Everything posted by nipper
Different Tires and AWD
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSearch torque bind if you dont want to listen to us. nipper
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBAD BAD BAD Its the quickest way to guarentee that you need to spend 800 or 1200 dollars later. By two tires, put one on each axle, thats the best solution. physically measure the old tires against the new and maybe you can luck out, or find a used tire shop and have them measure and match. If you have an automatic put the fwd fuse in. nipper
Subaru 4wd mini van taxi in Vanuatu
suzuki came first, but in this country it was sold second
Lift Kit - vibration - anyone can answer
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXboth. The sway bar is usually parallele to the road, not at a right angle to it. nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts banging against a few things, and i do feel more tail sway in the car. Its not as tight as it should be. I dont like moving the mounts either. I think I found a plan c. Getting the aluminum C mounts (99.00) and having them cut and extended by 2.5 inches to orient things properly. nipper
Dealer aproved lift kit?
nipper replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only place there may be one, or that I heard of, you have to be upside down. Someone on the Outback list in Austrailia had one installed at the dealer to keep his warrenty valid. On this side of the world it isnt going to happen. nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot under the car today and did some poking around. Anyone who orders a kit from Allied (BTW Albie is a blast to talk to) needs to tell them if its a stick or auto. Autos require two more spacers and the required bolts. Was a fun phone call, always comforting to hear "your drivng like THAT?!?!" Albie is sending me the two extra spacers. One noise was the exhaust came off a hanger. That seems to have cured one thunk (or possibly two). The exhaust was banging against the sway bar. The sway bar is located in such a way that it is sort of useless. So far there are two solutions. Drop the sway bar brackets by one inch. Second one is a 206.00 solution http://www.poltec.us/products/subaru/suspension/rear_end_links/1a-df015.htm I already talked to them and the extra 25.00 is to modify length of the threads. Surprisingly there is a quick turn around on this. I am up for any suggestions from anyone. I havent been able to inspect the carrier universal joints yet, thats tomorrow. nipper
Opinions on window tint
nipper replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck local laws and see how much tint is allowed. Too much tint, and get in the wrong neighboorhood and you can be a cop magnet. nipper
Vibration in brakes
nipper replied to Tommymc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRotors. Blu would do the same thing. I replaced the rotors and all is well. nipper
'02 Forester: wife wants to dump it
nipper replied to Hodaka Rider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am going through the altenator thing with Blu. Seems that there are some marginal altenators out there, so thats why I am buying the next one from subaru (and waiting for it now). I too lust after the evil empire, its a sweet looking car. But remeber Jeep comes up rather poorly in the reliabilty ratings, and it wont save you any gas. nipper
abs light question
nipper replied to timintc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXABS = dying altenator ABS + brake = impeding doom ABS + Brake + Battery = pull over NOW Get your charging system load tested. Make sure they test it at 2000 RPM with everything on in the car. nipper
Noticeable Engine Surge When Turning on Accessories
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not following your resoning. The way a battery usually dies is that the plates inside the battery shed enough material from charge/discharge that the plates short out. This is why optimum dry cells are superior to wet cells. This makes the battery into a resistor, which can load up the altenator, or cause the battery to self discharge, or worse case damage the alt. over 2000 rpm its all altenator. Under 2000 rpm it can be all altenaotr, or altenaotr - battery mix. It depends on what the load is and what the car is doing at the time. This is why when your in a catalysmic traffic jam in the summer, the first cars with thier hoods up are usually luxury cars. AC on full, all the gizmos running and the car is just ideling. This will kil the battery in a HUGE jam. Just reving the car up a bit keeps the battery charged. The highest load on the car is when everything is on, your in gear (auto) and your foot is on the brake pedal. Manuals are a little bit better with this. nipper
Legacy alternator in an Impreza?
nipper replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSnap it up at that price. I couldnt understand the huge cost differnce either. Oddly Autozone wanted a hell of a lot more for a rebuild. nipper
99 Legacy 30th anniversary lumberjack edition
nipper replied to fishy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk i'm not the only one that had that pop into my head first. nipper
nipper replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDefrost will turn the AC comprssor on for a short time to lubricate the compressor (if I remember correctly). The IAC motor is what kicks up the engine rpm when a load comes on the engine. Unless its more then a few 100 rpm i wouldnt worry about it. If it is more it can be a dirty IAC valve. nipper
radiator
nipper replied to Aja1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmodel mileage and year would be nice. A few things can clog a radiator. One is using tap water, another is the wrong coolant, too much stop leak, oil or tranny fluid contamination, physical damage.... nipper
Altenator
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru rebuilt unit. Yeah i couldnt beleive the price either, but thats what they said on the phone, so i said gimmie.... https://www.1stsubaruparts.com/ Jamies site has it too, just i dont have her link handy. nipper
Loyale... 2 Alternator laters, still no charging
This is the problem im having with a 1997 .. so dont feel bad. nipper
Brake Pressure Issue
On a MC its usually safer to buy a rebuilt unit then doing it yourself. nipper
replacing AT tranny, what else should I do while it's out?
nipper replied to biglittledog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe oil seperator plate (the plastic thingy) if it hasnt been replaced. They leak like sieves. The replacment is a metal part. nipper
EJ22 Phaze 2 possible head gasket?
nipper replied to 1Subaru1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts a Headgasket. No engine is immune from HG's, just the 2.5's are more likelyto blow one then the 2.2L. Bubbles are a dead give away. nipper
Help!! Looking at an Outback in a few hours Few Questions about Headgaskets
nipper replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPS . Make sure all the tires match Drive the car in a tight circle. With an auto on level ground it should be able to do it with no throttle or very little throttle. It should do it in a smooth motion. Check the condition of the tranny fluid. nipper
nipper replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it was a shoddy repair, it would have gone poof already. I would be more concerned about torque bind then a head gasket at this point. nipper
Altenator
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think I know why they keep missing the problem. I stayed in NJ overnight, and it got down to 58 degrees. I started blu up and he was putting out 13.2 volts (still a little low but the highest i've seen in a while). 295 was a 500 foot drive to the on ramp. As the car wrmed up, I noticed the voltage dropped. Eventually It went down to its 12.5-12.8 where its been sitting. As the Alt heats up it looses output. I am planning on chainging the battery cables, and am wating for the Alt from Subaru. The reason my shop kept missing it was because they were testing it cold. nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you, thats one part of the equation. nipper
