25
Everything posted by nipper
Already Made Them Mad
nipper replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well at least we will know he will never reproduce.... -
Sheesh 6 mouse clicks and it still won't download... http://www.subaruoutback.org/forums/showthread.php?s=&threadid=15247&highlight=diesel http://www.subaruoutback.org/forums/showthread.php?s=&threadid=15000&highlight=diesel http://www.subaruoutback.org/forums/showthread.php?s=&threadid=14293&highlight=diesel
On the outback board there are quite a few. Some of them are whining because they dont have automatic nose blowers or some such things. The one thing they do seem to have a legit concern about (but is true to all diesels) is the passenger cabin seems to be slow to warm up. Most these complaints are coming from sweeden and norway. Also under heavy acceleration they smoke somewhat (again diesels do that). Otherwise they seem happy with them. nipper
Shredded spline, drove in 4x4, did I do any damage?
nipper replied to Fox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i did this when i stripped a CV joint in my GL, no damage. nipper -
i personally dont like the numbers. I think they are still too low for a car that young. They are OK numbers, but not great numbers, i think you can do better. There should be minimal increase or none between wet and dry numbers. An increase of 60 psi between wet and dry tells me the rings have some wear on them. nipper
Ronald Reagan's old ranch Brat
nipper replied to Turbone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I dont know if i like the full restoration. Regan, love him or hate him, was a former President, and was most likely responsible for most the dings, dents, scratches and sweat marks in the car. Sort of like washing the Shroud Of Turin to get that nasty stain out.... nipper -
This has been posted once already, but still pretty. nipper -
Ignore this post -
You need to get a mechanical oil pressure gauge put on the car to see what the pressures are. Several possabilities are the used engine has bad bearings, the oil is getting dilluted by gas or coolant. ALso check your charging system voltage. You may also try a thinner oil. The light goes out because as the oil warms up, it thins out and flows better.
They should be alot higher then that actually. I would consider that a tired engine. Compresion numbers are not only the PSi but the difference between cylinders. one is a sign of engine wear (similar numbers) the other is usually valves or HG (one number low) and two numbers on the same side high/low a timing belt. I can't find my manual right now but speaking generally I would expect 175 psi or higher on a subaru engine. On other engines i look at the mileage and make a judgment call. At that Psi, you should notice a loss of power, maybe hard starting when cold, signs of oil burning. Maybe its just a mistake on thier part. BTW on a sooby a compression test isnt always conclusive on a bad HG. the next step would be to do a wet vs dry test to see if the numbers come up, but I tend to doubt the numbers you have more then doubt the engine
Boxer Diesel Transplant? Engine Dimensions?
nipper replied to DPDISXR4Ti's topic in Subaru Transplants
Another interesting point to add, that no one has discussed yet. Heat. There is a good discussion on the outback board from some scandanavians on how the cassenger compartment heat works. i hate to admit that i did not follwo it, but in the pieces i saw, it seems they use a heat pump (AC in reverse) and some other tricks to get enough heat in the passenger compartment. Diesels do not have a lot of waste heat, which is why they are so effecient. In Gas engines waste heat is managed by the cooling system (not including exhaust gasses). So this is not going to be a straight bolt in by any stretch of the imagination. But it is fun to talk about. nipper -
Our going to need the transmission too. the CI (compression ignition) engine puts out a lot of torque at lower rpms, and the tranny is geard for that. A SI (spark Ignition) engine's transmission mated up to DI engine will make it a dog. nipper
