Everything posted by TheSubaruJunkie
I believe the lower hole is where the mixture screw is. But its only the idle mixture screw, so i dont believe it will change anything when the car is on the throttle. And i believe you have the 2bbl Hitachi cause I dont think the C/W have that idle mixture screw. -Brian
valve sizes, stock cam info
TheSubaruJunkie replied to bushbasher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What program is this? Is there any way I can get a copy? -Brian -
I'm jumping ship too...
TheSubaruJunkie replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You'll be missed. This isnt subaru related, so it will be locked and used as an example. Thanks for understanding. -Brian -
Newer Subaru Carbs
TheSubaruJunkie replied to tdangelo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Weber is the best mod you can do to a EA81... but it definatly wont appear to be stock. The EA82 manifold will bolt to the EA81 with no modifications, but the thermostat is housed on the other side ont he EA82, so there are slight mods that have to be made when running the coolant hoses. As far as power gains, i wouldnt expect to see any. And as far as going to MPFI, you'd need to find a computer to control the EA81 MPFI heads and injectors. Also you'd need the intake from the MPFI as well... all can be found from a EA81T, but they are rare. Also, the main problem with the EA81T is when they overheat, the heads crack... leaving the most important part useless. -Brian -
The rear bushings on my '92 Turbo are wore out real bad. Enough to make the car swerve if there's enough weight put on that end. So, every subaru ive ever owned has had torsion bars and shocks. Never have i seen so many trailing arms, springs and bushings. My mechanic said they need to be pressed into place, but im sure i can manage to get them out and new ones in without a press... right? Also, im not sure if each bushing has a different name, but i noticed 2 that were destroyed. Both on the drivers side, but im sure the passenger side is just as bad. I didnt have a chance to look at the front suspension, but my mechanic said most the damage is in the rear, and the front is fine. Is it okay to just replace the rear bushings, or would it be best to replace all the bushings? Im short on budget and time here, just need to get the car "Safe" for now. Is this a terribly difficult job? I have plenty of tools, and room to work, but the structure of this legacy is all new to me. Thanks all -Brian
to all brat masters?????????
TheSubaruJunkie replied to beachbum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Not sure, but lemme ask you this.... Why in earth would you take a good 4WD and convert it into a 2WD? expecially Auto (BLECH!) -Brian p.s. No offence, meant it in the nicest way possible. -
All i need is about another .5" more in the rear. I'll see what i can find, but not too worried about that right now. I just got back from the shop, and while the car was in the air i took a look at the rear bushings. They are all shot. VERY badly might I add. The mechanic said they needed to be pressed into the control arms... is that true? Im going to start pricing some bushings and see what I can find. Josh, where did you get your bushings and how much did they run? Did you get bushings for front and rear? I think i might just do the rear bushings cause the mechanic said the front's werent that bad. -Brian
"Pick-N-Pull will be having a 1/2 Price Sale at all participating locations Saturday, March 20th and Sunday, March 21st! Pick-N-Pull Nevada locations will be having the 1/2 Price Sale Friday, March 19th and Saturday, March 20th!" Got that in my email this morning. I'll be going to the PnP in Rancho Cordova this sunday to get parts for my Legacy. Anybody else interested in going? -Brian
Thanks Em... I just got the car yesterday, checked the oil and thats about it. The car needs new brakes.... seems like the rotors are starting to warp. Hope their as easy to replace as EA81's are. Maybe after I got new pads, rotors and bleed the brakes things will change. Are there any other proceedures involved when bleeding the brakes on a car with ABS? -Brian
Kinda fell in my lap...
TheSubaruJunkie replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, 162k on the clock... not bad at all. Took it to my mechanic today on my lunch break and dropped it off. He quoted me $950 parts and labor for the clutch. So i'll be picking it up tomorrow and hopefully he'll have it ready by lunchtime the parts car, is a 2WD so i guess i wont be getting anything off of it... but i will be in replacing suspension parts soon. -Brian -
Legacy777, ive already stumbled upon the bbs and also the library... all i can say is WOW! What a great colaboration of subaru information. It definatly helped me out. Im thinking im going to replace ALL the bushings, and maybe even the struts. Prices i saw last night were alittle more than i was expecting. -Brian
Its actually 262,328km, not miles. -Brian -
My ABS light is on in the Legacy. I read in the manual if it stays on, to have it checked by the dealer (HAHA!! Yeah right!). When i brake, sometimes i feel the peddle fall slightly and it shudders alittle. Sounds like the ABS is trying to work. The car's braking is also spurratic. Sometimes when i brake it has a very solid feel and slows down nicely. Some other times, it seems as if I have to press the peddle down farther to get it to stop. Should i really take it to a dealer? Or is there something i can do to help maintain the ABS system. I noticed the ABS lines that run to the front passenger corner of the engine bay. -Brian
PARTS!!! Definatly. Anyone know if the rear ends on the 92 SS and the 90 L are the same? -Brian -
Thats all fine and dandy... but lets stop the arguing. The car gets up and goes!! I think the Power steering is failing. -Brian -
1992 Legacy Turbo Sedan. 5spd, AWD, 4dr. When i accelerate real hard, seems like the rear end wants to swerve to the left. When i let off the gas, the front end wants to veere to the right. Makes it very difficult to handle the car at high speeds when it wants to fishtail everywhere... and its kinda scary. And if i hold the steering wheel steady and let the car make a wide right turn, the front of the car will steer hard, then steer back, then sharp, then back... and repeat... all without me even moving the steering wheel. Also seems when i brake hard, the rear end wants to swerve as well. Anybody have any ideas? -Brian
The car is a pig right now cause the clutch wont grab. Kinda sucks, but i bet it will be night and day when i get that new clutch. Found one on the Legacy Central board for a 2.2T and it'll cost $243 to have it send to my door. Should have it here this weekend. Might try to locate a mechanic that will install it for me, or just suck it up and do it myself. Leaning more toward leaving the tranny and engine in, and tilting the motor out of the way. Also... the car is a canadian car. So everything is in KM/h. Its going to be hard to keep it at the speed limit, when it looks like my speedo sais im cruising at 110. Also, the mileage is in KM/h as well, so it only has 262,000km on it, whatever that is in Miles I think its like 140k or 150k miles. Pix: And tons more here in my album: http://usmb.net/gallery/album205 Looks kinda beat up, cause it is. Car looks like it was the dude's fun-toy or something. The entire belly of the car is filled and covered with mud underneith. Checked, and no VLSD -Brian
