25
Everything posted by nipper
A few issues, first off is that if i remeber correctly subaru flywheels dont like being resurfaced, as they are already pretty thin. Secondly look at the TSB's on this issue. The other thing is the clutch slave/master cylinder. The fact the clutch play changes as the car warms up tells me there is an issue someplace in the hydraulic clutch. nipper
the optimal fuel air ratio is the same for performance or economy http://en.wikipedia.org/wiki/Air-fuel_ratio 14.7:1, thats why we have all this neat and fascinating computer equipment under the hood. You get the best performance and ecnomy from fule at this ratio. The rest relies on valve timing and other design factors. Since it has simple wiring, its not a chip, its just a more sophistacted way to fool the ECU, not unlike what you see on ebay, instead of you turning a knob, itdoes it automatically. nipper
start by replacing the bad VSS sensor. That is a good/bad item, no imbetween. Without either VSS operating, you wont have AWD, and the car may go into limp mode. What is supposed to happen is when one VSS fails, the other takes over and operates the spedo. Its possible you have 2 bad sensors (examine the wire harness) and your car can be in limp mode The ignition coil thing.... they may have hit it on the head, but if its been over 80K since a plug/wire replacement do that yourself. Also spray the oil with a water filled water bottle one evening with the car running and see if there are any sparks (cracked coil tower). What have you done if anything since the original thread.... nipper
It can be done without removing the heads, buy using compressed air in the cylinder to keep the valves from falling in the cylinder. Now my question is, does it go away after the car warms up. i have always been concerned about opening an engine up for a little thing like this, as it tend to snow ball into a valve job or bigger. A Valve job can blow a high mileage set of rings, etc. Can you live with this? How much oil does it use? Do a wet/dry compression test first and get a feeling for the health of the engine. nipper
Strange sound
nipper replied to Moover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
A bad differential makes a ROAR like nothing else on the car will. It gets louder with speed, and is unmistakable. FIrst thing is to inspect your tires, check for cupping and broken belts. Next is to install the FWD fuse and see if it has any effect. CHeck your lubricant and fluid levels. nipper -
Winter Oil
nipper replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Dont forget the winter flasher fluid..... nipper -
Rack inspection is more of a sympton thing then an inspection. First you rule out the pump, fluid, and universal joint. The symptons you describe (worse when cold especially) are indicitive of the seals in the rack being tired. When the seals are cold, they shrink. The seals already leaking when warm, are leaking much more when cold. Once the fluid warms up it becomes a less of a problem. I think your rack is tired. http://www.car-stuff.com/subarusteeringrack.htm nipper
