idosubaru
344
New soon-to-be-owner down in Florida!
idosubaru replied to Tegwin's topic in Meet n' Greet. Your USMB Welcome Center
if by "performance" you mean actually fast - a Subaru won't fit the bill, it'll be slow no matter what upgrades you throw at it. if by 'performance" you mean you enjoy tinkering and playing around and adding parts, then tear it up. unless of course you get into turbo Subaru and upgrades - but that is a completely different order of magnitude in terms cost and effort - and the vehicles you're discussing never had turbo engines anyway. the 2.2 liter motor is much more reliable than the 2.5. 2.5's have lots of head gasket issues...which means most cheap ones have already been through that debacle and may have questionable longevity. -
well J, don't get too excited, as much as i wish this was for fun....the captive nut for the transverse link broke it's welds and is free spinning inside...no access and requires cutting to get to it. i gave it a go from the cabin and to no avail. i'm going from the outside now. http://www.ultimatesubaru.org/forum/topic/142509-who-has-done-this-repair-captive-nut-broken-loose-front-transverse-bushing-link/
that's a good call but doesn't work well here. no pull it yourself yards and most places don't want you in their yards. last time i asked, they wouldn't let me power up a 2003 to see how many miles were on the electronic odometer...on a vehicle i ended up buying the transmission from, $900 cash in hand....and that one was in the parking lot where customers parked, not even in the yard yet.
sounds like you got it narrowed down to the igniter. post in the parts wanted forum here or subaruxt.com ryan (rpholz) has one available here: http://www.subaruxt.com/forum/viewtopic.php?f=1&t=13566 distributor is a likely culprit too, i've seen a couple cause no spark conditions in vehicles that sat for along time. again - find a used one. i've got igniters and distributors for XT6's too.
snake all the junk outta there. ozone generators are great. i use them on vehicles that have been smoked in - neutralizes the odors you can't get too - in empty spaces, etc. seal the door up, open up as much as you can, leave the ozone generator running in it 24 hours. i'll even run the vehicle with the vents/HVAC on to circulate air while the generator is on as well.
i'm cutting an access hole/door which i'll then weld back in place so accuracy is nice, probably go with angle grinder. up or down side to a torch for this? probably won't use it for this but have one and you guys know better than i. dremel is off the list, thanks. i would have easily tried it though i was thinking it kind of small.
never replace EJ22 headgaskets unless they are blown. they don't blow unless they've been overheated. yes get one of the gates kits on amazon now for like $130, great deal with new tensioner, pulleys, and belt. the pulleys are generally not in good shape by now. reseal the oil pump, tigthen the backing plate screws on the oil pump, use a SUbaru water pump gasket (the aftermarkets are flimsy cardboard). don't get a much simpler 100,000 miles.
2003 Outback The captive nut for the front transverse link bushing on the passengers side is broken and free-spinning inside the chassis. This nut is inaccessible. It's the rear-most nut. 1. Do you have to drill the floor pan directly above the nut from inside the cabin? (doesn't seem possible with firewall in the way). 2. Once the initial 5 layers of metal are drilled through that your feet sit on - do you keep drilling? I drilled/cut through 5 interconnected metal layers all adjacent to each other, where your feet immediately rest and I only see empty space and additional folds of metal 1 - 3 inches (roughly) down in the empty space. It seems like I'm in a hollow space - an interior side of the chassis (floor pan that i drilled through) filled with additional folds and metal. Do I continue cutting into one of those folds/metal areas too? had a thread but wanted an accurate title since few have repaired or seen this and i thought it was simply a stripped bolt at first. http://www.ultimatesubaru.org/forum/topic/141241-stripped-19mm-front-control-arm-rear-transfer-link-bushing-bolt/?do=findComment&comment=1187964
for those that have done this - you've done this on a Subaru before, what year/models? mine is a 2003 Outback Sedan H6 i've drilled multiple holes and I've cut a huge swath out - like 5 inches or more with a sawzall and i see nothing - zilch just empty cavernous space and metal folds. i can't imagine drilling or going through those folds....not without making a 8"x8" hole to work through but you haven't mentioned that. truthfully it doesn't seem like what i'm doing is possible and this seems like the worst possible way to attack this. it seems from the underside cutting a notch is the only way to do this?
it does seem statistically more likely that it's something invasive that you worked on - which would be valves. But I've always wondered so now is a good time to ask - being horizontal, do Subaru valves pool oil like other vehicles? It seems like they wouldn't. Oil would pool in the bottom of the cylinders behind the rings though...?
i would guess it's easy for one of those seals to not seat properly, i know it's happened to others on the forum. rings would also be a concern - i'd do a leak down test to confirm where the breach is. i haven't seen it myself, so i don't know the validity of such statements, maybe they're just an artifact of old, but folks often say "fresh heads result in more compression and blow by/oil loss from rings".
loyale battery drain chase down.
idosubaru replied to Rust's topic in Old Gen.: 80's GL/DL/XT/Loyales...
***Jump down to item 3 for the best and proper way to figure this out. it literally takes like 3 minutes to diagnose for sure and get an actual value and then in less than 10 minutes you could pull all the fuses and know which fuse the drain is on at least. so in the time it took you to post this you could have it narrowed down significantly. make sure the battery terminals are tight, clean, and don't have too much resistance and alteranator connections are good and clean too. the alternator plug could be corroded, brittle, and nasty. with some hard to find drains it's best to test and narrow it down verses guessing. (if you read between the lines - i've wasted a LOT of time trying to guess at drains before LOL). 1. are there any systems currently not working correct, or not stock? ***non-stock stereo or other installed device or an inoperational OEM part. 2. ghetto test is to simply disconnect what you feel are the offending items - either via fuses/fusible links or disconnect the item if accessible. see if the battery dies over a couple days...that gets old really quick though if it's something you need and have to plug/unplug every time you use the car. 3. the proper test is to disconnect the + battery cable from the battery and simply put a voltmeter set to "milliamps" between the positive battery cable and the positive battery post. be sure to not use anything or allow any lights or anything to turn on while it's connected or you'll blow a fuse in the voltmeter. I. note the amount of draw (and let us know). this will confirm that you actually have too much draw II. start pulling fuses until the draw reduces to a normal range (usually under 50 milliamps) III. once you narrow that down you see what items are all powered by that fuse and disconnect them one by one IV. you can atlernately also just disconnect a suspected offending item and actually watch the draw decrease on the voltmeter. but again guessing gets tiresome. -
1. you used Subaru seals it appears? (not that i know if it matters) 2. are you positive you got the right seals (they didn't change between the non-VVT and VVT changes from 04 - 05?) assuming correct parts and installation my first thought is if the two are connected - bad bearings and valve stem seals. which makes me wonder: a. is it possible for loose enough bearings to cause the pistons to have more play, extend further, and contact the valves? i've seen bent valves that look so close to straight that i've just scrapped them and replaced them in fear of accidentally mixing up known good valves and bent ones. it would be easy to not notice a bent valve. but then if it's not noticeable it doesn't seem like it would be enough to harm the guides/seals any time soon. and i still can't imagine it being enough though, it seems the bearings would get worse quicker than the valves would hog out the valve guides. so it seems unlikely, but so does two issues happening like this. i've never had an issue with Subaru valve stem seals but they're tiny size in tight places does seem like it could lend itself to mis-seating them? if you remove the two lower engine mount nuts and upper pitch stopper and jack the engine up it's easy to pull a head with the engine insitu, so you don't have to yank the motor again.
I'd carry the piston slap/rod bearing discussion to another thread - he's asking specifically about head gaskets here. it sounds like a lengthy discussion would need to happen to clarify some of that because piston slap is benign, lower end bearing failure is not. the former is common, the later is possible. start another thread if necessary, he's not asking it here.
