25
Everything posted by nipper
150 is too high, you can strip the threads in the crank, then you will be really in trouble. Go with the numbers we said here. With the Loctite (which i dont beleive in personally there) and the proper torque, you wont have a problem. Remeber that this may have to be removed again in the future, and you donw want to stretsh any threads. nipper
in my legacy i was shocked, it took me all of ten minutes to pull the instrument cluster out of the car, another 5 minutes to disassemble the cluster, 2 to re assemble and 15 to put back in (i forgot to plug in a harness). i would imagine the forester is the same thing. There are 5 harness that need to be unpluged and its out (4 obvious and one behind it). I know on my car there was screws for the trim bezel, then i think 4 screws for the cluster (dont remember). The plastic cover snaps off easily (these cars ARE giant leggos) then some screws in the back and the gauges come out. Be very careful, i found out the pin for the needle stop comes out easily, but also snaps in just as easily. Be aware of this nipper
there is a long list of what it could be. Since the car has high mileage and unknown history, we need to start off with the cheap things first, and do only one at a time. Since this is an emissions test, he can't really test it in his driveway. i would do all the cheap things first (checking sensors, cleaning, insepcting. replacing inexpensive parts). Fuel injecters, if they are leaking, can be had a scrap yard. Do an opil change, check to make sure the car reaches operating temperiture (thermostat) check the temp sensor for the computer. Borrow a code reader and see what the sensors are doing. Inspect the spark plugs, check the gaps, clean and regap if on a low budget. PCV and air filter of course. Thats the down side to this, mechanically you fail an inspection you fix it and see the results. Emissions you cant see the result without going back to an inspection station. You do what you can in layers, but only one at a time, incase you do something to make the car run worse. nipper
Reason i ask is that it is a hall effect sensor. Everytime a tooth passes the sensor it makes a pulse. That pulse is translated into a mechanical movement of the spedo. there have been alot of bad spedos in this year, and usually just cleaning the connetcions where the head slides into the assembly fixes it, but this is the first time iver heard of it holding 40mph. a bad sped sensor should throw a code. You may try to clean the head first (its free) then see if it works. After that then feel free to attack the sensor. The haynes manual says to use a AC meter that is analog and look for needle movement as the sneder is slowly rotated. i just dont want to see you spend money when you may be looking at the wrong end. nipper
the keyway looks good, how is the key? i had mine let go and do some damage. The previous "owner" had the timing belt changed, but the shop didnt torque the bolt properly. It started as an odd vibration i couldnt nail down. I had to fly to Anchorage for work, car sat in laguardia for 2 weeks. i started it up and all hell broke loose. i guess it didnt like being alone at the airport in winter. nipper
i cant tell from the pics, they are too distorted. the worst case scenario if you dont want to go through the pain of replacng it, is you may have to clean it up a bit with a file. PS a beam type torque wrench is juat as good as a digital or a snaping torque wrench. This is really one of the most important bolts on the car. You have no idea how lucky you are that the keyway did not get mangled in the crank. nipper
We generally recomend OE, since OE gets the design changes first, and your never sure if aftermarket has got the latest change. As much as i love felpro, go with OE. Also do an oil change, its cheap insurance. You never know how hot the oil got, and with a small pan, it doesnt hurt to change it. nipper nipper
