nipper
Everything posted by nipper
  1. I used to test autoparts When i mention a brand thats not OE I can vouch for it personally. nipper
  2. I just took Blue on a 2 hour high speed run down the Jersey Turnpike. Above 63mph, sometimes there is a vibration in the car. Sometimes its heavy, sometimes its light, sometimes its not there at all. Its not from the brakes/tires/steering. Did have blu up to 80mph and the same thing happened. I am thinking its the carrier bearing/u-joint. I havent been able to look under the car due to this wonderful NY august weather (62 degrees and rain). I sort of remeber reading someplace that someone else had the same problem. The allied lift kit doesnt adjust the height of the carrier bearing (which normally shouldnt be an issue). I also remember reading that it didnt take a lot of spacers (someone just used washers) to cure this problem. What I want to know, is this true or is my mind broken? Also does anyone know the size of those bolts? Lastly if I do need a driveshaft (wouldnt be surprised) wher ein the NY/NJ area I can get one. Junk yards here on Long Island are almost gone. nipper
  3. CHange the rear sensor (which can be generic) before replacing a cat. Iv'e seen a cat burned up in one tank of gas because some idiot decided to use a lead additive. I've seen them burn out in as little as 20,000 miles do a fuel injection issue. Subaru's tend to last a good long time after 100,000 miles, if not the life of the car. nipper
  4. Sounds like a bad MC, its sort of typical for one thats on its way out to go bad after changing shoes/pads. First rule out the booster, as they can give the same symptons. Pump the brake pedal 5 times or more with the engine off. With your foot on the brake pedal, start the car. The pedal should move towards the floor. nipper
  5. There is a HG additive fix kit out there, that no one has tried yet. Personally I dont see how it can work, and it has a really envolved process to use it. You have a bad HG, and only one fix for that. High oil consumption can be a few things, but its prbbly related. nipper
  6. Accessery drive belts (aka fan belts) can come from anywhere. Usually the ones in the stores are Gates. nipper
  7. Reverse gears are straight cut gears, and they dont have synchros on them. This is done for a variety of reasons, but it makes it tough to shift into reverse while going forward. It is normal to use a little more force, get a thunk, or sometimes a slight gear grind on occasion going into reverse. nipper
  8. From 96-99 I am 98% sure they are all the same. Subaru replaces anything older then 1997 1/2 with all new parts because of the design flaw, and i really doubt subaru (being a small mfg) has different parts for differnty years. they may tweak the skin, but mechanicals dont go through major changes. nipper
  9. Keep away from ebay for any parts that are critical to the life of the car. 200.00 is just too little money, you get what you pay for. There are a lot of low quality parts on ebay. nipper
  10. Always wondered what a volvo would look like with a gun territ on it. hehehehe nipper
  11. beter question, do you feel a vibration anywhere else ? nipper
  12. Yes it will be fine. My outback has a second lighter on the left hand side by the jack compartment, not too sure about yours. nipper
  13. and all i get to blow up are those mudder ruckin illumination controllers. (I have dash lights again but no dimmer) nipper
  14. SO you blew the main fuse AND needed a fire extinguisher thats a double point score nipper
  15. Subaru AWD 101 Review The car has a forced 50/50 split in reverse, low and full throttle. Any other time the computer vaires the split from 10/90 to 50/50 amd anything inbetween. The Manual is a 50/50 split. nipper
  16. Try the auto parts stores, as its a standard fuse. How did you manage to blow the main fuse? nipper
  17. It's not an svx unless it has a tranny issue looks good nipper
  18. We are going to let Mtnbob do that experiment :-p . I will go for taller tires eventually. Since I needed two degrees of camber adjustment, I dont know what the springs will do. I am extreemly happy with the ride. Three things Ive noticed... 1- Steering is a little heavier 2- The steering has stiff spots in it, since I dont do autocross not a problem (and may go away) 3- There is a very slight shutter when starting off from a start. I think this is from the carrier bearing/universals as this is the only part of the car that was not affected by the lift. And a huge bonus, so far I am not nervous about people tailgating me now, since I am taller then almost everyone else. nipper
  19. I wonder if they ever calibrate it. This is the second time i've gotten burned by a new fangled digital shiney tester. Some times too much information is a bad thing. nipper
  20. Yup, that it does. Thats why I ordered the replacmenet, as it actually was a little lower then at idle. nipper
