Everything posted by nipper
Anybody used the cheap clutch kits from Advance Auto?
nipper replied to Subarunation 713's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell its true, either that or you enjoy doing it twice. I wouldnt say you have to go to OE, but do go with a name brand clutch kit. nipper
Eat your hearts out
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPICS!!!!!! i am so happy, too bad i need an adaptor plate to hook them up. it also has an audio alert from what i can tell if the temp gets too high or the oil pressure too low. There is a blue wire that looks like it would go to the oil pressure switch. http://www.ultimatesubaru.org/photos/showgallery.php?cat=918 nipper
Eat your hearts out
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://cgi.ebay.com/ebaymotors/AUTO-DIM-DIMMING-MIRROR-COMPASS-TEMPERATURE-ICE-ALERT_W0QQcmdZViewItemQQcategoryZ33699QQihZ018QQitemZ280028514397QQrdZ1 and its also a little larger then oe, another plus. i got mine for 70.00 nipper
Eat your hearts out
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnone of them detect it off the glass, even factory. There is a sensor that mounts in the grill, mine is on the license plate. The biggest PITA is finding a spot through the firewall. i use the gas pedal gromit, and that is rather crowded. The mirror kit is desighned to easily pass through things. The only complaint i have is that i have to reset mine from degree heading to degree fareinheit everytime i start a trip. i LOVE the auto dip, it works great. nipper
Eat your hearts out
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit came today, so the shipping was worht it. i just need to rotate the gauges 180 degrees to lean to the driverside. Whats really neat is that it plugs into the factory radio harness for lighting and the voltage gauge WOHOO! nipper
Eat your hearts out
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi already have the compass and temps in the rear veiw mirror nipper
Eat your hearts out
I finally solved the gauge issue. I got a JDM gauge set from ebay, complete with factory harness and senders. It mounts in the pocket under the radio. I paid a bit much for it, but i worked it out in my head as justifed, considering how much individual quality gauges are, then the work mounting them. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=190027289998&ih=009&sspagename=STRK%3AMEWN%3AIT they bolt right in. Now i need an adapter plate at the oil filter to screw in the senders. nipper
anyway to tell
nipper replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe numbers mean something, what are they nipper
AWD and hyrdoplaning
nipper replied to drewd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTires play a huge part in hydroplaining. AWD helps to some degree, but its mostly tires. When i had the FWD fuse in the car hydroplaned like mad, but after the awd was fixed, it almost disapeared. My tires are 1 year old BFGoogri How many miles and what brand of tires are on the car. nipper
ej18 q's
nipper replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe. Thats when the switch over happaned. Look for a daignostic pin connector in the dash, i think that would tell you. nipper
Are VCs interchangeable?
nipper replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst question is is it it an auto or manual. Second do all the tires match. i dont know if a gen1 wil accept a gen2 nipper
Brake noise(99 Imp O/B sport)
nipper replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstop shouting if your not in a rush, https://www.subarugenuineparts.com/oe_parts_cat.html they ship fast, but it will take a few days. call jamie. Other wise OE kits come from OE nipper
Emissions failure? PASSED!@!!!!!!! WOOT
nipper replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA jumped timing belt can cause a emissions failure, but the car wouldnt run better with just an 02 snesor then, it would still run odd. When was the last time a belt was changed. what were the values on the emissions, we really need to know this in order to help you out. It may be a bad converter, but we need those numbers. he has to give you those numbers, go to a differnt shop. nipper
Grease Fittings & Universal Joints
nipper replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit goes with trying to make cars as maint free as possible. Grease fittings have been disapearing since the late 1970's nipper
nipper replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe subarus have a driveshaft that goes to the rear wheels. In the center of the car is a carrier bearing, and there are 4 sealed universal joints. When the center joint foes, its a comon practice to take it to a drive shaft shop and have it replaced with a ford ranger ( i think, been a while since i had it done). If the car only lasted 180-200,000 miles it would be ok. But cine they go far beyond that, when they go (not often) they need to be replaced. With the grease fittings they will last for ever. nipper
nipper replied to Subarunation 713's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou get what you pay for. nipper
2000 Outback Limited Wagon Headgasket
nipper replied to dfeck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvalve cover gaskets .... make sure the covers are tight first. nipper
2006 Outback Sport Brakes
nipper replied to Eric Barr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXunder what conditions? and yes is the fluid resivoir full. i dont think its the abs, as that doesnt hold a lot of fluid. ABS is a passthrough system. Either way i would have it towed to the dealer. How does the brake pedal return? nipper
nipper replied to Eric Barr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt can be a bad master cylinder or a bad booster, but it sounds like a master cylinder. On a new car thats rare, but build enough of anything and the long shot failures will pop up once in a while. Has this happened more then once? nipper
nipper replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreplace the pads, and get new rotors. You can machine the rotors, but 90% of the time your better off with new ones (not all that expensive). Also check the sliders on the calipers to make sure they are free. Get yourself a haynes manual and that will cover it, its not really all that hard to do. nipper
nipper replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou probably need break pads, when was the last time they were done? nipper
Slight bang or like dead spot....
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt solved it for me too. Use OE wires. nipper
Low Gas Mileage 2001 Forester
nipper replied to librarygal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhere is a thought, is there a rear wind deflector on this forester? nipper
90-94 Legacy Sport - Speed Limited?
nipper replied to testy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi used the pull down menu to pick the make model and car. The only options were a 2.2L turbo and a 2.5L turbo. i get the feeling this is generic box that fits anything. i also get the feeling it may over ride the ECU instead of reprograming it. Would be interesting to see the install directions nipper
P0446-Evap Emmis Control System
nipper replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXheheheh you funny. When i worked for the fuel cell company, i wrote the manuals and got to name the assemblies and parts when they werent named already. This is true for most engineers, they get to name thier own parts (i wrote the manuals and desighned processes and parts). We ddidnt need no stinkin books, we just made it up as we went along. I even named one part "widget" nipper
