25
Everything posted by nipper
I would replace the oil pump. Since the pump is the heart of the engine, without that the rest of the engine would be crap. Now if you have a feeler gauge you can probably inspect the oil pump and check the clearances to make sure its still in spec. Another possability is an oil pump from a lower mileage engine. nipper
this is a 3 year 36K warrenty? You need to get the "antifreeze conditioner" and put it in the coolant (its just stop leak). If this still fails, then there is a 100K warrenty kicking arounf on HG, but you may have to fight for it, but it only works if you put the conditioner in. Now i dont know what happens if the dealer discovers the leak first then adds the conditioner. nipper
whish i still had acess to a machine shop nipper
well you can do that on any car on a dyno , again there is that extension cord thing, and doesnt prove driveability or durability. nipper
:-p nipper
500 CFM really isnt worth the effort in this configuration. Its the right size, but it needs to be exhaust driven.. Especially when you consider you have to power the thing with a large electrical current. Also the cost of the extension cord is going to be a bit much. nipper
Chains on the front for two reasons, the cars are biased towards the front, and there is more clearance in the front wheel wells. The majority of people run all season tires here on subarus with no problems. Actually at this point in time in the universe, thats sort of like asking if radials are better then bias ply on the car nipper
Usually what happens is not that they break, is that they jump a tooth. I would wait till 105,000 miles, unless you have some need to do it now. If you push it beyond 105,000, way beyond then it may break, the tensioner can fail, etc. Ive always had the luck of a timing belt going 2000 miles past the change date. nipper
