25
Everything posted by nipper
a clutch can do weird things. Can you go through the gears with car off and the clutch depressed? Can you start the car in gear (clutch depressed) then try shifting. Get under the car nad make sure the linkage is good. Also IF your going to chenage the tranny (i dont think its the tranny) might as well replace the clutch. This is not a standard failure mode for any manual tranny unless something is broken inside, and even then you would still have 3-4 5-R. Does it go from 2nd to neutral or is it just stuck in 2nd? Check the linkage. nipper
can you do this again when the car is warmed up? The problem may be your scanner. Not all scanners can read subarus, as (subaru being subaru) has a code on to itself, that meets the letter of the law, and can be read by most scanners. Ford also does the same thing. WHne i fisr installed my scantool, i got the same thing, untill i told it i was running it on a subaru, then it was happy. nipper
What are typical component lifespans in miles?
nipper replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Look at it this way, you can replace a part on your schedule, or on the cars schedule. The cars schedule usually reqyuires a tow truck in the middle of a cold rainy night. i prefer my scheduale, its much more convient. i also disagree with the go with the flow theory. It goes against everything i know as an engineer. You can cause just a lot of damage with a ball joint or a tie rod failing at speed. Telephone poles tend not to jump out of the way. Parts do give warning that they are going bad, but not everyone can pick up on the subtle nuances, or is trained to. Noises that build up gradually over time can escape an untrained ear. Also noisey bearings would fail an "inspection". i too worked on F15 compnonets and other air plane systems. i would never let my car becomes a bucket of bolts. There is no excuse for a maintanece part failing becuase it wasnt rreplced on scheduale. Older subarus are more tolerant of this method, but i still don't like getting stranded. nipper -
delayed lock up
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
doesnt matter, it can be flat or down hill. Uphill i understand. nipper -
heheh i know we probabaly all just jinxed ourselves ..... well at least we know who to blame nipper -
FWD is the universal symbol for front wheel drive, for like almost forever. 4wd is the same for four wheel drive. Its designated by SAE and the NHTSA. This was not a subaru invention. These markings are set by engineering standards. There is normally a label that says read your owners manual someplace on the instructions label for changing the tire. Very few people read thier owners manual. Very few read labels. There is only so much you can do to rule out peoples stubborness or stupidity or thier big brains. Every tire changing instruction i have ever seen has said Read your owners manual. If you buy a car without one its your responsability to get one. Also i've seen lables disapear on cars. nipper
Radiator is exposed to the elements. They clog from not using deminerilazed water. The cooling fins fall apart from the elements (corrosion). A radiator my guess from past exp would be 160,000 miles or 160 months. On a non interference engine you can wait till the timing belt breaks, but i think now all subaru belts last till 100,000 miles (sort of silly making some last only 60, then others 100). Materials have gotten better since then. Waterpump should be changed at either 100 or 120K miles depnding when you do the belts. Wheel bearings are tough, but again probably over 160,000 miles. Altenators no rhyme or reason. Spark plugs have a much longer life, along with wires then subaru says. Usually 100k or more. The ignitor isnt on there. Thats maybe in the 160,000 plus range. Another questionably short subaru interval is brake fluid, which should be changed at whenever brakes are done over 100,000. Cap and rotor depends upon the brand. i had a blue streak last the life of the car. Axles depends upon when the boot rips. Coil can go for ever Fuel pump if you dont run the car to fumes will last the life of the car. On my two 1980's subarus i never had to change struts, fuel pump, master cylinder. One i never changed the clutch, but did have to change the cables. I did have to change the universal joint in the drive shaft and shift linkage bushings. Most things you replace once every 150-180,000 miles. nipper
