Everything posted by TheSubaruJunkie
Need lots of lift advice
You'll break your socket or ratchet before you break that bolt. That bolt is exposed to all the elements, so it will be kinda tough to move. Get some PB Blaser or some rust penetrant and spray that bolt down REAL good... maybe tap it a few times to help the penetrant work its way into the threads. Remember righty tighty, lefty loosy... tighten the bolt to raise, loosen the bolt to lower the rear end. -Brian
drilled/slotted rotors worth it??
I dont know if I would trust those ones on ebay. Buy em and give em a shot. -Brian
where's this ebay link? I dont remember ever seeing slotted and drilled rotors for our cars. OEM will work just fine. If you want your brakes to look real cool, then go for it. Dont forget to get a can of engine enamel and paint your calipers too. -Brian
14" M/T tires
Cause super swampers are alittle overkill to some. I opted for the kumho since my tires will see alot of pavement driving, and when asphalt is 140 degree's it kinda eats away at tires REAL quick. Expecially swampers since they're kinda soft and all. -Brian
14" M/T tires
At $90 a tire, I'd rather go for the Kumho Venture MT's.... they list for $80 a tire at TireRack.com. Tread pattern on the Kumho is simular, but looks to be a tad more agressive. -Brian
Your hatch has a 3.9 ratio open rear diff. There are two types of LSD's that came in Subaru's... a VLSD and a standard LSD. The Standard LSD is better for wheelin, and came in EA82's as an option... came in ALL RX's standard. THey are ALL 3.7 ratio, so before you can use one you will have to have it converted. Really, all that info IS in the FAQ. There's even some info on converting a LSD in the USRM. -Brian
Brat from AZ, alive and well
I dig the rear fender flares. Looks real good. Could use a super accelerated paint job now! Oh, and whats with the AMC Eagle in the background? Is that the lifted one your friend did? Looks like maybe he scrapped that idea?? -Brian
2002 Outback Sport Center Diff Lock
Use an older 5speed AWD tranny with an open center diff... then you can just weld that. -Brian
price question for AC recharge
Your lookin at spending big bucks at any auto shop to have your stuff converted. Ive never used a conversion kit, but I did have a friend with some extra bottles of R12 and he recharged my Brat. One can was enough and i was amazed how well the A/C worked after that. Find someone certified, and have them buy this: http://cgi.ebay.com/ebaymotors/r12-r-12-freon-refrigerant-r-12-new-12-ounce-NATIONAL_W0QQcmdZViewItemQQcategoryZ46094QQitemZ8076912971QQrdZ1 Would make it alot easier. -Brian
Has anyone seen this body kit for 4DR GL/Leone/RX Sedan??56K BEWARE
didnt goto the PnP last weekend.... and prolly wont go this weekend, its just too damn hot out. I'll prolly be in the garage all this weekend anyhow. -Brian
Boots and Timing Belt on '85 BRAT GL
50,000??? Wait another 100,000 and then start to worry And, you wont need to bother with timing belts or timing chains, those EA81's are OHV with the cam being run directly from the crank. It will last you well over 250,000 miles as long as you maintain regular oil changes. -Brian
That is no stock Subaru Body kit. Since it is an overseas car, its probably a one of a kind. He coulda adapted a BMW Kit, or any other kit for that matter... locating one will be hard to do. I didnt know your car was a sedan Eddy, those are my favorites -Brian
Yeah.... he's ozified. -Brian
Wow, 2wd ND dizzy upgrade is a good one
Ive found 12 degree's is about as high as you want to go on a EA81. -Brian
If im reading things correctly, it seems the SJR Lift doesnt come with everything you need. Like the steering extension or rear shocks. Then you have AA, who have announced they are pulling out of the subie industry. And that leaves you with PK Davis. And I can tell you from past experience, that PK supplies EVERYTHING You need to lift your car. If you want to run 27" tires, a 3" lift will be just fine. My car was running 27's and I had to do minor trimming, but that was only to keep it from rubbing on full-lock. I have since removed the lift from my old wagon, and I have to say it looks just as good today as it did when i removed it from the box 3 years ago. I plan on installing this same lift into my current 1984 Hatchback, and I will be running 27" tires again. Should be fun, i cant wait -Brian
Here are some pictures I took when i installed my lift a few years back. It includes a layout of all the blocks that came with my PK Davis BYB Lift Kit, along with a couple installation pictures. http://www.subaru4wd.net/old/New/lift/lift.html Hope this answers a couple more of your questions. -Brian
Yes you'll need a steering extension no matter what. -Brian
If you want to turn... yes. -Brian
There are no larger brakes for our cars. So you cant upgrade. You can get rear disk brakes if you want, it helps... but isnt neccessary. Whoever you buy your lift from will supply everything you need, no additional suspension components are required. However, your Hatch is over 20 years old, so nows a good time to replace the shocks. Not sure what you dont get. -Brian
Weber swap how-to
I tried downloading the pix, but they come over as the same small size. Maybe there's another link im missing. I have plenty of space online for images, lemme know when the .zip is ready. -Brian
Alittle work done to my bumper...
Probably, but i wont see rain for a few more months. -Brian
Weber swap how-to
Tom... anyway you can .zip some of those photos and email them to me? -Brian
Got other lights comming for the roof 6" round, 133watt spotties!! -Brian
MAV... SHHHHHH!!!!! So far, i have yet to get pulled over for not having front turn signals. Im in the process of locating some that I can screw into the bumper. I'll have to be careful when im wheelin to make sure I dont smash the lights. I have some other mounting ideas that may better protect them. -Brian
wheel bearing help
Yeah, check the castle nut on the end of the CV to make sure its tight. I usually stand on my breaker bar to torque them. -Brian
