10
Everything posted by ivans imports
check the coged idler and the timing belt tentioners can make it knock if berrings are going out
Have been working on this car and a'm having problems figuring out whats wrong as soon as i load it it boost spikes and shuts down the boost will sit at 7 psi and sudenly jump to 10 -14 psi witch turns on the feul cut witch kills it then it will come back on at 7 and jump to 11-14 agian and cut feul is very violent. Everything looks to be conected right and car is stock. I cant seem to figure out how the two stage turbo setup works has 3 wastegates two blowoff valves and two boost controlers a intercooler valve. I a'm unfamiliar with theese cars and is being a diffacult fix any ideas ?
Have a jdm 2.0 a'm working on this week has a lefthand turbo failure is over boosting it should be at 7-8 psi and was jumping to 10 -14 psi the feul cutoff is at 8.5 psi so anytime it overboosts the engine shuts of is a real pain to diagnose. Is it posible that its doing somthing like that do you have a boost gauge ? it could be pulling timing if its boosting to high also have seen many knock sensers that do not ground i file the bottom and the block the cleaner the better.
- 85 replies
The engine takes me 25-45 min to pull and about 1 hour to teardown two hours to prep and surface heads two hours to reassemble and a hour to install and test on a auto one i bill 10 hours and a standard one is 12 hours as it takes more time if servicing the clutch. I put the engine on a stand and disasemble the heads before i take them off the engine. I also knurll #2@#4 pistons if any piston slap thiss take 1 hour to do but makes a big difference
Fuel Injector 1988 GL 10
ivans imports replied to scoobywagon45's topic in Old Gen.: 80's GL/DL/XT/Loyales...
try a heavy ground wire to the bolt on the lower coil braket by ignitor to - on batt -
when they fail they like to stick open and dribble be the cly thats ritch -
That efi is very sensitive anything not 100% is a hudge problem it must all be working exactly right
- 85 replies
Anyone gut their cat?
ivans imports replied to Radio Flyer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I put subaru catts on everything even my lawn tractor no unburnt feul smell and i dont breath hydrocarbons win win and it shoots flames when she backfires ! -
well my freind dont ask me to help put up drywall lol but when you wrench every day theese gloves are a lifesaver the cv grease is the worst and atf trying to rebiuld a 4eat with no gloves gross or a 5 speed gear oil mess i just use cheap blue nitrlie and throw them away often and few boxes of gloves is cheaper in the long run than many bottles of fast orange. And i can take the gloves off and hug my kidds without leaving greasy hand prints
Has to do with whats left over after the combustion process less carbon and deposits in the premium feul octane is erelavent and burn temp is erelavent its the leftover crap in the feul that is important. The feul we get here is realy poor so the perium feul is a step up and not just premium chevron or mohawk 94 premium as it has some ehanol in it witch will burn cleaner it did seem to work still no 420 codes on the test 02 forester and it used to throw a 420 every 2 days and is driven at a idle by a 70 year old man so rpms dont think it sees any
having a problem figuring out how to rev up the drive by wire cars from under the hood when i do headgaskets i like to be able to control the throttle from under the hood. But drive by wire i canot is there any way to control the throttle remotly or a device that can do thiss. Anyone messed around with thiss at all ?
valve addjustments they will be tighter when cold and will open up as it warms up has no code for valves to tight so it gesses whats wrong
- 85 replies
you dont whant it was a problem with theese cars did not hold up put on two electric fans is way safer when that fan gos it likes to take out rad. I almost died from one of theese fans explodeing missed my face by mms i was watching the motor wile reving it and fan split in half and came outa car in a big hurry i donot think they are safe
