14
Everything posted by monstaru
*** uckin *********************............
then just deal with some of the ins and outs.... you are acting lke there is no solution to your quandry.or like you already have one.then why did you ask?ya know.... i say you just go to a strut spacer that you can make yourself, and buy the tires you want, instead if the tires you should get, or have to get.... your right,they are expensive.and it is a big decision.and should be bought proper the first time...cheers, brian
i started out with a HF machine.POS. my lincoln 140 is awesome.110....i use it fcaw. everything i have welded for the past two years has stayed.and i have used it on 1/4 plate ...... i know guys that have used them to build their entire offroad rig that gets way more abuse than any ************in subaru known to man,rally included. so whatever.it depends on your weld...... if you have inclusions,undercuts, etc...(those are types of weak areas in the weld) then you will not get the full psi out of the weld. now, if it was a perfect bead it would maintain that. just FYi, the innershield .035 wire by lincoln(who invented the process) is good to 70 thousand PSI basically , if you lay down a good weld, ugly or not, it will hold to 70 psi. my brother (a union ironworker)and i were just talking about this last night. there are different ways to prep your piece to insure proper penetration. this is very important when dealing with a smaller machine.or , when you are dealing with slightly thicker material than you are accustomed to. i would not use my HF welder for anything anymore,cept maybe a doorstop....cheers, brian
The worry is that tires aren't cheap. It's a risk thing. I can't afford to take any risk whatsoever with my tires. I can't afford to replace them. This is my daily driver. If I killed a tire, I couldn't drive to work. If I can't get to work I can't pay my rent. It's just minimizing risk. the sure fire way to minimize risk , is to stop wheeling.period.
yeah, but if you worry your toaster is going to catch on fire you spend every morning cleaning it instead of enjoying the toast... and if you cannot afford to fix things that go wrong, maybe you should not be modifying your car.its irresponsible, and puts others into a position where they are liable for your mistakes. just my 2 cents.cheers, brian
Sway bar size question
monstaru replied to Vanishing Boy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and there is difference in ea81 and ea82 series front bars..........and , just measure your bar. just clean of a good spot, caliper it , and read.....simple.cheers, brian -
slackers........:grin:i don't believe either one of you are building anything.:grin:cheers, brian
you dirty bastard....that just might work........:lol:cheers, brain
AND ************ING SEARCH>>>>HOW MANY ************ING SNORKEL THREADS ARE THERE? i found about 25......alot with pics.about 3 from you.......including this one.
you guys will know as soon as we know.....:)cheers, brian
yeah, lawrence is a rad guy to work with.i am glad he had the time.believe it or not he is super busy...... when we goin ?:)cheers, brain
ALRIGHT, its on boys and girls!!!! this will be where scot and i show off our rigs! so make it a point to be there.i will get some maps and such printed up, so make sure you are prepared for fun wheelin! we will be adding to this thread , so KEEP CHECKING BACK......we will be giving gear recomendations soon! i would like this post to be for people that are going,or are able to make it for reals.thanks, and vote for me.cheers, brain gear sleeping bag boots extra socks your personal effects small shovel,trowel hat water bottle etc... CAR these are particularly important. axles, bring all you have.and if you only have one , go tot the junkyard and get another. ************ EMPI sells them for mad cheap these days. AXLE stubs! any extra hoses belts rags oil gear oil coolant(speaking of which, put an overflow on your car!) more to comes.........
thats crap.......how are you even going to fit in the model?cheers, brian
official build thread.........this is monstaru2
monstaru replied to monstaru's topic in Members Rides
whenever we decide to meet for our thAng.:grin:hopefully. this is my "BUILD OFF" car............... welp, i know i know, this thread is worthless without pics.. i will get some, but they will be uber random, and puzzlesque.... i figured out what i need to do for the front suspension i want to run. did some fabbin this weekend.worked out well.i should be done with it by the end of the week. need to find some 16" subie rims(5x100 steelies). as soon as i get some rims i can mount the tires , and see what height i am working with.and finish the back up....then i can start the mounting of everything to the car.should be comin along pretty quick here (at least for me) cheers, brian -
its called the FAQ.its at the top of the page........
moarrr pictars!!!!!!!!!!!!!!!!!!!!
yeah, he is my hero.i am actually looking for him sos i can get the schematics from him.i figure a powerglide with a diviorced t-case would be sweet.using it would give you multiple ranges like a twin stick... i found a guy on nasioc that put a powerglide in a rock buggy....sounds like the way to go to me cheers, rbain
actually, the reasr spline output on the 4eat body is exactly the same as the input for the tx10 transfer case. i started researching this last year.from what i found there is not a cheap way to make the adapter for the 4eat to tx10 union. however i do not think it would be diffucult in a proper shop... the down side to all of it, is that nissan transfer case rigs are not popular , so the same prob remains.no aftermarket. there are gear sets for the tx-10 and they are spendy as hell.like 1200 bucks .the positive side to it is that it is a 2.something low....... the next step iun my evolution with the research was to get a nissan pathfinder version(with tx10 attached) and see if the bellhousing could be swapped with the subaru trans..i have a resource for this, just have not had the extra scratch yet... be cause it truly is the mainbody of the trans that is the same between the two. the new path i am on is a powerglide........ if you have any questions on my research, let me know. cheers, brain
"When i first came across this website i thought it was great, but now its just a competition of "who knows what and who doesnt"...... lame" it's ego....i've done this and that....etc.....no one wants to believe there is more than one way to skin a cat.because their way is best!that is why i always tell peole to try things.if it does not work then you at least know why. therre are folks on here(myself included) that have tried a million different things, and spent alot of money trying them. they will mostly tell you there experiences and let it be.therre are others that want to believe that there way is proper because it is tried and true, and there is no reason to spend money on R&D because they already know what youa re trying to figure out.that is all fine and well, except it usually leads to pissing contests... i think your right though, it is getting lame..... i for one know that my ************ doesna stink,and all you mutha ************ers don't know diddly.... sorry for the hijack.cheers, brian
EJ20 Single Turbo - Can a 5spd D/R handle it?
monstaru replied to rxleone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ah ************ it, i'm goin back to ea81's......:lol:at least until i can afford an ej d/r.cheers, brian -
what up bro!i hate running troubles, i have scrapped cars because of it! i think, THINK that hose is a vacuum actuator hose for the vent setup on the hvac.THINK i said:grin:.....pretty sure though.almost every car i have ever had with that hose , i plugged into vacuum.pretty sure , but not a 100 %... hope all is well besides this , cheers, brian
i am speaking of a 5spd behind an ej205, with 227hp stock(just what i read, not what i claim).if the starter spacing is the only problem with using an ej flywheel, i may try to figure that out......because all of this is lames..... it just gets me ya'know.no one knows what a wrx clutch is going to do behind an xt6 pressure plate.but they want to theorize, it won't work, it won't work. well ************ , on paper communism is perfect. cheers, brian -
yeps.....gonna have a microwave too.... :lol:bring your burritos!cheers, brian -
i do not know if the xt6 pressure plate will work or not......but it is one of the things i will try when it comes to putting the trans in..... i just wanted this to be solved already.and when i read everything thus far , i was dissapointed...... another reason to go to an automatic...i guess... i started looking into this about a month ago again.as i finally had all the parts to do it.well, kinda.and was down to fingering out what i needed to do. everyone here is giving good advice.but still none have the experience specifically of what we are speaking about.which sucks...... who's gonna do it first?:lol:regardless , we all need to find a remedy that we like....and can afford......i wanted one of those ej d/r 's from oz.... but that boat did not float..... cheers, brian
