25
Everything posted by nipper
Idle Question
nipper replied to jamraw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
IAC is not working right. nipper -
how in heck did he get on a second set of headgaskets? thats unheard of. unless he over heated the car then blew the gaskets. just get a 2.2L form the same year and yould be good to go. Personally i love my 2.5, but with that track record even i would switch to a 2.2 of the same year or generation nipper (and yes there is alway somone around to say its happened to me so hush...)
We always say to use a subaru thermostat (aftermarkets cause headaches). Now the 2.2 is a reverse flow (thermostat on the bottom). Since the temp gauge isnt saying anything (and they are a reliable place to get info). im a bit puzzled. Your not showing the typical symptons of an air buble in the cooling system, but thats the first thing i would check. Is the car full of coolant after its been run? Check the raditor for flow after you put in the new OE thermostat, replace the cap too since your there (its not expensive). For the hell of it check the physical condition of the radiator and make sure its ok. nipper
the engine (motors are electrical devices, sorry pet peeeve) wil last as long as its maintained and not overheated. We have lots of soobies here crossing over into thw 200,000 mile range, and some over 300,000 miles. 1.8L is 110hp/110 ftlbs of torque (not bad by the numbers) 2,2 is 135/140 2.5 is 165/162 (1997 year of my car)) 2.2L turbo is 160/181, i cant find numbers for a 2L turbo. If its an automatic no matter what you do your going to lose alot through that pre 95 gearbox. nipper
Strut mount
nipper replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
i vote for the strut mount (the thing on top of the strut). It has a bearing in it that may be seized. nipper -
Ej-25
nipper replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
this sounds oddly familiar, i think someone else ahs the same exact problem... nipper -
New Clutch
nipper replied to cannonball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Can you adjust a hyd clutch, yes. SHould it be adjusted, no. By adjusting it you are taking out the lash adjustment that is there for heat expansion, and can fuin the clutch. Sometimes you luck out, others time you dont at all. nipper -
Gotta question
nipper replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
when you downshift or upshift and keep the same road speed does it go away? Try starting off from a dead stop in 4th gear. If you can do it your clutch is getting tired, if the car stalls your good. My other theory, which the mileage is to low for, is the center carrier bearing on the driveshaft or the universal joints. I am ruling out the mechanical stuff before we get to the electronics (my weak spot but im getting better at it). nipper -
Gotta question
you cant post a metric car on american board WHat year is it. Som subaru clutches are bugy. I think there is a tsb on this side of the pond, but i dont know if they carry on over there. nipper
