Everything posted by TheSubaruJunkie
Allied Armament buy still open?
Look in the Vendor Forum. -Brian
Cant find rims to save my life. **FOUND EM!**
Awesome, thanks Mike. I may have to paint some fenders too... so i will definatly go get me some of that paint. Im also gonna be getting the Kumho's for these rims. Maybe I should install my WRX scoop and make a twin of your Hatch? Do you still have that thing? Any chance we'll see it at this years show? -Brian
It would be best to contact them. We wouldnt know. -Brian
Bratsrus1's 5speed kit - Clutch
Yeah, you retain the EA81 4wd selector. But the rest is EA82 stuff. I thought there were 1pc EA82 shafts, but i could be wrong. I Got a PM from Jerry that cleared things up a bit. Hopefully Jibs can get everything wrapped up, tired of seeing his brat sitting in the garage -Brian
changed thermostat, rough idle
Sounds like the AAV was disturbed. It resides ontop of the thermostat housing. -Brian
RX springs for an aditional 1" front lift.
Thanks Mick -Brian
EA81 4spd to EA82 5spd swap roll call...
Cool, so it looks like we gotta drill a hole. No worries, just thought things should bolt up. Thanks Guys, -Brian
RWD Conversion & a Rear LSD on a EA81 4speed....
I got spare axles IM not worried about it. I think i'll put the LSD in when i put the lift on tho. Im lazy :-p -Brian
Im gonna be putting my 3/3 lift on my hatch. IM wondering if RX springs will add an inch in effect making my car seem like a 4/3 lift? Has anyone put RX springs on their EA81? Do they fit the EA81 struts well? Also, would this effect my camber? I dont need to be eating away the outside of my front tires. -Brian
Dead off the line
Also check and make sure your ignition coil isn't starting to die. That and your spark plugs are good and not creating a short somewhere. -Brian
Ok guys, who's done the swap? Jibs is doing it to his brat and we're having some problems bolting the shifter up to the body. We got the EA82 shifter and all, using jerry's kit. There doesnt seem to be any holes in the body to bolt the shifter mount to. What did you guys come up with? -Brian
soob buggies
Use a EA81 Auto. I hear they're better than EA82's. -Brian
Weber swap how-to
I cant read a thing, even if I do download the images -Brian
We're trying to use EA82 stuff for the shifter... but the mount for the actual shifter lever has no way to bolt up to the EA81 body. And he's using the EA81 flywheel, so i hope those washers work right oh.. and do you HAVE to use the 2 piece EA82 driveline? Would a 1 piece EA82 driveline work. He's doing this to a brat. -Brian
Wheeling at crooked finger today(56k no way)
Looks like you had fun. You should invest in a copy of PhotoShop and crop those images down. Even with my 21" monitor im scrolling all over the place to view them. Could only imagine the poor saps stuck with 800x600 res. -Brian
Russ start your own thread about your stupid camaro... And Phiz... the Subie seems to handle alittle better in RWD mode. Not near as good as my RX with AWD, but better than FWD. Cant argue the better gas milage, i averaged 20mpg on my trip to Reno and back. -Brian
You had a rear LSD Nipper?? -Brian
Weird pulling problem in a 90 Legacy
TheSubaruJunkie replied to subieman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEvery CV ive had fail, shows signs of failure at high speeds. Except for the clicking noises... but vibration and pulling usually occurs at freeway speeds rather than 0-35mph. -Brian
SPFI Conversion Manual
Morgan, if you wouldnt mind I would like to host this .pdf on my servers to ensure its URL will always be working. I'd also like to submit this to the USRM. Do i give credit to Kelley or to You? -Brian
locating Peugeot Lugnuts?!
Danny, PM Me. If briam doesnt want this set, i have one for you. -Brian
Overheating 84GL
Try 22 years old. -Brian
CV axle help...
Oh, and the castle nut at the end of the CV is 36mm. Only tools you should need will be 12mm, 14mm, 17mm, 36mm and the 3/16 punch. You can get away without using a 12mm & 17mm and thats if you keep the brake assembly complete, and dont remove it. -Brian
Overheating 84GL
Chances are its the radiator. No use inspecting it, its hard to tell a good from a bad one. Spend the $100 and just get a new one. -Brian
CV axle help...
Lift your hood and take a look at the tranny. You see the CV joints attatched to the tranny??? That is where the pin your looking for is located. You can use a 3/16 punch to remove the pin. If you rotate the CV, you'll see that one end where the pin goes through has a bevel... this is the side the pin enters. When you remove the pin, you want to punch it out through the other side, the unbevelled hole. The lower control arm is the big chunk of metal that runs under your CV joint, and goes from the engine crossmember to the wheel hub. You dont HAVE to remove the brakes, but it may make it easier for you to replace the CV since this is your 1st time. Ive done it so many times, that I just set the parking brake and let the caliper hold everything in place... after I remove the pin on the tranny side, I unbolt the lower ball joint from the lower control arm and pull outwards... this is usually enough to get the CV to pop off the tranny. Then I take a hammer and wack the CV real good from the brake hub... once its removed, its just a matter of replacing with the new one. Good Luck, -Brian
TheSubaruJunkie replied to subieman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be a tempermental CV joint. If it starts to bind alittle, it may pull to that side... then when it free's up it would be like nothing had happend. Would also explain the high speed and acceleration only part. -Brian
