25
Everything posted by nipper
In addition, clean out the radiator before you take the car apart. The reason for this is that everything is still liquid. If you do it after, everything is exposde to air, and that gunk turns to glue. get a new radiator cap. The sweet thing is that you are doing it before the car cooks. That should make the job really straight forward as far as the odds of the car being 100% when your all done. Also dont forget to clean the overflow tank, and do an oil change. nipper
Stil loosin coolant after head gasket replaced
nipper replied to Joey Joe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Compression test, both wet and dry. Remove the radiator cap, let the car warm up and burp, top off coolant, and look for bubbles. nipper -
Oil Leak
nipper replied to tomson1355's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Did you replace the front main seal and re seal the oil pump? Also there is an oil galley plug or two. A leak this big should be easy to spot. Clean the underneath of the engine using an engine cleaner. push the car out of the gaint puddle you just made. Start it up untill you see the dripping then shut it down and see where its coming from. Sadly there arent too many things that can cause this fast a leak in a sooby. -
Should I be looking for a new EA82?
nipper replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and it comes and goes.... nipper -
Code P0325
nipper replied to crowheart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
usually a bad knock sensor code is just that, a bad knock sensor. Not much to test on the bench, so i would just go ahead and replace it. nipper -
holy run on scentences .... Could you please rewrite that in english, then maybe we can help nipper
Why are we here.... What is the meaning to life ..... Who came first the chicken or the egg .... Whats the difference intiming belts .... All age old questions with no real answers. You really need to go with the factory recomendations. There is more to a belt then just design. The load the belt is under also has an efect on age. Also if your engine is an interference engine, you dont want to risk it. nipper
one word. Water. If your timing belt covers are off, if you wet the tensioners the noise should change. Actually do this to any idler for any belt. nipper -
rod knock is more aparent at idle then anyplace else. You have a vibration noise of some kind. To test for rod knock, at idle remove one plug wire at a time and see if the suspected noise changes. i'm voting for a heat sheild. nipper -
It's not that bad a motor. If you follow some peoples logic (blown HG), then by the same measure subaru makes the worst awd system in the world. (just as many TB threads as HG threads). There are many many many more people on this list with perfectly good 2.5L with over 200,000 miles on them. They are strong powerful engines, especially the DOHC engines. The 2.2 is a good strong engine, but i think the 2.5 is more fun. i have owned both. nipper
