Everything posted by nipper
04 Outback Wagon piston slap
nipper replied to Garry's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1- Yes 2- if it is bad enough that the dealer is syaing the 2 pistons need to be replaced (people end up having huge fights with dealers over this) then do it. 3- That is the common replacement procedure. Do a search here on piston slap and sit down with a cup of your favorit hit beverage, it will be a long read. nipper
85% ethanol test
Well then hes got great luck, as everyone including the people who make the stuff say it should not be done, or he did it properly by completly cleaning the fuel system and replacing the rubber parts (or confirming that they are alcohol freindly). I have done lots and lots of research on this, and ther is alway one odd ball claiming it works (see the water thread) but everyone strongly advises against it. nipper
Run a Sooobie on Water? ...
arent they called water fountains? hehehe nipper
99 legacy emissions issue Warranty?
nipper replied to subeman90's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOEm for front, and 99% of the time it solves the problem. The cat is good for 100,000 miles, the sensors are 50 i think. nipper
Weak brakes
the new generation forum Another thing to look at, it may be time to replace the break hoses. They can get soft internally and give you what you are feeling. nipper
OverHeating EA82
You have combustion gasses getting into the water jackets. If you are lucky its a HG, if your not it can be a cracked head. How is your oil level? Pull the plugs and see if they all match, or if one is cleaner then the others (sign of burning water). nipper
85% ethanol test
You may have a problem now. Ethanol is a strong slvent. you may have loosened up all the crud in your fuel system. I dont know how long it takes for the stuff to attack rubber, with any luck yuo have escaped that. I dont think its going to hurt any of the floats either, but you DO have to change the fuel filter now. There is alot of things that have to be changed to run on e85 to make a car run on it. nipper
Weak brakes
This is in the wrong forum, but do you have rear drums? Frozen rear adjusters or mal adjusted brakes can cause this problem. WEak brake hardware in the rear can do it too. nipper
Binding issue in 95 Impreza Manual
nipper replied to Huck369's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTorque bind in a manual is terminal. It's like finding out you have cancer and 3 days to live. The viscous coupling is cooked. There is no longer any slip between plates. You need either a new VC assembly with the center diff, or a used transmission. Unlike automatics, there is no way of rectufying this or trying to make it work. The viscous coupling is a sealed unit within the tranny and it does not use the gear oil. nipper
Dtc P0420 '00obw
nipper replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts always bad that the cat is actually bad. It's rare at that mileag but it happens. When you hit your hand against the (cold) cat does it rattle? A bad o2 sensor or two can cause the car to run rich and burn up the cat. How long did you drive with a bad o2 sensor? nipper
Just a little
81 DL: No spark when warm?
Bad ignitor. nipper
Alternator w/ or w/o regulator?
OE has been doing it for many many years. Its a common conversion on older (read pre alternator) cars. i see no harm in it, just get the wiring right. It does eliminate the possability of just replacing a bad regulator. nipper PS why would you want to do this?
lets see him put his finger in the flame, if the flame is cool. Patents dont mean anything. At least he calls it Hydrogen technology, bot brown gas. What they dont show is how they get the hydrogen out of the water. you can run any engine on H2 with no problem. Ibnteresting to notice that all these vehicals have carberators, and none have fuel injection. At least the second one seems more honest. nipper
Hmmm...18.4 MPG...?
Do two checks, one is simple. Get a vacume gauge and hook it up. Give us the readings, as we can tell the health of the enigine by what the needle is doing and what it is reading. Next you may want to do a compression test to make sure mechanically the engine is not feeling its age. Carberator is the most likely suspect when everything else is exhausted, but it would be to get status on the engine health. nipper
"How many miles do you drive in a year?"
i did 10,000 miles in 5 weeks, but dont tell my insurance company nipper
So austrailia is in a 1000 year drought sand they are playing with water to energy cars. There are several things worng here. The puff os smoke was defanitly from gasoline. If this was such a true invention he would not go by Joe X. You cant have combustion (compression) without heat. a cold running engine is bad for the oil. I found this http://educate-yourself.org/fe/fejoewatercell.shtml Someone is smoking really good dope out there. They are saying there is no friction in the engine, and that the mixture implodes. Hydrogen burn colorless (i worked with Hydrogen can make interesting fires). This is seriously flawed in so many way. its funny to read. nipper
Help, please. 90 Leg, no-start... "open" between relay and fuel pump
nipper replied to NorthWet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnly one way to find out. Disconnect the relay. Take an ohm meter and place one end on the relay terminal, the other on the fuel pump feed. This will check the wire (you will need extra wire to do this). SHake the harness at the tank end and see if you loose continuity. Its very very rare that there is a wiring problem. you may have a bad relay that is on its way out. nipper
Shake when accelerating
nipper replied to MiniTransAm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat he said and easy to check. You will feel it in the seat of your pants. Get under the car, midpoint and see the driveshaft and its bearings. grab both driveshafts and shake. There should be no play in the X or Y direction. There should be none at the bearing either. nipper
No power when cold
nipper replied to TROGDOR!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems like people have done it here before. You need to do a search on how to do it properly (i may be facing that myself). nipper
power steering pump question
nipper replied to rpl3000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts a pressure sensor. It ups the idle rpm at full lock. If you dont have one you dont need it. nipper
low tone a bit wobbling moaning (like bad tire) sound from front on LL Bean 2001
nipper replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it was anything mechanical, the subaru dealership would have told you. Thats the purpose of the cupons, to get you in and find things wrong. Since they didnt im betting tires. nipper
No power when cold
nipper replied to TROGDOR!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave we cleaned the mass airflow sensor? i'm sort of stumped since the car is not in front of me. There arent many things that are working while the car is in open loop, but the airflow sensor is one of them. nipper
No power when cold
nipper replied to TROGDOR!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave we checked the engine temp sensor? nipper
No power when cold
nipper replied to TROGDOR!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnipper
