25
Everything posted by nipper
88 gl automatic transmission problem
nipper replied to dmcluen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is one of those things I cant diagnose from the desrpition, but I am going to go out on a limb and say due to its age it is tired and needs to be replaced. You can try an addative as a last ditch thing, May buy time. -
This is for the Justy but I don't think it matters to the question at hand. SMP (Standard Motor Products) Carter Bosch Beck/Arnley I used to just buy SMP/Hygrade by default, as that used to be a more complet kit. Beck/Arnley is on clearance give away price, but I can not find out what is in it. So aside from SMP, anyone have any opinions?
Did you start with a basic, like the shuft cable adjustment? -
just diconnect it and see what happens don't take it out. I bet it doesnt get better. 1000000's of these have been installed and never has anyone had mpg drop, so I think it is another issue. Also it is not fair to bash someone as over the phonoe they would not know where to start. I wouldnt either unless the car was in my driveway or shop. I could rattle off quite a few things it could be, but that wouldnt be fair untill I saw the car. What I would do once it is here as opposed to the list of posabilites can be endless. Good luck
coolant blow from exhaust...
nipper replied to Suba_GL_87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
But i wanna Easter egg! -
Check the intake manifold gaskets. I think on this engine coolant passes through them and a common place for a leak. -
Yes. If you stop and think about it you changed a dimmension that the pushrods go over. It doesnt take much to throw the valve adjustment out in a case like this.
If it ran fine before, and now it doesnt, time to retrace your steps. Is the vlave clearance properly set?
but your all the way over there .... way over there..... how are you with carbs
This is for a fwd ford but you get the gist: http://www.drivetrain.com/images/stories/documents/axel_instructions.pdf Remco's Axle-lock Coupling Disconnects the automatic transmission for towing a front wheel drive vehicle. The Axle-Lock is a mechanical disconnect built into the vehicle's front drive axle. A single Axle-Lock is installed into the right front axle (passenger side).When the Axle-Lock is placed into a disengaged position, the transmission will not turn and the speedometer will not register mileage. To understand the principle of the transmission disconnect, where only one axle is disconnected, you should understand the built in effect of a differential. It is commonly known that with both drive wheels off the ground, and the transmission in "park" position, when one wheel is turned forward, the other wheel freely turns in the opposite direction. With the Axle-Lock in the disengaged position, the left wheel can turn forward while a portion of the right axle connected to the Axle-Lock turns freely in the opposite direction. The right wheel also turns freely with its axle disconnected at the Axle-Lock. This same principle used in the Axle-Lock, is used by several US and foreign manufactures of 4 wheel drive vehicles to disconnect the extra axle. Disengaging and engaging is accomplished by reaching around the front tire, and rotating the Axle-Lock housing one-third turn; clockwise to engage, and counter-clockwise to disengage. Steering the front wheels to the far right, allows easy access to the Axle-Lock.
For automatics there is available a pump to circulate the auto tranny fluid to keep the transmission happy. There are even certified cars to be towed behind motorhomes (not many).
Yes they do, but I could not find out if they disconnect because they are getting dragged, or like the old 4wd hubs and are manually turned to disconnect. You can powerslide a 4wd vehical on loose surface, just have to practice.
Not really. No one makes a device to disconnect half shafts from the front wheels. There are free wheeling hubs that used to be used on the rear wheels, i haven't seen any on the front wheels. There are drive shaft disconnects. I am sure someone someplace has rigged something up, but with enough money and a machine shop one can do wonders.
No its rather complicated from what i see on the justy board, but no one has done an tbi swap. I dont see why that would be too hard. An ideal FI swap on a justy seems to go out and buy a FI justy, put your licese plates on it, and you converted it.
1989 Justy was the last carberated car in the US, after that they went to FI.
Ah the megasquirts i have seen on the justy board has been full blown FI conversions. I wonder if you can just bolt on a TBI fomr a sooby and all the needed electrics. I would like to see the TBI conversion, for that I would be interested. I talked with 1st subaru who had a 360, he said subaru carbs aren't available anymore and he is going to ask around to find me a good rebuilder.
