lmdew
Everything posted by lmdew
  1. Almost 300 Lbs and 150-300 to ship. I built a wood crate to ship them in. As a side note, both trans failed after shipping. They were not damaged in shipping, but I think the rough ride may be a problem. I bolted them through the box at the front and tied them down at the aft mount.
  2. I've used the Bosh P. without a problem, but have started getting the NGK based on other feedback. I have a set of stock wires I can send with the ignition if you want them.
  3. Cam & Crank seals and replace the oil pump o-ring and reseal the pump. Make sure you tighten the oil pump back cover screws. The new tensioners are not as good as the old. You can switch if you get the mounting bracket and associated parts off an 95 or older 2.2. IMHO
  4. I have a good used one if you need it. Lmdew@hotmail.com
  5. Remove the 10mm nut from the line cross clamp. Then the lines will go on individually. You should be able to thread them all the way on by hand. They can be a bear to start and they can be cross threaded. You can use a vacumm pump to pull most of the old fluid out of the pump before you pull the lines the rest will drain if you let it. Then just fill it up. You should go stop to stop with the new rack to bleed the system and keep the pump full.
  6. Get 3 gallons, drain and clean the pan, filter if you want. Fill it up and pull the top trans hose from the radiator. Put a temp hose on and run it into a gallon milk jug. Start the car and pour new fluid in at the same rate the old nasty stuff is coming out. Shut it down, put the hose back on and fill it to the cold full mark and then take it for the test drive.
  7. PM Sent, come and get it! I'm glad the cats worked out for you, Larry
  8. I've used the bolt up from 93 all the way to 98 on standard Legacys and Outbacks. The mounts have plugs in them so the threads do not rust. Pull the plugs and bolt it up.
  9. I have a good used one, needs a coat of paint. 1" receiver hitch. $40 + shipping from CO 80919 I pulled it off a 97 Outback that I sold. Lmdew@hotmail.com
  10. I have some good used starters, $25 shipped. Lmdew@hotmail.com
  11. Yep, what he said. Lots of 2.2 t-belts, never had a problem with the bracket or lifters. Make sure your using the crank mark on the back tooth and not the arrow on the front of the gear! This is the most common mistake and then you get to do it all over again.
  12. The T-belt, cam and crank seals, water pump and oil pump o-ring will cost about $200 for the parts. It's a day job if all goes well and you can do it. That will take care of the front oil leaks. The oil seperator plate on the rear of the engine does require either the engine or trans to be pulled. The metal plate is $12.00 and some RTV. Labor is the major job here. The transfer clutch soleniod can be accessed from the rear of the trans. You can check it by putting the fuse in the FWD fuse block, right rear of the engine compartment. With the fuse installed, you should have the FWD indicator on you dash. Is you AT Temp light flashing 16 times when you start the car? If so you have a code stored in the TCU. If you take your time and do the research up front all these jobs can be done by a DIY Mechanic. If you don't know which way to turn the nut to get it off or are not willing to read the manual and understand the procedure its best left to the shop.
  13. What did they say about the Alt when you had it checked? I'd check the alt to make sure its good. A bad alt could be causing the problems. How's the temp of the alt when its operating? I will be warm, but should not be so hot it burns you. If you need an alt, let me know. I have some good used ones.
  14. He's pulling the stub (axle) shaft out! Without this retaining the hub in the bearing the hub can come out. I know because this happened to me when I parted a few Legacys.
  15. The axles preload the bearings and keep the hub in the bearing. Without that preload you are asking for problems! You could get some old axles and pull the outer joint and just put it in and bolt it down. That would solve the problem.
  16. If it was an outback I would think they would fit, but on a Legacy, I think they will rub.
  17. Is it the shift lever? If its the lever, there is a solenoid that should release the lock when you step on the brakes. There is a manual release, pry off the black trim ring around the shifter. You will see a 1/4" hole in the shifter body, just push down with a round bar of some sort and it will release the shifter. If its your shift lock soleniod, and you want a new shifter I have one you can have for $15+shipping. If the shift lever is fine, the cable should be checked and fluid changed. It could be either. Is your AT Temp light flashing 16 times when you start the car? If so you have a trouble code stored and need to get it read.
  18. Would someone please send the 97 2.2 valve adjustment FSM Info to me. Lmdew@hotmail.com Thanks
  19. Most likely rust build up which may have caused the damage. I've had this problem before on east coast cars. Get some good P-oil and spray it down. Clean the splines on the old axle and work it in and out from the outside. That will push all the junk out of the splines. You may want to remove the inner seal or put a rag in it to keep this junk out. You could do this with the new axle as well, just make sure you get the splines cleaned out before you install it. It takes some time, but it has worked for me.
  20. Visit your local junk yard and look at the old trucks. Lots of great heavy duty coolers < $10 usually. Just make sure you clean them out well!
  21. The gauge pod is easy to pull, but tight. There are 4 connectors at the back. Lower the steering wheel all the way. Pull the 4 screws from the trim. Pull the 4 screws from the gauge pod and pull it out a little. Remove the connectors, 3 along the top, one in the back. Make sure the screws holding the speedo head are clean and tight, these are the connection points from the circuit board. If you need a gauge pod, let me know. Larry
  22. Has anyone put 225/70/15 tires on standard Outback rims? I think they would work, the fit will be tight in the wells. If you have this combination and they are working please let me know. Standard struts, no lift.
