Everything posted by ivans imports
Is this where I would ask to find a specialist do make a wiring harness and find a place to send my copmuter to be reprogramed?
have done a few dozen wire harness ez was tougher than a 4 cly one
Please help: Cam seal retainer bolts stripped on '91 Loyale
tap tap taparoo as long as its just slighty biger should do
Car is stalling randomly
ivans imports replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso have seen the conection on the top of feul pump sender to pump burn and make bad conection at under side were pump harness conects whould get worse as it heats up
- British MV (BRAT) meet at JAPFEST 2013
svx diagnostic plugs
thank you North wet helped tons now i feel confedent to diagnose this car
putting in new spark plus outback 2005
ivans imports replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do plugs wires and valve covers as a set no point if oils going to get on your new plugs and wires
1987 GL wont stay running
stop cleanig mafs make no differece just riuns them
Knocking in 98 Outback
ivans imports replied to 808Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPiston slap is running to smooth for bad rod take out #4 #2 pistons knurll them and put them back in sound will be gone. But realy start with pulling the oil fillter and dumping it out into a pan tant you can see if any meatal or berring materail in the oil. Have heard worse piston slap than that always #2/4 that slap have you treid pulling the wire of on that cly and see if noise stops when not firing ?also a oil preshure check helps min 10 psi hot at idle. And oil light should go out in under 1 second cold start
1995 Legacy EJ22 code 0400 egr issues help
suck on the bottom line of egr transducer and see if holds vacume if not replace it
ivans imports replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpower feeds at fuse box or fusabble links loose ground on intake maf senser
Door Jammed! ARGH!
I have done about 60 very commen problem
odb1 and has no green conector just multi conector with small jumper pins is a odd car 96 but no obd2 nowere to plug in scaner. Cant figure out how to get codes
Its buggy time agian
Sorry they are haveing site trubbles we are working on it and i lost matt for a week we are on it
going to buy a new impreza tomorrow head gaskets?
ivans imports replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCvt just like driveing a 90 justy agian
- Erratic idle, loss of power, cutting out, popping nad ticking...New Weber carb...
Door Jammed! ARGH!
ok heres what you do roll the window down all the way take a light and look down to the lach on one side will be the lever to relase door other side is the lock. The outside door handle lever that gos to latch sticks down pull it up or mauanly push over the latch to right i use a 2ft long snapon flat screwdriver for this and patence
Working on a 95 svx having a problem to read engine codes anyone have a printout of code read procedure on svx ? has a airbag light on two if anyone knows how to code check airbags whould help to thanks all
Clocking torsion bars (Gen 2)
i clocked the inside two teeth have had luck with a shim under the addjuster nut
Ea82 transmission with ej20 front casing.
I have biult a cupple i use the 2wd legacy case with ea82 pushbutton guts in it works well should be same as what you want to do but dobut you could use the wrx awd and internals in it
warning have done this caused to mucth load on bar and it broke they dont like to work well clocked like that broke two in a row
EA71 4spd trans teardown - help
And folks we lay this nut down to sleep !
EA82T injectors?
have used toyota and nissan injectors before must have same ohms
- LPG conversion...
I have at least 4 of those trannys all good just sitting around have no cars for them
Gauging Interest: Open-Source/-Hardware Engine Management.
so this will drive a realy borad that drives curcits or the chip controls realys that are part of same board
