Mouse/Rodent protection ideas welcome -Storage solution
The GF's landlord doesn't do dogs or I suspect I would have a dachshund ... or were it my choice possibly a basset hound. But the rats are definately the most superior in the pocket-pet world. Amazingly intelligent for their size - they can learn virtually anything a dog can - even running obstacle courses and acknowleding their own name. Few people realize that because of their small size, extreemely prolific breeding habits, and docile nature they have been domesticated by the labaoratory and science community so as to be "easy" to work with. When you can breed a new generation every 2 months it's easy to use them for medical research. The only drawback as pets is they have a short life-span of around 2 years - but at least replacements are cheap GD
1/4" is plenty small, and definately chew-proof. They can chew a lot, but not steel. And they won't try anyway unless they have some reason to get inside. Rats are smart - on par with dogs - but unless they have a reason to go through a barrier (or burrow under it) they won't. A junior sized rat would fit through a quarter sized hole, but not a full grown one. Females are around 300 grams, and males can be upwards of 600 to 700 grams. 1/4" is plenty small to preclude entrance to any rat or mouse old enough to be exploring outdoors. She aint gettin through a quarter sized hole : GD
86 Subaru Battery and Alternator Questions
You may have a problem with the switch that tells the ECU to increase the idle speed with the AC on. There's a pin on the ECU that should be grounded by the AC system. Your issue with the fan is probably related as the system is designed to run the AC intemittantly with the controls in the defrost and possibly other positions as well - such that it's hard for the uninitiated to know exactly when the fan is on by itself vs. the fan AND the AC being on. Voltmeter dropping is simply a function of the idle being too low. The rectifier/regulator cannot maintain 12v if the alt isn't spinning at least 700 RPM or better (which translates to about 500 RPM at the crank pulley because of the pulley reduction). The clicking and not starting issue is common - it's the actual ignition switch itself. You can install a relay run by the ignition switch to transfer full battery power to the starter solenoid. That will solve the starting problem and is the prefered method as it allows the ignition switch to be operated normally. You may also want to clean all the wireing harness ground connections. GD
Actually, to do it right you would have to use like window screening (anything much larger and mice could climb through), and it would have to be the metal variety. I suppose the next best thing to a tupperware container for the car would be a wooden frame (cheap 1x2 pine probably, with a plywood bottom) covered with metal window screening (stapled), and then cover the whole thing with a cheap blue tarp from harbor freight, some dryer duct and battery operated 12v computer fans + car battery and soler charger..... Could probably pull it off for pretty cheap actually. I bet less than $100 - cheaper and definately more advanced than a flimsy cotton duck or plastic car cover. GD
One dim headlight
You *have* checked that the bulb has a good low-beam element right? Does it work on high's? GD
old-timey metal widow screen would work - easy to work with and cheap. GD
weber vacuum hookups on 77 ea71
Some you can, and some aren't drilled for it. If there's a brass bolt blocking off the other side then you can swap the inlet and the bolt. GD
The canistor can either be removed, or just fogotten about. Most people don't realize they are supposed to be replaced like every 50,000 miles or something and it probably isn't any good anymore anyway. It's a passive system so it won't cause any problems if just left disconnected. If you don't have an EGR port on the Weber then you just leave it disconnected. The EGR won't open without vacuum supply from the carb so it's effectively disabled if you just don't hook it up. GD
Just run a single vac line to the disty advance - leave the retard on the disty OPEN so it can breathe. You should also have a port on the front of the Weber for the EGR - it may be blocked off with a brass scew. If not then don't worry about it - some older Weber's don't have the port drilled. Plug everything else. The Weber has no facility for bowl vents or purge lines. That's why it's not DOT approved. Don't need any of that stuff anyhow. GD
ea81 turbo heads
I'm not so sure about that - remember the SPFI EA82 is 90 HP and the EA81T is still only 95. The EA82 is rated for higher RPM as well. The SPFI may have only a single injector, but it's BIG. It's hard to say without flowing them exactly what the params are - the EA82T injectors aren't large enough for many folks that want to use FPR's. GD
Loyale Wgn Woes
Either the problem with the Alt is intermittant or the Autozone tards can't use their machine. Only way the brake lamp comes on is from AC voltage. It's diodes. GD
ea81 turbo heads
Why? You would need a custom injection computer (Mega-Squirt, etc) as the EA81T's MPFI is niether set up to run without the turbo, or set to run with the high compression of the N/A block. The heads really don't flow all that much better - the exhaust port is still siamesed. Plus the EA81 MPFI uses the old flapper-door MAF.... which just plain sucks. Your mileage with the stock ECU will suck. SPFI is the way to go - it's the cheapest and quickest way to FI, and it's simple and rugged. With Mega-Squirt you could easily upgrade the TB if you so desired. GD
DON'T use poison! It doesn't work very fast so they will crawl into the car and then die inside the duct work. It's also extreemely inhumane - it's basically a really powerful anti-coagulant. Takes days before they even show signs of illness, and then they bleed to death internally. Really not appropriate for your situation anyway. They make all the commonly availible poisons this way intentionally in case a pet dog or cat should accidentally eat it - there is a common antidote to the stuff (vitamin K actually), and it gives them time to administer it. GD
more 4wd conversion ???'s
More than anything you will have problems with the transmission tunnel. It's not big enough to accomidate the 4 spd - 5 spd is even worse. Lifting it or beating/cutting the tunnel will be required. You will have to change the complete exhaust system, front sway bar, and fuel tank.... as well as the rear end. Front strut's are different too. It's a lot of work, and I probably won't even do another one. Waste of time - the coupe has the same wheelbase as the wagon and virtually no storage space for off-road. GD
EA81 intermittant wiper switches (Brat-specific)
Well - it's more complex than that. The automatics didn't have T-tops after 84 even in GL trim. Also AC could be installed in DL's as it was a dealer option as well as a factory option. D/R of course was only on GL manual's not on GL automatics. But yes - ALL gen 2 (82+) GL Brats have intermittant wipers. All of the ones I've owned and driven had it. GD
Car won't start, no fuel.
Carb pumps only get power when cranking or running. There's a FPCU (fuel pump control unit) under the drivers side of the dash - it controls the relay using the tach signal from the disty. GD
Disty Screw You Too on Roo!
USE THE BLUE. You will never get it back out with the Red. Loc-tite will take care of the problem. If you get the right brand of rotor it should come with a new screw that has a lock washer that will bite into the plastic of the rotor and keep it from turning out. GD
Your best bet is to cover the holes as you are planning. If they can't get in initially they probably won't try - although a determined rodent will make short (maybe a couple minutes) work of foil tape, cardboard, plastic or any other soft material. I and my GF have rats as pets and I can tell you that there is nothing they can't chew or won't eat or nest with given a chance. Only way to stop them would be to poison them, but then you have dead carcasses AND nests inside the duct work. I know of nothing that will scare away rodents other than a bowl of cat food and the biggest, meanest tabby you can locate to stand guard over the car. Get a nice outdoor dog/cat house complete with food, water and big mean farm cat. GD
There's supposed to be a lock washer on the screw. I've never had one come loose but if I did I would use blue lock-tite on it. GD
Effective Carbon Remover
Soak in carb cleaner overnight. GD
EA 81 A/C installation
It's definately going to be easiest to pull the dash. Although it's probably *possible* without doing it, the added effort is worth the end result as you can inspect and clean all the whole vent system and use new foam on all the flapper doors and stuff. GD
US Brat's do have the intermittant wipers - GL's only of course. Did you mean to say that the "Brumby" doesn't have them? Coupe's and Sedan's here also have them and yes, the switches are the same as the Brat since they don't have rear wipers like the wagon and hatch. GD
What brand of CVs are recommended?
GCK - special order at Autozone. GD
One dim headlight
I also seem to recall 4 relays. Perhaps one has already been replaced and was not put back in it's rubber "holster"? Might be dangling, or more likely someone shoved it up into the mess to keep it from dangling. My subarusense tells me a PO has used an aftermarket relay which may have subsequently failed GD
preping EA82 manifold fo EA81 Weber install. Dial up beware!
Lots of folks have done the Weber swap - myself I've done it fully half a dozen times or more now. The first few I ground some on the flange to "match" and the rest I didn't. It doesn't matter either way - the difference is non-existant. Others I talked to when I had the same idea as you agreed. The heads flow so badly, and the cam curve is such that the rest of the manifold matters little. The EA82 manifold flows a bit better than the EA81 but it's not much, and doesn't seem to make any difference in power. The biggest win for the EA81's is changing the cam and porting the heads in conjunction with a slight compression increase. Even then the EA81 stock manifold is more than adequate for 100HP. GD
