Everything posted by nipper
EJ intermittant missfire has me stumped!
nipper replied to MoonDog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is the ol rubber hose method. use a hose as a stethascope and listen to all four injectors. if they all sound the same we need to chase this down some more. Check the grounds, clean them, maybe run a new one from the block to the body. Check the MAF sensor as may also cause a miss. Are you using the same coil pack?
Won't start below freezing
nipper replied to Stephen J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEngine Temp Sensor. It can not tell how cold the engine is so it is flooding the engine. This will not throw a code.
1996 Legacy AT Oil Temp Light Flashing 16 Times
nipper replied to pcd10141's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSlight correction. This is telling you there was an electrical fault in the transmission in the last operation of the car. 98% of the time it is the Duty C solenoid. Alos look up Torque bind and enjoy lots of reading
nipper replied to MoonDog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you ever replace the O2 sensor or check for a clogged cat converter? What parts did you swap over from the other engine. The miss is always on #3? Did you use new OE wires? Are you sure this is an ignition miss and not a fuel injector miss?
howling
nipper replied to jrt2nd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes it sounds like a mismatched diff. It is easy to tell on a lift. Start the on the lift raised only high enough to get the tires off the ground. Mark the other 2 wheels with chaulk in matching spots. Since these are open diffs have 2 people san use 2x4's to stop the ine side from spinning. On the side with the marks the tires should stay in synch. Since Autos transfer a minimum of 10% of power to the rear, they will spin.
Rear wiper spray
nipper replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSwap washers see if it pumps. Just because the motor spins it may have enough omph to do anything.
Rear wiper spray
nipper replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rear has its own pump in front tank. the pump died. you can use a universal pump kit. You may think about replacing the front pump too, as I had them quit 1 month apart.
Wheels locked up and car was stuck in first gear. please help
nipper replied to gravitate's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK im perplexed.
10 MPG Outback
nipper replied to nicolo69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA cracked knock sensor may not throw a code. Physically inspect it. I would prefer to use the thing sticking out of the flor to do the same thing I do that lots as it is, and will drive the car manually on occasion.
10 MPG Outback
nipper replied to nicolo69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats typical Japanese 4 cyl cruise conrol calibration. If you are in a loit of rolling hills use Drive 3, it will really make the car much happier.You just shut it off and drive uphill, it is not a bug as much as a silly design feature. Do the vac gauge like I suggested and post the results here. There is no such thing as too much data for those of us who do not have the car infront of us. If your code reader wil do it can you give us the % of load at idle, 30mph and 60 mph on level ground (or the avg load). Hrmm the decelration only happening above 40, i think we may have a clue. It should happen all the way down to where the car will max out if allowed to creep at idle. Some cars will get up to 15mph due to tranny calibration. How is your wheel alignment? Have you tried better fuel? Forgive me if I am repeating myself as this thread has gotten long, but was the knock sensor replaced. Is the egr functioning. Do you have a scangauge so that you can read these things on the go and get a real MPG reading? Is your cat clogged? I sort of wish we had data and not information on what you checked as that would give us more information.
Where's my hill holder?
nipper replied to Bostonian1976's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's back with the CVT and stick.
Knocking Noise/Vibration When Getting Underway
nipper replied to Bostonian1976's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI could have gotten you a source for one almost 1/2 that price. http://www.driveshaftspecialist.com/?gclid=CJWX9bujtqECFcRM5QodjSGF_g
nipper replied to Bostonian1976's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.cars101.com The hill holdr on your car is that stick between the seats below the shifter
97 Legacy outback no power why
nipper replied to ericjames86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats a first. It is listed everywhere, from FSM to parts catalogs as a seperator plate. http://allwheeldriveauto.com/subaru-seperator-plate-explained/
10 MPG Outback
nipper replied to nicolo69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk you may have a small shop, but there is one tool that everyone seems to forget about. The vacume gauge. It can give you so much information. http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm Lets give that a check.
nipper replied to Bostonian1976's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn a older used car my rule of thumb is in the first year expect to put at least 50% of the purchase price back into it, so thats about right. Where is the driveshaft coming from?
AC no longer cold after HG replacement
nipper replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as the system does not have a hole in it, a quick replacement of a bad valve o ring etc won't require any parts besides what is leaking. And if you are putting a gauge on it it should be a gauge set, even if you use just one gauge.
1976 Master Cylinder and other problems
Sometimes Brute force is called for as these pipes can be a real pain in the arse no matter how good you are. Remeber the basics of mechanics... Vice Grips Torch (heat source) Big Hammer Duct tape The first two should be able to help you take things apart.
nipper replied to ericjames86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is this speel-ing U speek of?
Trouble Resetting Computer
nipper replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIllanrob, i was referring to the original post, not yours. If iI was referring to yours I would have quoted it . You are also OBDI not OBDII which is a different beast. Original post from Axgutt I got a CEL on my 95 Legacy Wagon (2.2, MT), and I'm having trouble resetting the computer (which is the first thing I usually try when I get a CEL). I disconnected the negative terminal before heading out of town for a couple of days, and reconnected it when I got back. Started it up without touching the gas, expecting it to do that thing where the RPMs go up and down for a little bit, but it just started idling normally (with CEL on). It seems like sometimes I can reset it by disconnecting the battery, and sometimes not. Is there some specific sequence I should be following? And we are still waiting for the trouble code.
96 legacy loud popping when shifting
nipper replied to Eshaw08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck mounts and anything else you touched. Maybe get the car up in the air (do NOT get under it), all four wheels and see if you can hear it better that way
nipper replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChevy has imported parts, the same way subaru has american parts. Yes do use him. He will be able to find the leak quickly and easily then fully recharge everything for you.
nipper replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExcept he is not mechanically inclined, personally i would rather he price it and get it done by someone.
10 MPG Outback
nipper replied to nicolo69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd best to do that with 3 fill-ups.
nipper replied to Eshaw08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it a pop, a thud, or a knock. When you rev the engine is it there? Does it diminsh with each upshift? Does it exist when floored in top gear? I am thinking a tranny mount
