25
Everything posted by nipper
Time For a Cookout!! June 30th is the Date
nipper replied to Bucky92's topic in Meet n' Greet. Your USMB Welcome Center
Bring the wheel, a clean wheel nipper -
i have to WASH Blu????? oh he is not going to like that at all ..... nipper -
EA81 Dual Range 4x4 help - it goes kaboom!
nipper replied to Gyoas759's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are all your tires the same size? Also manual 4WD is not meant to be used on a dry surface. You get torque bind in the driveline (especially with mismatched tires). The kaboom is the driveline unwinding. Dont use 4wd on dry pavement. nipper -
I am going to ask a few questions first... What condition did you find the engine in. How was it stored. Can it be turned by hand? An engine sitting around for a while can be a bit of an unknown. What have you done to the engine to prep it for running before you installed it, if anything? Have you lubircated the cylinder walls? Have you removed the valve covers to see what condition the valve train is in? Rubber parts can dry out when they sit around. Modern engines dont like to sit around. nipper
hrrrmmmmmmmmmmmmmmmmmm nipper -
yes it is. i was thrown off by when the engine was replaced. The sender and the surrounding metal bacame thier own part seperate from the engine. The Tech said that we should replace the ECU temp sensor too since that took a hit. Now i see the connector (which i didnt before) i see which is which. i love my pain meds weeeee nipper
i'm voting for the timing belt, which it seems he has not looked at yet. There is zero indication of a HG failure. HG's dont kill the car, they will still run, but will over heat. Pull the covers and inspect the timing belt, make sure all the marks lign up, then we can start looking at other things. BTW, when was the timing belt last changed? How many miles on the car?
http://www.eng-tips.com/faqs.cfm?fid=1139 more reasons it can't be done. nipper
Resivoir gets that way. Its something almost everyone over looks. You should do it yourself. You can take it back to the dealer, but its only a 30 minute job in the driveway. Check your belt tightness yourself. Is the shudder in the car while making a turn, or in the steering wheel. Is this an auto or manual? nipper PS check the PS fluid level
There really is no method to bech test injectors (at home) to see which one is worn. You can test coil resistance, but that wont address the issue. DO NOT PRESSURIZE THEM AND BENCH TEST!!!!!!!!!!!!!!!! This can result in all sorts of ugly things happening if you dont know what your doing. We dont want anyone here winning a darwin award. nipper
http://www.nestleclassics.com/product_goobers.asp no touching the goobers .....
