What EJ engines are non-interference?
idosubaru replied to SubaruWagon87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEJ18 noninterference EJ22 non interference until 1997 EJ25 all interference
4EAT from 98 impreza into 95 legacy, will it work?
idosubaru replied to greg donovan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit will work but you're likely to have final drive issues. the legacy is probably a 4.44 (although you don't specific which models - OBW and GT's will have 4.44). the Impreza will be a 4.11. All you need to do though is make sure whatever trans you use, you get a matching rear diff.
Installing SJR lift kit
thanks scott. i'll install a 1" block of i have rubbing axles. so the other guy didn't get the rear bolts for dropping the rear diff? just curious why that is, are they not necessary? being that i know nothing about lifts, it's better to keep that stuff tucked up under there for ground clearance if the axles can handle it right?
Clicking under deceleration only
If your trans isn't the culprit then it's one or both of your axles. If you bought an aftermarket axle, then that would be where i'd start looking.
2" Lift kits for EA82?
Tom, I'm installing essentially the same kit. I have a Legacy GT steering coupler i'm going to try first. I'll let you know how it goes, but it'll be a couple weeks before I get to mine so you might beat me to it. I see slight variances in your kit and mine, anyone know what that is? http://www.ultimatesubaru.org/forum/showthread.php?p=833316#post833316
I'm confused - it seems the description of parts here is different than in another EA82 SJR lift kit thread. In my thread the longest bolts are for dropping the rear diff. In this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=99881&page=3 They are for the front cross member? So my kit came without the front cross member blocks/bolts and the other kit came without the long bolts for dropping the rear diff? Why is that? I don't mind fabricating extra pieces, but want to get right what I've got when I go to do it.
'01 Forester Head Gasket warranty replaced
idosubaru replied to JOEK39's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXright on mike, i do agree with. it gives poor service too. if someone can get paid for more hours than they work, do they think that encourages high quality service and work? quite the opposite, the quicker they are the better. having worked for large companies, in manufacturing - the only real world solution is to control everything yourself, but that cant' happen in large corporations. if you owned a large business you'd understand the non-efficient necessities they put in place. i don't agree with it, maybe there's a better way, but it's one of those "necessary" evils sometimes to survice the complexities of large markets, infrastructures, etc. if anyone can do differently, they would suceed immensely at business. for instance, and this is only one example of many, if it was based on actual hours - then warranty work would cost a company inordinant sums of money - because people would abuse that. "oh the spark plugs were all rusted and it took me 50 hours". you are honest - but all people and employees are not. which brings us back to - "stupid rules come from stupid people". another system you're thinking of likely has all sorts of holes in it (or you'd start a revolution in industry if it didn't) that would get abused by people too - so for a company to survive they have to do something. i agree, but this has happened because people are dishonest and greedy. and that's unfortunate.
idosubaru replied to JOEK39's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin general i agree with the sentiments about dealers. though anytime things are done on a "work order" basis and laborers are charged for hours, there's good and bad jobs. having worked in industries that do this, it's just the nature of trying to tame a huge beast. there's problems with paying "by the hour" too. it's just way more complicated than that from an organizational standpoint. when you're the laborer and get 3 hours for somethign and then run into problems diagnosing, rusted bolts, broken tools, or other parts break and knowing you'll 'get blamed', it's just a dynamic and inefficient problem all around. what happens sometimes is the "experienced" guys know which jobs to take (get paid more hours than it'll take) and the less experienced guys get the crap jobs.
Eff you, EA82!
reliability wise the EA82 is far nicer than the EA82T's. but with really lacking power. to be reliable a 20+ year old EA82 is going to need lots of help - resealed completely and done right. very rare to be worth it.
Help-Bouncing Speedometer???
idosubaru replied to JimmyJam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa friends 97 Impreza Auto EJ22 AWD is doing the same, i'd be interested to see what this is. hopefully it's something simple because the driven gears in the trans aren't going to be replaced by most folks (intensive, costly, or both).
been a Lot of posts for questions recently
some of my personal favorites are "anyone in the tri-state area", "the bay" area, by the interstate.. etc!
Eff you, EA82!
i agree 100% that EA82T's aren't worth getting into and you're headed in the right direction with a swap. but there's a chance your profuse oil leak is really simple. that would buy you time to get ready to scrap the piece of work for an engine swap. valve cover gaskets can dump oil instantly...as well as cam seals, crank seal, and oil pump seals. i had a brand new NAPA crank seal (forget the brand) that didn't seat for crap on an EA82 and ended up leaking profusely. got a Subaru seal and it seated perfectly. local guy had an Xt6 for sale due to massive oil leak. i told him it was one of the oil pump seals (seal or gasket). he replaced one (not both) and it still leaked. i told him to fix it right and he listed it on ebay instead. so i bought it for $500, replaced the $7 seal i told him too, it ran beautifully, pulled his custom headers for my car and sold it for $2,000. sometimes it's worth checking into something before giving up.
legacygt.com domain has expired
idosubaru replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh man, hope you snag it. we got hosed on our xt6 domain. snipers got it and want bank for it. we had to get a new domain and still have folks that can't find us. we got hosed by the company essentially going under though, we "paid" for it, but they never followed through properly.
Help 99 SOHC ej25 to 00 SOHC ej22
that'll be 1999+. definitely not 98 or earlier. and looks like you can swap intake manifolds in this case, i forgot about that. did you see that?
87 GL10 Value?
$1,500 give or take $500. First thing - fix all the "little" and easy stuff - the headliner, wiper, blower fan. Multiple issues just start things off on the foot. When selling a car like this and wanting top dollar, time is your friend. You're not likely to find someone wanting an old school Subaru like this every week....but once or twice a year there's someone out there looking. Extend your for-sale time and that helps a lot with a car like this. It's unlikely to sell here, so get it out on autotrader or advertise it somehow.
changing crank pulley /timing belt- please advise
idosubaru replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey are interchangeable.
'97 heated mirrors into a '96 OBW
i would think your 99 outback has the wiring in place. if it was like a brighton or L then maybe not. but i don't know, i haven't done it, just passing along what i've read in forums.
idosubaru replied to JOEK39's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXawesome, nice hit getting it fixed. that's not quite right. the Subaru extended head gasket warranty campaign is for 100,000 miles and 8 or 10 years, so you sneaked in under both counts, just in time!
'99 Legacy Outback 2.5 jumped timing, still need advice
idosubaru replied to MG McAnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX? that's odd. they are tight, but a mechanic should have done this like 100 times, i have and i'm not a mechanic. basic stuff, the "bump the starter" method works 100% of the time (just don't screw it up!)
Leaky valve covers (oil on exhaust) = fire?!
idosubaru replied to spud's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhighly unlikely to cause any problems. all subaru's do this, the design lends itself to oil dripping on the exhaust, almost doesn't matter where the leak is. 660 miles no big deal.
Help: Engine Swap questions 2.5 EJ DOHC AT to a 2.2 EJ SOHC
idosubaru replied to 4ahickey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi already replied to one of your other threads, but apparently it was deleted.
Transmission seized, how to move?
idosubaru replied to kami333's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStart it in gear, will it let you do that? I've done it on older Subaru's, but never a newer one. Bypass whatever you need to in order to let the starter turn the engine over. Make sure the ebrake and anything else (blocks, etc) are taken care of and use the starter to move the car. You can use the starter to load a car onto a trailer, i've done it. A good winch will probably be your friend to load it. Disconnecting the driveshaft and front two axles is one way to get it to move. They also make car "dollys", and I don't mean tow dolly's. They're like little wheeled "cups" for moving cars. Not sure how that would help you on a dirt road and 100 miles though.
Turbone? Anyone know how rare is black rx #33/50
i'd take any EJ engine over an EA82T. but if you're doing a custom engine swap, wiring, ECU and all, head gaskets are negligible anyway.
my daily driver XT6
AC experts?
im' not an expert at all and what i've learned is that A/C is not hard. replace any bad parts, they're all easy as pie to replace and the ones that aren't very rarely fail. replace any orings you can get to (the two on the compressor for sure) and the two schrader valves. pull a vacuum and charge it. if you can't pull a vacuum, just charge it and it'll work fine. if you're dealing with an internally exploded a/c compressor things get more interesting. but that is rare. there's enough existing A/C threads to probably fix your situation.
