Can the VA diff and T-style diff interchange?
idosubaru replied to mell0094's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've never heard of VA and T type diffs? i've heard of open, LSD, VLSD, and inner verses outer stub styles?
DIY Head Resurfacing... or "Post-apocalyptic machine shop techniques!"
Why is this EZ30 head taking forever and many sheet changes? I've done a few heads - takes 20 minutes and a few sheet changes. This EZ30 i've changed the sheets 4 or 5 times and still has light markings around center cylinder. Can I speed things up with 100 grit first? If it's taking this long it hardly seems like it would matter? This head was just that far off?
Intermittent rumble fixed, undiagnosable wheel bearing.
idosubaru replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep, i've had them with zero symptoms as well, slightly unnerving guessing and hoping you're right! plenty make it 200,000 miles without ever being replaced as well (i have 220k and 190k on my OB's and haven't had a failed bearing yet on mine), so there's no practical reason to preemptively replace them. wheel bearings always give ample time for diagnosis and planning a repair. if you replaced every part that has failed by 75,000 miles you'd have a lot of parts to replace. but i can understand feeling good about a car too based on a past experience.
intermittent misfire
idosubaru replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes indeed it was. happens more often on newer stuff that actually have spark plug tube seals. is power steering fluid leaking down into the top/front of the engine? that seems most likely, i'd check there.
2005 Outback No Rear wheel drive when fuse is in?
idosubaru replied to Don P's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"no rear wheel drive when fuse is in" - that's how it's supposed to work. remove the fuse 1. is the AT light flashing 16 times at start up? 2. does the AT light work - does it light up with ignition on but engine not started? 3. car drives perfectly fine other than being in FWD? 4. is the rear driveshaft in place? did the wheel speed ABS sensor code go away after replacing the wheel sensor? what's the history of the vehicle? has the engine/trans ever been out? how many years/miles have you owned it?
appears it's not the wheel bearing
idosubaru replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbased on the front differential being an open differential, it is normal for one wheel to spin and not the other. maybe someone more versed in those can comment but i don't think how the tires spin is necessarily definitive. the collapsed hoses i've seen (in american vehicles) - i jacked the car up - pressed brakes and the brakes locked...let off brakes...and the offending wheel would still be locked up. i forget how we'd disengage the brakes...maybe bleeder screw like you said. repeat and it'd do the same thing. replaced hose and all good.
Six Cylinder To Be History
idosubaru replied to 9098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's very simple numbers: turbo has seals and bearings that can fail which a non-turbo doesn't have. turbo has coolant lines with gaskets and/or hoses that can leak and a non turbo doesn't have turbo has oil supply lines that can leak there are solenoids, waste gates, controllers for turbo's that can fail add to that higher pressures, faaar more heat management and turbo's also become much less forgiving than non turbo engines, inherently. a turbo is identical to a non turbo engine except it has an entire system of additional components to it. to suggest additional components don't add more risk, maintenance, or possible failure modes shows how little someone knows technically/systems/mechanically speaking.
01 6 cylinder dependable?
idosubaru replied to thechadnichols's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXexcellent engines - make sure it doesn't have headgasket issues - these things are a beast when the headgaskets fail in them. it is "thought" that they have fewer headgasket issues but enough people have had HG issues in the H6 that you want to be careful for sure. it's twice as expensive to repair as the 4 cylinder headgasket to repair due to the significant chain cover labor. check for external seepage at HG seem under engine and look for bubbles in overflow tank while driving, after spirited driving/uphill acceleration, while hot, or immediately after shutting off. any small bubbles in the overflow tank and you might want to avoid it.
Can you use 14 inch wheels to replace set of 17 inch wheels?
idosubaru replied to roadsubiedog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi don't think they will - 03 is around the time Subaru went to the larger of the two earlier rotors...there was like a 10.7" and 11.3" or something like that.... but 15" will clear some dual pot front calipers - in those cases it depends on the wheels - some 15" will clear and some won't - i think 15" steel Subaru wheels will not....jamal's brake caliper thread has a fairly extensive listing of brakes and what wheels clear them.
2wd to 4wd conversion?
you want to put a 2WD automatic 3AT transmission into a 4WD automatic or 4WD manual or either one? that shouldn't be a problem at all. i've installed 2WD 4EAT's into a 4WD 4EAT and it all plugged right up and ran without even swapping the computer. you don't have a computer to deal with in the 3AT so sounds simple. swap away!?....I75eye just confirmed it as i typed...
Just bought a 97 obw what should I be looking out for?
idosubaru replied to MrLinfoot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh ha - that's an Impreza. Typically if you say "Outback", that would refer to the legacy based model. That changes quite a bit - you just went from having the worst engine subaru ever made to the best! They don't have headgasket issues unless they've been previously overheated, neglected, or real bad luck. At some point you should replace all the timing belt components - tensioner and pulleys. One or all of them are always in poor condition by that age. Gates kits on amazon are very inexpensive for all those items in one kit. The 1997 2.2 liter engine (and all 1997+ Subaru engines) is an interference engine. If any of those pulleys fail, which happens, the belt will break and you'll have bent valves.
oil pan replacement
idosubaru replied to grimaceNMike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno good pans in seattle? weird. post in the parts wanted forum/section. www.car-part.com
rodent stank removal heater core.
ozone generator. run it overnight in the vehicle. run it for an hour or so in the vehicle with the HVAC on and all matts removed. do not get in the vehicle when the ozone generator has been running in it. tool equipment rental places have them. can even be rented on line - they ship and then you ship it back. hotels and fire departments typically have them.
07 forester 4EAT> 5mt swap
idosubaru replied to hankosolder2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheaper and quicker to repair, sell, then buy the 5MT you want. Create a 4EAT simulator and then install the MT?! If someone were bent on this - start comparing FSM wiring diagrams and delineate wiring differences?
idosubaru replied to MrLinfoot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsqueal may not be starter and the throttle control module almost certainly has nothing to do with your idling. diagnose first then repair or you'll be throwing parts at it. keep your eye on the temp gauge - those engines are the worst Subaru ever made due to an ominous headgasket issue. many of them that hit the used car market or get traded in do so because of headgasket issues. your particular engine only has one symptom - random overheating events. Idle issue: any check engine lights? have the plugs wires ever been changed? how many miles on the vehicle? clean idle control valve (or install a used one) replace plugs with stock NGK plugs and wires with Subaru or NGK or other quality wires. not sure what you mean by "clutch pedal squeaks" - is it squeaking any time you move the pedal or there's a squeaking that goes away when pedal is in or out?
idosubaru replied to lewisd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 wheel bearing. was it properly greased? was it properly installed? if so - if the hub is hosed it'll ruin the next wheel bearing. if everything else checks out and you're replacing the bearing again - replace the hub as well. it's unlikely a brake hose. Subaru hoses are robust and rarely fail like that.
tic of death 1993 ea82
replace the pump before cam tower orings. i've never had to replace the cam tower orings to fix TOD.
EJ22 swap- knocks, ticks, leaks. Oil pump or bad engine?
idosubaru replied to pginter96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually it's the opposite - a very easy subject - because it doesn't matter. follow the owners manual. Since it doesn't matter - the allure of being right means people can be partial, tell you their stance, and what has worked for them...and they're always right! so attractive, so addictive..i might make a website called "Garyistheoilguy" for people to academically pontificate themselves into inactive boredom...it gets confusing if you over analyze it. That's why there's so many opinions, discussions, and different approaches...it doesn't matter. My secret to having no blown engine in the dozens of Subaru's I've owned...got a note pad ready, this is cutting edge oil protection...buy whatever is cheap/on sale. *** Turbo engines, towing, racing (and maybe some newer Subarus) - severe use conditions - those are different discussions.
I/M codes on 99 Legacy E25DOHC to EJ22 SOHC
idosubaru replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 drive it some more. 1996 Subaru's had IM monitors that would never reset and are exempt from emissions, or that part of it anyway, because of that issue. Emissions give you a waiver on that - it's a known/documented error. It's not uncommon for ECU's to also be swapped when engines are swapped - so if it has a 1996 ECU in there the IM's won't ever be ready. Just swap in any other EJ22 or Ej25 ECU (i've noted zero performance difference swapping them). They're cheap and readily avialable, i can probably ship you one for $20.
'95 Legacy Intermittent Hot Start Problem
idosubaru replied to staninoly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry swapping the crank sensor just to rule it and the cam sensor both out. fuel pump? they don't fail terribly often but hey it is 20 years old now. test for fuel next time it does it. either just pop the fuel hose in engine bay and see if anything comes out or rig up an actual fuel pressure gauge.
'92 2.2 timing belt.. please tell me I didn't waste my time, and a water pump gasket question
idosubaru replied to VolvoMatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe oil seals generally don't leak such that the belt gets wet unless they're just gushing oil out...which is highly unlikely. the only one i've ever seen do that was an aftermarket seal on an older Subaru which were known to not be well-fitted and the seal was a fraction too large. It puked oil out all over the new belt which failed in about 6 months due to oil saturation. And when I say saturation, it was saturated, he must have been dumping oil in it weekly. as much as it's talked about - i've never seen a failed thermostat in a Subaru. it obviously happens but i wouldn't be terribly concerned. that being said - the thermostat is easily replaceable right under the vehicle regardless of the timing belt job.
idosubaru replied to pginter96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not HLA's or piston slap? No way the oil pump was damaged. The timing cover damage/interference is very typical, not a big deal and doesn't suggest something more ominous. Pull the cover and reseal whatever is leaking.
2001 EJ22 into a 2003 Legacy
- 2001 EJ22 into a 2003 Legacy
idosubaru replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou don't understand what is meant by swapping the cam and crank sprocket? what do you mean you don't understand? you're doing an engine swap - surely you can swap one sprocket! swap the drivers side cam sprocket: 1. remove sprocket 2. install other sprocket same for crank sprocket there are two different style trigger marks on the cam and crank sprockets - to verify you have the correct one it's generally advisable to swap them so you keep the crank/cam sprockets TO THE VEHICLE (even if you swap engines). this is true EVEN if you install another EJ25 - they can vary as well. since you don't have the pulleys you'll have to try the EJ22 and see if it works or otherwise try to narrow down which pulleys you need and get them.- 2001 EJ22 into a 2003 Legacy
idosubaru replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXahh...no intake manifold eh? intake manifolds are easily removed in the vehicle - so swap the drivesr side cam sprocket and crank sprocket, drop the engine in, plug it in and see what happens. if it's not working out then remove the intake and install an EJ251 intake manifold - it bolts right up to the Phase II EJ22. - 2001 EJ22 into a 2003 Legacy
