25
Everything posted by nipper
watching Rides on TLC. They are customizing HHR's. One shop had a BRILLIANT:clap: idea, i mean f'n brilliant. They put a turbo on the car, but since its too cramped under the hood, they put the turbo on the exhaust pipe after the rear axle under the floor. Now i can see where you would loose HP and throttle response possibly, but.... hrmmmmm ..... evil thoughts very evil *stares at outback* nipper
a few questions
nipper replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The brake calipers are held on by one bolt, and another it swings on. If one is loose you will get chatter. Rule out the ABS, pull the fuse. If you rember your science lasses, you should (i hope) know what frequency it and vibrations are. a vibration can occur at specific frquencies, but not others, frequency being car speed. Lets rule out the abs first. Now how many miles on this. The B solenoid can be keeping the torque converter locked up longer then it should be when breaking. Try braking the car in Low, Drive2 Drive3 and see what happens. nipper -
a well maintained car built TODAY should last 200,000 miles. in 1997 the life expectancy on average was 140,000 miles. You did get good mileage out of that engine. Also remember for every bad engine or car there are many more good ones on the road running well. Fine ill take a boat anchor or two ... nipper
a few questions
Ok here is a list Wheel bearings seized/bad cv joint bent wheel broken belt in a tire wheel balance (can happen at any specific speed but will always repeat) bad suspension component bad tie rods loose calipers warped rotors (they can warp real fast if improperly installed or el cheapos) ABS would not make the car shake, just the brake pedal. APply the parking brake while moving this will maybe help tell if it is front or rear. Does it do it in reverse, or any change in reverse Turning any effect on it? nipper -
a few questions
if they over tighten the lug nuts on the wheels they can warp the rotors. Inspect the tires for broken belts never go back to the guy that said purportioning valve. who did the brakes? What kind of pads were put in Could be improperly installed pads, loose caliper, there is a list,, -
a few questions
i thnk B is the lock up torque converter, not sure.Are your rotors warped or out of round from having the lug nuts overtorqued? Wheel bearings? nipper -
i disagree, replace it once and be done with it, Headgaskets while annoying is not a death kneel for this engine. When a honda blows a HG do you replace the engine, no, you fix the HG. It's much ado about nothing. Now if someone wants to give me thier 2.5L with a blown HG since they think its junk, ill take it gladly. nipper
