2
Everything posted by 3Pin
So my friend's son parked his 97 5 speed legacy wagon for the summer and pulled out his summer driver. I think he left a light on. It drained the battery good. Fast forward to fall in Wisconsin. They jumped it, got it running and the lights are flicking on and off. Car will not move though even in neutral with the car off. He set the parking brake when he parked it. It was dry as a bone out that day so we don't think the parking brake is locked up. . I told them to hit cars 101 site for the resetting trick for the key fob and to get the lights to stop flashing. Will the lack of battery power also immobilize the car's transmission or are we chasing another issue after flashing light issue?
My 2 cents.....You might want to snag a used wiper motor for cheap and just include it in the sale and clean up the interior in the pictures. A Dirty car does not sell as well as a clean one especially inside. Not a big fan of the aftermarket hub caps either. A parts yard would have 4 subie caps for cheap as well I am sure.
reconnect horn
3Pin replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
hit a parts yard and see what you are missing and grab it. -
lots of people say only ngk or subaru ignition wires. I would start with new good quality wires. Might be a good idea to tighten teh gas cap as much as you can or replace it to go after the p0442 code. Here is what some other sites recommend for troubleshooting: P0300 SUBARU - Random Cylinder Misfire Detected.... Possible causes - Faulty spark plug (s) - Faulty ignition coil (s) - Clogged or faulty fuel injector (s) - Intake air leak - Fuel injectors harness is open or shorted - Fuel Injectors circuit poor electrical connection - Ignition coils harness is open or shorted - Ignition coils circuit poor electrical connection - Insufficient cylinders compression - Incorrect fuel pressure... The P0300 code means that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are common caused of multi-cylinder misfiring. If no leak are found the next step is to replace the spark plugs. If the problem persist more tests needs to be done to diagnose problem,............................P0442 SUBARU - Evaporative Emission Control System Malfunction... Possible causes - Missing or loose fuel cap - Incorrect fuel filler cap used - Fuel filler cap remains open or fails to close - Foreign matter caught in fuel filler cap - EVAP canister or fuel tank leaks - EVAP system hose leaking - Fuel tank leaking... The P0442 code means that the control module has detected a small leak in the Evaporative Emission (EVAP). Loose fuel tank filler cap is the most common cause that triggers the P0442 code.
I second the Gates stuff as junk. Had a water pump leak at 300 miles and the rest of the idlers were from China. Like AISIN. All OEM stuff. Fits nice.
- 17 replies
- timing belt
- timing belt cover
(and 3 more)
Tagged with:
Zip, this is a free world. Go where you want, but wouldn't it be interesting to actually have a conversation about why you want to put the coil in in the first place? What if adding the coil doesn't do jack? Or what if the coil had an interesting positive result? Either way, in this polarized world where it is just so easy disagree about politics, to flip people off in the car or tell someone off in the internet, we forget how to respect each other or talk to each other. Maybe if you were across the bar and talking about this with GD, it would turn out different? my 2 cents
For $250, I have a 95 2.2 in Milwaukee that would be perfect swap for your car. You can also source 2.2's via car-part.com. as well, but they are pretty high mile and cost in your area. Any swap, you should just do HG, timing and seals etc, but it would keep your car on the road longer and it should not be too costly. That is too nice a car to junk for sure.
The 2000-2004 are great tanks for a kid to learn in. In the rust belt, you should make sure rear sub frame is not rusty. Wheel bearings, Head gaskets, timing belt replacement are all good stuff to look for. I sometimes find a cheap outback with a broken timing belt for cheap. Then fix the heads, do the head gasket and timing belt, idlers, cam o rings etc rear main......you get the idea and while it is up drain and fill the tans with a new spin on trans filter. That way, you pay $250-500 for the car, but can afford to do all the rest of the things that will make it reliable.
1992 Transmission Assembly Subaru Legacy BLU,4SW,LS,2.2L,AT,AWD,FL 277,788 190142 $350 E-Z Auto Wrecking USA-WA(East-Wenatchee) E-mail 1-888-558-6767 / 1-509-884-5000 99 I just looked up your car on car-part.com and 3 pages of transmissions came up. Make sure the trans code on your trans is the same and you are good to go. This one seems pricey and higher in miles than in the midwest, but it may just be the market.
What year and engine are we talking about here? I just looked at my part stash, and the knock sensor plug from 2000 2.5 from the intake is a male and the knock plug sensor connection is female. Where did wire pull out? Was it out of knock sensor or the female plug in the wiring harness to the intake? If the wire connection plug of either is bad, you may need to repair or replace it or the CEL will come back again and again.
