Everything posted by nipper
Decarbonizing with water
nipper replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think that is a VERY bad idea on a car with a hot-wire MAF sensor, and poses a significant risk of damaging the expensive MAF sensor. Frankly, I also question the need to decarbonize a modern engine...the tighter regulation of fuel/air mixture in a port injected car compared to old carburated cars means that there tends to be few carbon deposits. I haven't found much of anything in the various engines I have stripped down over the years. Nathan Nathan, Your not going to hurt it since the sensor can deal with 100% RH. Using a spray bottle is essentially the same thing. Notice i said SPRAY BOTTLE and not ppour it down the throat of the hose. I agree about the carbon thing, but engines to get carbon inside the heads. my 97 obw autopsy i saw alot of carbon on the head but very little on the pistons. nipper
Differential fluid change good idea?
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTC no. . Differentials ROAR and the volume increases with speed. Its un mistakable in its sound. Now explain this whinning.... nipper
Can I trust the corner oil-change shop to get it right?
nipper replied to Juan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou do know that oil changes are assigned to the class "C" mechanic in any shop (unless step one is remove engine). They are the most inexpierinced and most likely to mess up. nipper
Im about to replace HG any tips?
http://www.aa1car.com/library/ic697.htm do NOT tell somone he needs a rough surface if hes never done it before. Thwey will usually make things worse. The surface must be smooth to a machined finish. But hey waht do i know, pulling a wrench since i was 5 (45 now) and just an automotive engenieer. nipper
nipper replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsigh.... Ok basics, the wider the throttle is open, the less vaccum there is. Close the throttle its at the highest (accelration is close to 0 in hg deccelration 28 in hg). http://www.imperialclub.com/Repair/Fuel/VacuumGauge/index.htm http://www.procarcare.com/icarumba/resourcecenter/encyclopedia/icar_resourcecenter_encyclopedia_gauges.asp There are many places to pull a vacume, and depending upon what it does, it can be choked, reverse or not even go to the engine directly. I would use a spray bottle and spray it down the thraot of the snorkle of the air box, AFTER the air filter. nipper
99 Forester Speedo... went all the way around...
nipper replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGoing by my outback 4 screws once you get the plastic surround off (four screws on that too) 5 wire looms (one in the middle of the cluster) Carefully manover the cluster out (steeringwheel all the way down) i dont remember if it is 4 or 6 tabs The plastic isnt brittle so it wont break easily. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure Mr show off with your three stars ..... nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAPI GL-5 SAE 80W-90 Gear Oil nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsame weight as the rear (or are you going to make me look it up) nipper
NNONONONO this should be machine smooth, no scratches. Scrtaches are extreemly bad. They make leak paths. this is bad bad idea. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou put in the weight that is required by the factory. It never hurts to change the fluids. nipper
nipper replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubarus stopped using cables in 1995-1996. nipper and yes your spoiled :-p
Doing the T-Belt/H2O pump on the 92 legacy
nipper replied to oregonloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi used to work for Standard Auto Parts. We had a huge problem with counterfit parts from china. Dont assume that "they are the only ones that make them" Subaru does NOT make these parts, but the parts do have to meet Subaru spec to become a sunbaru part (and they are tested). Same goes with body parts, hence why you make sure your getting only OE body parts when the car is damaged. Now where do you think the rejects go? Also there is a HUGE business in counterfit parts, literaly right down to the nuts and bolts. I have been a design engineer and a buyer, i can tell you stories of vavles that would come in and have a 90% failure rate. now where do you think those failures went to? Look in any industrail supplu director (thompsons) ther are literally 100's of bearing manufaturers for example, but very few i would buy from. penny wise and dollar foolish. nipper
Wheel slip in AWD?
nipper replied to NoahDL88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok lets try something. Put the car in low and try it. Low forces the car into 50/50 torque split. If the wheels still spin and the rears just sit there, you have glazed AWD clutch plates. nipper
Wheel slip in AWD?
nipper replied to NoahDL88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX400.00 thats a steal, a real steal. Mine cost 850.00 at the dealer. nipper
installed JDM fogs
nipper replied to iluvdrt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi like those so much more then my outbacks.... nipper
QUICK! Is there an override for the security override?
nipper replied to oil_leaker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.cars101.com will tell you how to do it nipper
Squeaky door 91 legacy
nipper replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno no no for door hinges (and lock mechanisims) you use white lithum gease. it comes in a spray can. nipper
nipper replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer um.... So.... Just remoove the instrment panel, take off the plastic cover (its held on in little tabs). GENTLY remove the pin, reset the needle, reinstall the pin (it pops in and out easily). Plan B get a used spedo head and rebuild the cluster. Cluster comes out in about 15 minutes. Worse case scenario is that the board is fried, go to ebay or junkyard and pick one up for 40.00 nipper (and im ashamed that you didnt think of this tsktsktsk) and there is no cable, man you get a newer soobie and you forget all this stuff.
Final Tips?: 2.2 for 2.5 swap - 96' OBW
nipper replied to jmickelct's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat grossgary said. Sometimes you can get a deal. I've gotten deals where you buy the car for 500.00, they drop it off in the yard, you pick it clean, they come pick it up when your done. nipper
99 Forester security system question
nipper replied to oil_leaker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich leads to the question, has anyone every had a forester stolen? i mean, really, its not like the hottest car in the 'hood..... wasnt too long ago that no one in thier right mind would steal a subaru cause they were so slow :-p nipper
Cam seals leaking
nipper replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can wait as long as you dont mind breathing in oil fumes from burning off the exhaust. the one you cant wait for is when the oil pump or main seal goes, then the car will hemorage oil. Oil wont get on the belt as long as those two other seals are ok. nipper
nipper replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing to worry about, what kills the cat is raw gas, not carbon and water, which the car normally expells anyway. i havent done this since 1980, but it is still a tried and trued method. Thats why blown HG 's have one really clean cylinder (on any car but subaru's). One thing, point the car AWAY from the neighbors, and make sure you are upwind from the car. this makes a hell of a lot of smoke. Use a spray bottle. Do it untill the exhaust is puffy white. Dont let the car stall. nipper
nipper replied to oregonloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes they were on the forum, but its been a while so i cant recall. Well there are two issues here, not so much interference engine, but when you are stuck on the side of the raod, usually in bad weather, waiting for a tow truck, usually on a sunday, then the time it takes to reinstall the parts and the cost, its just better to di it with the right parts the first time. nipper not to mention the whinning passnger that is complaing.....
nipper replied to oregonloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNO NO NO NO NO BACK AWAY FROM THE COMPUTER We have had people in the past buy parts on ebay with mixed results. Some parts you can take a risk on some you cant. Get the parts from a reputable dealer, either subaru or a mom and pop outfit. nipper
