with the buffer and polishing compound... been clear for months. And a truly clear lens does wonders for the beem pattern. Finished buffing on one of my '92 SS lenses Beem pattern on my '91 SS with the left clear and the right still "yellowed" Gary
5spd d/r's are 3.90....right?
Yep, like the Doc says. Turbo 3.70, N/A 3.90 Gary
Rear engine EA82 Drive in VW?
Hey Rollie Most direct way is to use the Kennedy plate Craig mentioned, I'd mate it up to a later VW Bus trans or a Porsche box if you want it to last under spirited driving, these can be built up very strong if you need it. To use the VW reduction boxes would require and lot of custom fab/machine work and if not engineered right might have the same harsh reverse torque reaction the stock ones do. But it could be done. Gary
Brighter reverse lights?
All_talk replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn my old '65 Pontiac, I modified the housings to take the clip in 55W halogen fog light bulbs, worked great and never blew a fuse. If I was redoing it today I'd add a power relay to take the high load off the stock circuit. BTW, the '65 Pontiac housings are cast metal not plastic. Gary
Head Gaskets DIDN'T fix my problem!!? Doh!
All_talk replied to who1981's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey Stephen Sounds like you might have a crack in an exhaust port, these normally start between the valves then extend down the port. You have to look under the valve to really see them. I know this can be a problem with the EA82 head but haven’t heard that it’s common in the EJ stuff. In the future, if you’re gonna spend money at the machine shop a pressure test should be on the list. And on you’re original P.S. question, I don’t think there is any difference in the ’90 to ’94 injectors, but in general its best to keep the injectors matched with the ECU/system they came with. Gary
The SVX headlight mod
I find myself thinking... why? But what the he||, its not my car. The EA82 Subes actually have good lights. Its the first gen Legacys that need some help. And BTW, I like the SVX. Gary
VLSD Finally Installed!
Got ya Doc, works for both... Sweet! Gary
Anybody got pics inside the P/T 4wd trans?
Great pics, thanks for takin the time. If I go deeper into this idea it would most likely be part of my hopeful AWD mid-engined VW Beatle project, so a custom transfer case and parts is a given. The only way I'm gonna really figure out what might be done is to tear down a couple of trannies and start measuring out some stuff. Gary
The Legacy SS was made for 4 years, '91-'94 (T-wagon "92-'94), but only the '91 SS came with the rear VLSD standard, I think it may have been an option for the later cars. Gary
Hmmm, I thought it had male stubs, guess I'll have to take a closer look. Gary
press test hg before install?? 2.2l
All_talk replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd thats just rotating static pressure, actually firing pressures are about 1000 times the coolant pressure. Gary
All_talk replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could do it but I dont think it will tell you all that much. Conditions in a cold bench test wont even be close to a running, up to temp engine. Sure it could show you a major issue, but wont prove the integrity of the seal under normal conditions. Gary
The VLSD from the early Legacy is a direct replacement for the EA diff, it has male spined stubs that match the EA82T axels. I have '91 Legacy SS with the VLSD and I find its very smooth and progressive, but I've never found the clutch type LSD in my RX overly harsh. I think that for a street car the VLSD is better. The rear LSD/VLSD will make the car harder to rotate (understeer) up to the point where you have enough power to break the rear end loose, then it will create more oversteer. I find this effect much more pronounced with the LSD than the VLSD. Gary
A layout of the parts would be great, gears, shafts, syncros, shifting fork and such. And just to fill in the blank, I'm thing about adding a P/T transfer case behind a F/T box so you would have three options... Fulltime - open diff Fulltime - locked diff 2WD (diff locked) Maybe even work in the EJ VLSD center diff so the fulltime options would be VLSD/locked. Gary
Looking for pictures inside the EA single/dual range (assuming the 2wd/4wd guts are the same), specifically the the transfer case section. I'm thinking again... Gary
flipping ring gear/ differential??
Can not be flipped... look here for more: http://www.ultimatesubaru.org/forum/showthread.php?t=41009&highlight=flipped+hypoid+spiral Gary
Front diff interchangeability: The true answer
I wouldn't go as far as to say that, but your're gonna need to educate your self a bit. The FSM would be a good palce to start. Or take it to a tranny shop and pay the man. Gary
Convering Clutch from Cable to Hydrolics
Sure could be done, as to parts sources... Lots of EJ Subaurs with hyd clutches, those parts might workout (specialy the pedal box). Also look at the aftermarket stuff the VW/dune buggy guys use. Gary
And.... Gear setup is VERY critical, you cant just swap them. Adjusting the placement and backlash is not an easy task for a novice mechanic. And if not done correctly the gear set will chew its self to bits in very short order! Just be for warned Gary ..... I hate being a buzz kill
Its not as simple as tooth count, the gear geometry is different between the ratios, without getting into the engineering, the ratios come down to pitch diameters, not tooth count. You can not mix and match ring and pinion gears in a hypoid set (or any bevel set for that matter). Gary
And what are our LSD choices from the EJ apps... VLSD? Clutch type? WRX "gear" type? Gary
So just to be completely clear.... I can put a EJ limited slip front diff in my EA box? And... How did we not know this before now? Gary
