idosubaru
344
A complete list would be convoluted and largely ineffective - The EJ22 changes every single year from 1994-1999....delineating all those differences and then deciphering if they're the same, interchangeable, or interchangeable with some effort/swap/custom/change/variance/CEL or not...etc and then EJ18, EJ25, Phase I, Phase II, EGR, non-EGR, MT/AT....too many variables. Sometimes answering one specific question takes forever - with 4 different options and approaches based on direct swap/interchangeable with some extra parts/work/consideration, interchangeable with a CEL, interchangeable if you also change something else, willingness to do a work around to make it viable - multiply that by all the other years, changes, variables and you've got a veritable book on your hands...and then no one would want to read it. They'd just do a search or ask in a thread rather than sift through pages of information for what they want. that would mean writing a long book for free that would rarely get read...i'll let someone else do that!
Phase I and Phase II EJ22 timing belts are different. Timing pulleys are all interchangeable - there's an old style tensioner up until about 1997 then a new style tensinoer starts. They are different but interchangeable if you swap the brackets behidn them that they bolt to. The old style is way more reliable and nice to run in the past, but most are ancient by now. You can do an ebay search on water pumps - and see they all interchange from like 1990-2004 or something.
Good luck being a patient, hope you've got good people and resources there too. Good job getting it done. "wiring overhaul" - i assume that means spark plug wires? In a sense you can wait for those if there's a compelling reason for you - they'll eventually give you a check engine light when they're performance is out of range and they won't leave you stranded.
If the best gaskets you can get are used and the heads are resurfaced the success rates are really high, you can expect to never replace them again. That said, they can fail a second time, the DOHC EJ25's (96-99 legacy and outback and 98 RS and forester) are probably the worst, but it's rare and unlikely to happen to someone around one or just a few head gasket jobs.
yep - same bottle i've used for years. 96's definitely don't have them, Subaru's didn't have them until 2000+. It's odd - I've seen them seize up quick before, within months due to bushings swelling. I'm not sure what the difference is, maybe different lubes mixing exacerbates the issue or something or how much of the old stuff is cleaned off or not....never noticed why there's such a variance.
Thanks kids. Dremel cut it out. First time I think I've ever used the dremel tool, I was impressed. Cut a notch through the nut and banged it out with a chisel. My torch flame is huge because I don't have it set up right and know nothing about torches, i don't trust myself with that big flame under a car with oil, plastic, and rubber and gas lines. I need to learn how to use a torch and just get that thing set up right. Vice grips won't work, no room to get one up in there and I used a 3 foot pipe to get the other exhaust nuts out - I don't see getting that kind of leverage on vice grips in a tight space. If there's room I'd grab the monkey wrench/plumbers wrench, they grab so hard they trash the metal they bite into.
Nut splitters don't work on a tribeca EZ30 exhaust stud nut. Goes on off center, not enough clearance between the nut and exhaust, and then just walks itself right off as it's tigthened. Welding a nut on top got one off, but not the other. Tried welding it until all was cherry red, still no dice. It's all mangled now - welded on multiple times, cut with an angle grinder...but not enough room to completely get a grinder up there.
wrecks are the perfect donors - you know the car/engine was in running condition at least before the thing that sent it to the yard. when i'm looking for an engine I want a wrecked car. of course you don't want a front impact that cracks the timing gear or upper oil pan of H6's, oil filter bung, etc...other than that obvious stuff i've never seen damage. the EJ block - the mechanicals are the easy part and you'll get really good at it because you'll probably have to do it more than once - what are you doing for fuel control if you did build a turbo? FI on an EJ25 sounds like a headgasket cheering squad.
I'm sure you know this, but your 96 doesn't have the rubber bushings on the pins so those won't lock up. And if you have them on another car - just throw them away, they're pointless, I consider that a routine part of 2000+ brake jobs. LOL But even the 2000+ rubber bushing issue aside - the Sil Glyde has been much better for me. For a few years I was confused finding stuck pins (no rubber bushings) or pins lacking grease that I knew I had greased within a couple years or even a year. At first I figured I made mistakes...but after awhile I was fairly sure it wasn't me. It's not like it was every time, but a few instances. I got in the habit of checking the slide pins every time I had tires off. Sil Glyde - I go back in and it's fresh like I just greased it and hopefully I can wean myself of checking the dumb things every time I swap snow tires. I'm not sure what the difference is or where the permatex stuff goes - and it's not like it always did it - but I'm glad to have more consistency.
The permatex green standard stuff is low grade. It doesn't last as long and can swell the newer generation 2000+ bushing pins. I've gone back in for other jobs before and pulled recently greased pins to check them before and the permatex stuff has been degraded much quicker than factory stuff. I don't use it any more. Sil Glyde is excellent. Notably lasts longer: http://shop.advanceautoparts.com/p/american-grease-stick-co.-sil-glyde-silicone-brake-lubricant-tube-4-oz-bk-4/12024852-p?cm_mmc=PLA-_-Google-_-GPLA-_-12024852&ci_src=17588969&ci_sku=12024852&ci_gpa=pla&ci_kw=&iv_=__iv_p_1_a_214327102_g_12425515822_w_kwd-73681271422_h_9009441_ii__d_c_v__n_g_x_pla_y_6201684_f_online_o_12024852_z_US_i_en_j_73681271422_s__vi__&gclid=CKXxoPi9nMgCFcERHwodwzMH9A#utm_source=pla&utm_medium=google&utm_campaign=gpla&utm_content=12024852 I'm sure there's others, I'm not a brand fanboy by any stretch - that stuff works great and is readily available, there's no need for me to look into anything else. Just get a quality silicone based lubricant and I presume you should be good to go. This isn't rocket science, you just need an appropriate grease that doesn't swell seals and lasts.
Phase II EJ22 are only found in: 1999-2001 Impreza 1999 Legacy If it's not those - you don't need to ask. "Will a 1998..."....No. You also need a single port exhaust manifold for those as well. JDM suppliers have 2.0 stuff too that can work. Yes any 00-05 block will work. For that matter nearly any EJ block from 1990-2009 I think can work if you make appropriate decisions. I've used 1996-1999 DOHC blocks in your car but the pistons stick out and need to use thick headgaskets to compensate for valve interference. www.car-part.com
i mean properly diagnosing that it's low first would be ideal.
don't let A/C scare you, it's easy. it probably just has a leak. replace any orings on the compressor (they routinely dry out, get brittle and leak i presume due to engine heat/vibrations), schrader valves, and any other easy to access orings. then charge it. convert it to the new stuff. no need to vacuum the system or anything. easy peasy.
not additives but thoughts..... change the oil frequently. HLA's don't like getting dirty. on older generation subarus the oil pump is often related to HLA noise - replacing the oil pump, even though it has no known issues - solves the problem most of the time. with that in mind, i wonder if the loose backing plate screws (on I think ever EJ oil pump I've ever seen) would contribute to it.
what year ej22 for retro-mod?
idosubaru replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
depends what you mean by "preferred" - they're all basically the same with minor differences. 1990-1994 are OBDI 1995-1998 are OBDII 1996 and earlier are non-interference 1999+ are Phase II's, I'd avoid those. EGR doesn't matter, you can just remove the EGR and block it off. -
Dude, you never described the symptoms at all - just that people are talking about your car. I wouldn't base anything on some passerby's commentary on your car, they probably don't know anything about that engine. Describe the noise itself - precisely the sound and how it varies/happens. Is it present 100% of the time? Does it ever change? Does it go away as the engine warms up? It's probably piston slap which is benign and you can ignore it the rest of your life. Or heat shields Or if it is valve train related - have the valves adjusted properly. In general Subaru valves get tigther as they age though so they don't typically get louder in that regard...
Baja build nearing completion with lift, tires and wheels done!
idosubaru replied to subarubrat's topic in Members Rides
nice work, again!
