12
Everything posted by ferp420
i think it would be sick stock length maybe add some tracks for the snow
Advance Auto Radiator
ferp420 replied to Saturn5rocket's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oh thats for the super coolant or the ice water port as we like to call it or it can be used as a water heater to heat your coffee or soup or maybe hot water for a shower all bull isht aside it dosent do anything on a manual trans no need to do anything with them -
turbo clutch pedal assy V's non turbo - EA82
ferp420 replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the presure plate dictates the feel of the clutch the cable has nothing to do with it every manufacturers clutches have a different feel to them and some times from clutch to clutch by the same manufacturer my feelings about it is u will get used to it in time as its costly and or time consuming to change them out just becuse you dont like the feel unless its realy stiff and hurting your knee in witch case resurch presure plates and let us know or a longer pedle would do it to but it would have to be alot longer to make a differance are the ea82 pedles longer than the ea81 pedles if so how much longer i dought it would be enuff to make a differance though and to much longer and its gona hit the floor or be uncomfortable on your foot -
i wouldent look for a set of plans just look at as many buggies as you can and find one you like and copy it the best you can
so where are the pics at are you gona buld a tube frame and just use the drive train or are you gone hack the body up in to a buggie
i put the front axle back in it sure was fun but back to normal i would rather have the option of 4wd than run in rwd all the time
intake and throtle body spacers
ferp420 replied to ferp420's topic in Old Gen.: 80's GL/DL/XT/Loyales...
one more spacer and then i can test them out worst case i ruined a good intake manifold and wasted some nice aluminum -
the im spacer -
cut it out with the sawall drilled some holes -
we had almost a week of rain so instead od finnishing something i started a new project intake manifold spacers and throtle body spacer and started geting a port plan for my heads so this is what ive got so far remeber im working with basic tools no cnc or layth or mills just a sawsal a drill/drill press and hand files more than likly im just waisting my time here but on the off i get more usable torque out of it and dont make any flat spots ill be happy nothing else its been intertaining and cheaper than going to the movies first a patern then a chunk of aluminum
Ea81 and Ea82 head porting.
ferp420 replied to Jerry DeMoss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
im woundering about that to i just took the ruff edges off the it because it sticks in to the intake and leaves a big sharp edge i dont know about taking it out completely im in the preping stage for a full reseal of my motor and am practicing my porting of the heads and intake manifold in also fabing up some intake spacers and a throtle body spacer in hopes of geting to the torque sooner -
ive refused 3 axles at the counter at orealys because they where loose right out of the box ive instaled 2 i dident refuse that where loose shreded in a few weeks i just installed another new one that was questionable right out of the box will wait and see on this one point being its hard to find good cheap axles i did get one solid axle from orealy though so unless you enjoy changing them it would be worth the money to buy quality new or rebuilt axles used junk yard axles and cheap chinese junk axles are hit and miss
if you dont have to smog it i say run it only realy need to hone it if your installing new rings those rings are already mated to the cylinder worst that will happen is you will get some blow by and burn oil the rust is mostly above the ringlands the rest will go away real fast once that piston starts moving ive run alot of motors in ruff shape like this one just clean it up and run it
my girl and i have his and hers honda trail 90s they rock and would fit easyly on the back of a suby
i agree those bolt holes are always alittle off best to build the bumper and put it on then mark your holes then remove it and drill them its the only way to make sure its not sitting funny on the car someone in one of these threads sead to leave the mounting pieces as long as posable and add a few more bolt holes to spread the load i like the square tube bummper to ive been thinking about puting it back on but the stinger is alittle small and theres no reciver on it but that wouldent be hard to change i like the function of it more than the one im running now but i think im gona build a hybread of sort between the 2 styles next
theres the basic mesurments and some pics of my square tube bumper
this was a great bumper i might put it back on some day
