nipper
Everything posted by nipper
  1. It shouldnt. The only thing it will affect is when the tranny upshifts. nipper
  2. Pull a plug and no change means that there is a dead or weak cylinder, plug or wire. Time for a compression test. nipper
  3. I took my BFG T/A on fire roads in the west and didnt have a problem. nipper
  4. If tis lazy it may or may not. The flashing CEL happens if there is a miss or backfire condition(or the cam can crank semsors are out of synch), not a bad o2 sensor.
  5. all model years with the 4EAT, low and reverse as per subaru. nipper
  6. Divisadaro (sp?) street scared the f*** out of me, and i dont scare easily. Extreemly steep, and 4 way intersections with stop signs that are for decoration if your going up hill. You cant see the cross street at all. i'm impressed and in awe of people who drive stick shifts there. nipper
  7. more likely people not knowing how to drive down steep hills. That sucks. i dont see any signs demanding useing low gear like i see out west, maybe thats part of the problem. San Fran has just as steep roads and they dont seem to have a problem. nipper
  8. oh i agree, but due to a car accident and the subsequential surgeries, i cant operate a clutch anymore. i am just hoping i can ride a motorcycle again... And the automatics have gotten so effeicent in a $WD manuals are now just a matter of personal taste. now a TRUE d/r case (like a 4:1 reduction and an auto its unstopable (aka jeep) nipper
  9. er um, its not important that you dont have an estimate (and if they didnt give you one its a violation). The fact they screwed up is enough to write the letter. nipper
  10. If you believe a motor vehicle dealer has treated you unfairly, contact the OMVIC. If your complaint pertains to a recently purchased new car with a major mechanical problem, you may be referred to a special arbitration program called the The Canadian Motor Vehicle Arbitration Plan. Ontario Motor Vehicle Industry Council 789 Don Mills Road, Suite 800 Toronto ON M3C 1T5 Tel: 1-800-943-6002 Toronto: 416-226-4500 Canadian Motor Vehicle Arbitration Plan Tel: 1-800-207-0685 Toronto: 416-921-2686 Toll free: 1-800-207-0685 If you have a complaint about an auto repair issue that doesn’t involve a dealer, please contact the Ministry of Government Services here.
  11. there is this thing called the postal system, you write a letter and complain
  12. Ne wheel bearings arent much more. a new tranny mount cost me 85.00 from the dealer. And there is only one mount i do beleive. 88.00 to flush the cooler lines? Man they are a rip off... nipper
  13. WTF USED WHEEL BEARINGS !!!!!!!!!!!!!!!!!!!!!!!!! :confused: :confused: andsomething else doesnt add up, a rebuilt tranny should have everything all done to it, no need for a clutch pack or valve body as seperate line items. nipper
  14. not a whichhunt just a fact. But in all honesty for every day driving it doesnt matter, SInce cars run so clean, and the lead is out of gasoline, filters dont have to work as hard as they used too. Fram meets specs, but just meets specs. the others exceed specs. nipper
  15. That year they all seem to have an odometer issue, thats not a biggy. Have a body shop inspect it and see what they say. nipper
  16. Found this on a mailing list: I do not normally interest myself in other than the performance type forums but a chain of events got me looking for more info on the Legacy electric antenna to close the gap on a few questions I have. I think from what is supplied here, and what some are asking here, I can say that now I almost qualify as an expert on the subject. I say ALMOST because there are still some anomalies in my part number catalog versus what has actually been observed. To really understand the "Mysteries Of The Mast", It may be helpful to first understand the curious factory radio situation. When the first gen Legacy was introduced as a sedan, The radio/cassette/CD combo was provided by Clarion. There was an electric antenna option which apparently Clarion was responsible to provide wire harness, electric antenna motor, and mounting brackets. The motor, brackets, and telescoping mast with toothed style cable were all provided and listed as an antenna assembly with one part number. When the Legacy wagon was introduced a year later, for whatever reason, the radio combo was provided by Matsu************a, under the familiar brand name of Panasonic, with corresponding responsibility for harness, electric antenna motor, and mounting brackets. Well, Matsu************a went to somebody other than did Clarion for the motor, and had the foresight to list the telescoping mast as a separate subassembly. The result for the wagon; different harness terminations, a different style smooth cable to mate with the different style motor take up reel, and different Subaru part numbers for the radio, the motor assembly and a separate Subaru number for the mast, none of which are interchangeable with the Clarion equipment on the Sedan. Apparently, to "normalize" the disparity in part number designations between the sedan and the wagon, Subaru later created a "synthetic" part number for the sedan mast corresponding to the format of the wagon OEM part number, even though Clarion did not provide a break out. Curiously, they also created another part number with a totally different format, for an antenna mast "option" for the sedan, which is priced considerably lower than the OEM number. Probably went straight to the motor vendor for it rather than thru Clarion. The wagon radio has the word Panasonic at the lower right corner of the multi monitor display window which is in the upper right hand corner of the radio. The cassette door cover will also have the alphanumeric characters P113...P for Panasonic. Not certain what the Clarion equipment has but I'm told it's some similar identification. Most cars do not have the CD player, which is what gives the most trouble and the reason for my search also for a radio combo after having it repaired twice already. It may be the CD player, which is a separate unit in the same bracket housing is a Clarion. My parts manual only list radio w/ cassette and radio w/o cassette. To see a picture of a stock 92 Legacy wagon radio/cassette/CD combo go here http://members.aol.com/ssspoon/cdradio.jpg <http://members.aol.com/ssspoon/cdradio.jpg> Now the part numbers as listed in what appears to be a factory catalog; AM/FM Radio w/o cassette Clarion 90 SOA333D165 91-94 86201AA200 Matsu************a 90 86201AA140 w/ cassette Clarion 90 86201AA110 92-94 86201AA340 Matsu************a 90-94 86201AA350 Power Antenna Assembly Sedan to 8/90 90-91 SOA447D465 Sedan from 9/90 91-94 86321AA090 Mast Subassembly 86322AA110 Mast Subassembly SOA447D466 (non listed option) Wagon 90-94 SOA333D470 Mast Subassembly 86322AA020 Subaru of America has changed the alphanumeric formatting of many part numbers from SOA to non SOA somewhere in the early to mid 90's. So you might have a part which if not identical is interchangeable and that part may have two numbers, with the old still in stock along with the new, and at different prices. Motor mounts or trans mounts are another example of this I have experienced. If your parts man is sharp he can save you a few bucks by looking up the cross reference, but the dealer may not want him to tell you. The following is from my source for a later Subaru OEM radio with remote CD changer I went to Hello, These stereos were designed for use in 2000 up Subaru Legacys and Foresters, and were manufactured in 2003. 90-94 Legacys had a 2 piece wiring harness and 2.5 DIN or 5 inch dash opening. In 1993 Subaru initiated a single plug wiring harness in their Impreza model with a 2 DIN< 4 inch, dash opening. This was adapted to the Legacy and Outback in 95, and is standard throughout Subaru since then, with the exception of the 2000-2004 LTD's with a 3 DIN opening. So, these are plug and play for 93 up Impreza, 95 up Legacy, all Outback, all Forester, and all Baja models. I have adapted them to the 90-94 models with an adapter harness and a 1 inch spacer to accomodate the odd dash opening. Through 99 Subaru had the clock function in the radio, but in 2000 they put the clock in the instrument panel, so these radios don't have a clock. 90-94 Legacys had either a single DIN radio with a 1.5 DIN compartment or a 1.5 DIN cassette/radio with a single DIN compartment. I can put just about any Subaru option in your car, but right now I have the original Legacy radio/cassette with a 12 CD changer under the passenger seat of my 91 Legacy, but my recommendation is the original radio/cassette with a new 6 CD changer under the seat, or if you had the radio only, a 95-99 radio/cassette which has a clock with a new 6 CD changer under the passenger seat. I also have options for large and small compartments. Robert (Pinkfull) rdean@inlandnet.com <mailto:rdean@inlandnet.com> DSCN0399 from a 95-99 radio/cassette which has a clock with a new 6 CD changer under the passenger seat is one recommendation. The radio is the same as yours except for the auxiliary input between the FM/AM button and the 1/REW. This allows you to plug in your iPod with a mini-RCA cable from the headphone/output. Beneath it is a CD changer controller which connects to a 6 or 12 CD changer beneath the passenger seat. It involves quick splicing in 5 wires. I have the mini-RCA cable, new 6 CD changer, used 12 CD changer, and extra magazines. Also, the changer set up could be used with your radio. I would recommend replacing your single CD changer unless you can find NOS. This is older technology and less reliable. Also, unless you like "stock" I would not recommend continuing to repair it. The CD changer "part numbers" belong to Nikon. The Subaru Number for the radio is 86201AA151, made by Panasonic, the Subaru number for the controller is H6240FS040, the 12 Disc changer is CDC 1205, and the 6 disc changer is RDC 605, all made by Clarion. The 6 disc changer will fit in the glove box, but won't leave room for much else. Personally, I find under the passenger seat quite easily accessible. Try it yourself; it isn't much of a lean to reach under the back of it. Once you have removed your stereo, you will need to assemble the mounting brackets to the replacement units, splice (I will furnish color codes) in five wires to the small harness plug without cutting any wires, lean toward the passenger side and feed one end of the changer cable up and through to the stereo opening, press the cable up under the lower edge of the console going back to the passenger seat, go under the seat tracks and feed out past the back of the seat. Now plug the controller into the radio, the cable into the controller, the lights and power for the controller, the antenna, and the two radio plugs. Slide the assembly in, 6 mounting screws, 4 trim screws, cupholder, and ashtray. Plug the cable into the changer and slide it under the seat, slide the door open, slip a magazine in, close the door. Allow the changer to finish its cycle, push the power button on the bottom right of the controller, and adjust the volume as it starts to play. In order to listen to the radio or cassette, the controller must be shut off. Also, it is advised to have everything off when plugging in the auxiliary RCA cable. I have another option DSCN0582 from the 98-99 Legacy/Outback Limited : AM/FM/Cassette/CD with Weather Band, CD changer controls, and clock. This is the Subaru Premium Stereo system from 98-99, the last year with the clock in the radio. With this stereo you have radio, cassette, CD, and clock in the console plus the option of putting a new changer beneath the passenger seat. Minor scuffs on the display face are not noticeable in normal use of the vehicle. The spacer is cherry wood and has since been darkened by stain, or you can make your own. This will require an adapter harness and 1 quick splice. Installation for both systems require a stubby philips, a magnetic tipped philips, and pliers. It takes about 10-30 minutes. If you didn't require a clock, there are several more options available, but both of these systems offer what you want. I can put 6 or 7 CD's in the console, but none include the clock.
  17. If you think that OE makes 100% of everything your living in the 1950's. Now having worked for an autopart manufacturer (who was trying to become an OE supplier), i can tell you what goes on (but no one listens anyway lately it seems). We had to jump through hoops to meet OE specs, they were tough. OUr very best product went to OE, our 2nd best went to our product line. We chared accordingly. It wasnt that our stuff was bad, it was the fact that OE wanted better. Anyone can sell autoparts, as they wont get a lawsuit or the federal goverment after them (as long as they arent killing people). There is a HUGE differnce between OE and aftermarket, unless your lucky enough, or smart enough to buy from the same supplier. Even then its not a guarentee that it will be as good as OE. If its a small supplier (liek for Subaru, a small producer) odds are they will be equal. If its a large producer, it may not. nipper
  18. My sister had a BMW 3 series she just traded in for a lexus. The bmw was on transmission number 4 for the same thing, and it has about 52,000 miles on it. The transmission would engage reverse along with drive, and the same thing would happen. BMW has a seal issue in the valve body. i would guess that this is the same thing, but they kept reusing the same valve body. TCU replacement is not the problem. The tcu has no authority as to when the car engages reverse, as it is a purly mechanical function. nipper
  19. doesnt work that way, take it from an engineer. But it does reinforce that no matter the oil type you need regular filter changes. nipper
  20. first off 5700 for a transmission is a ripoff. Secondly there is no reason i can think of for transmissions to repeatedly chew themselves up except for a poor rebuild, (at 5700 that better be a brand new just out of the shrinkwrap transmission), or something is seriously out of alignement. The first ste would be to make sure the frame is straight and the moutns are all good. Second would be to do an autopsy on the transmission to find out exaclty why and where the tranny is failing. If they arent replacing the torque converter each time they are not being prudent. Transmissions are computer controled with a minimal valve body. Another possability is that it is going into reverse at the same time its in drive (that would be the downshift as reverse is traditionally second gear). Thats what i think is happening. It almost sounds like they are reusing the valve body each time, and thats where the problem lies. nipper
