Everything posted by nipper
2007 Tribeca key won't turn, wheel NOT locked
nipper replied to fanofmydesign's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnother Idea, find the gear shifter/brake pedal override. use that to put the car in neutral and see what happens.
fuel economy question, speedometer/4EAT question
nipper replied to notnowles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes yes and yes. There is a Vehical speed sensor in the spedo head. I bet the CEL is throwing a code. I wonder if the other VSS sensor is operating. In this car since I think it is a cable operated spedo when one VSS fails the other does not power the spedo. Are the gears stripped in the tranny or spedo? This will affect your fuel economy, how much fuel on 300 mile fillup? What is the temp outside? What is the avg speed/cruising speed?
nipper replied to fanofmydesign's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have another key? wigggle the key or play with moving it about slightly, it sounds like a worn key. Also wiggle the gear selector and try the same thing. Do you have AAA
Let's forget about Subaru problems.......
nipper replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did not know it came without it
nipper replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubarus never have issues.. More Eggnog anyone?
02 Outback bucking on acceleration
nipper replied to Ionlyhave3suubs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHELL YES! I missed that as posts crossed. You may even be seeing that start to show up a little bit. a grand is on the low side depending upon damage done.
nipper replied to Ionlyhave3suubs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust go with whatever subaru recomends for the car, anything more really is throwing money away on a subaru, as sometimes they can give the car indigestion. The waist spark ignition can sometimes be touchy about plugs. Dont forget the PCV valve.
Threw a rod in BFE WY...UGH
nipper replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI threw a rod at Dehners pass in CA a few years ago, very ugly. PO beleived in once a year oil changes. Blu had 191,000 miles at the time. Hope it all worked out.
steering wheel wobble/ break peddle wobble
Also check the sliders on the calipers to see if that caused the rotor warp.
nipper replied to Ionlyhave3suubs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen in doubt do a tuneup first, then we go on from there
Overheating on hills?
nipper replied to dhoch14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLets go to basics.. First replace the radiator cap. If that doesnt work go with an OE Thermostat Then inspect the radiator for damage at the cooling fins. have it tested for flow.
Jeep vs Subaru
I may be feeling my midlife crises coming on. I have to do the math, but I think I am entitled to my one "Converitble" in leu of my "blond bimbo" and may be able to pull it off. I just need to see if I can afford to keep the Justy. If not it will still be Blu and me since Mom has enough problems getting into Blu, would never be able to get into a new Jeep or a new Outback.
First Subaru, clutch slip
nipper replied to drdisco69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats an odd mileage for a timing belt. Check to see if all the seals and idlers were done too, if not guess what else you are doing. You win need two NEW throwout bearing clips from subaru. Do not mess with the rear main seal, they almost never leak and it is always the plate.
heater tech or tbl
nipper replied to Fuzpile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool. i just like to keep my mental database going. well no pun meant cool kind of thing.
heater tech or tbl
nipper replied to Fuzpile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen someplace we have failed you. We simply cant have things making sense in the last minutes of the unofficial i hate window thread time frame. It may be autocycling just to keep itself from freezing over winter. Also some cars do have the compressor come on at startup just to get the lubricant in the coolant to circulate.
heater tech or tbl
nipper replied to Fuzpile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually I havent see one specd out since the begnining of the OBDII cars. They usually are pricey to make as compared to a cheap liutlle plastic flapper door. Just iout of curiosity I would like to see a few. I also wonder if he may be having a sticking thermostat.
Warming up the engine on cold days?
nipper replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI should have said american (so I will clarify and not change), my mistake. As when i mean older carb'd in the US foregn cars were few and far between. Small engines (anything below a 8) didnt have any real competition till then. Also deisels (up untill the last 2 years) did not have cats, nor carbs, so they do not count either. Everyone knows of someone who has a car/widget/squeeqky that lasts way beyond what the planned life for the car/widget/squeeqky was planned, but for the moist part they were lucky if they got that far. Technically that is not a valid point either, otherwise i would be standing from the tallest rustpile exclaiming how the 1969 Rambler American was the best car ever built! HEY STOP LAUGHING AT ME! *giggle*
heater tech or tbl
nipper replied to Fuzpile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have absolutly no idea what you are talking about, but that has never stopped me before. Cars stopped using "heater valves" ages ago. They now use mixing or blend doors in the HVAC system to control temp and air flow. There is coolant constantly flowing through the heater core. Maybe you can gear your question towards that. By fan I am going to assume you mean your main radiator fan? In winter you may have things run that do not normally run in hot weather unless needed. This is done to keep them from seizing over winter. Ac compressors used to do this on some cars, along with fans etc affected by cold weather.
nipper replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt wasnt too much of an issue in pre-cat cars, as pre-cat cars were not expected to have engines that lasted too long anyway (60,000 miles was a milestone). Carbs and cats and winter startups with prolonged idle made for a nice warm car.... from the fire of the melting cat.
nipper replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurn key and drive is generally a bad idea at 30, very bad at 20, very very bad at 10, and dont complain to us your car has rod knock at zero.
nipper replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut then it is not the magical Christmas Coal
CVT Owners: Are You Impressed?
nipper replied to gbhrps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIm just pluggingin in here to watch. I hhave a justy with a ccvt. I have read the other boards, and this one seems to be whine free.
nipper replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso THATS why you walk around around your car three times in a counterclockwise direction under a full moon when it is below 30 degrees outsdie? And where is my lump of coal
Oil Consumption Prior to Valve/guide failure.
nipper replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLike GD said. In the field we call that increase oil consumption "Impending Doom".
nipper replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHeadgasket issue is not caused by outside temps, but that is another thread. Modern cars if you get in, start the car, put on your seatbelt, throw all the leftover McD's bags in the back seat you are good to go. If it is brutally cold you may want to give the car a minute before going. Drive nicely for the first 15 minutes to allow suspension parts and the transmission to warm up. The engine itself warms up fairly quickly.
