25
Everything posted by nipper
Big diffeernce. You get what you pay for, and cheap rebuilds are a crap shoot. They usually cause you to get a driveline vibration at idle because they are too tight, they wont allow the engine to freely shake (as the do). Search "Driveshaft vibration" Look at CCR engines website, they have a good axle supplier on thier page. nipper
Take the money and put it in the bank and forget about it. Thats what the extended warrenty people do. If you decide to go for it go over the plans with a fine tooth comb. Look for things that exclude transfer cases, AC compressors and timing belts. Now if this was a 2010 with a CVT I woud have a differnt opinion.
The car needs to start and run to throw a code. Its the weakness of OBD type diagnoses. Crank PS controls spark, Cam PS controls fuel injection. Usually the crank sesnor goes out more often then the cam sensor. I would rule out any fuel issues since the car starts and runs fine otherwise. Don't you just love electonics? nipper
Ok this being a 1991 (reread the lead post) I have no problem with you getting one from a commercial source. The issue is the 1995 on up legacies. Some stores sell you an imprezza alt as a legacy one, as they are way more exp and cant keep up with the load (been there personally). I cant see paying 200 bucks or more for an alt that on a car that "mature". Just dont get the 59.00 special. nipper
Since 50% of the work is going to be getting the tie rod end off the steering knuckle, I would replace the tie rod end. It is hard to tell if they are worn out or seized sometimes, since a new one can be very very stiff. If it is at all loose replace it. At leats you have a new one to compare it to. As an WHY get yourself a tie rod end boot too, just in case. I tore mine getting my tie rod end off. Luckily I had a universal boot around. nipper
Having the driveline up in the air is going to confuse you to hear the noise. For instance (im going to do simple numbers here). It takes three turns of the driveshaft to make the ring gear turn once. The power from the ring gear goes into a mechanical splitter, that avgs the driveshaft rotation between the speed of the left wheel and the right wheel (this is how you can make turns). If one wheel is turning 0 times and the outer is turning six times, the avg is three (hence the driveshaft speed). Thats why i was asking for the pattern of the noise. This is assuming is is a hollow sounding knock of some kind. If it is a scrape kind of noise it may be something in the brakes. Inspect the rear CV's too (though they tend to last forever). You may also wish to drian the rear diff fluid and have it drain through a cheese cloth to see what comes out of it. Chrysler rear diffs used to thunk as they got older, when you went from forward to reverse. This was just play developing in the diff, and the cars went thier entire lives like this.
