Everything posted by ericem
New EJ22T
ericem replied to markman34's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Ya some of these turbo legacy's are way overpriced for there condition. -
engine stalls
ericem replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
cookie! -
engine stalls
winner -
I forgot to mention I bought my 94 legacy turbo with non working awd. Opened the transmission saw the clutch housing had actually cracked! I swapped in a good 4eat and guess what torque bind!! Swapped the tcu with one from another legacy turbo no more torque bind and again had the same issue random power light flash on startup but dont recall it torque bind going away turning it on and off sometimes. Good luck pretty sure you found the source of your problem!
Good post! AS much as people here hate 2.5's there is also VERY MANY aside from this community who have simply replaced the hg's on the 2.5 PROPERLY and have been driving for many many more years after the repair successfully without having to go down to a older underpowered higher mileage 2.2. I have had my share of 2.2l's which were trouble free yes! But I have repaired my share of 2.5's and those cars are driving around happily!
engine stalls
Nope alot of times it doesn't! -
Ya it's a tight one had my fuel pump relay die in my 93 legacy wagon too. I replaced both the fuel pump and ignition relay. Look close to the side there is a brown relay and a silverish/white relay. Get some long pliers in there and pop them off there holders. You can then grab the wires or the relays from the bottom corner lying on your back and pull the wires down so they are more accessible and can easily be unplugged. I found mine were wet from rust around my winshield letting water in. I left my relays just dangling you can kind of tuck them under the carpet so they aren't just hanging by the wires. Another thing to make sure is all the grounds are good! I recently had a friend with again similar clicking and all of a sudden didn't want to start at all was towed to my house. Found the main ground to the motor was corroded cleaned that one, and ran a seperate ground for the motor and transmission and chassis with some nice connectors and everything was perfect car was also running better then ever with no hesitation! PS: forgot to add you need to remove the knee panel with 4 screws in order to see the relay.
My friend picked up a 08 wrx over a 09 wrx because it was very very cheap compared to the 09's. It's pretty decently quick nothing like a 265 but you can't go wrong and I think the car looks great it grows on you to the normal car ethusiast they wouldn't mind the looks of the 08 + . Only thing that sucks is compared to a 06-07 or 09+ the 08 won't make as much power with stage 2 accessport and dp. Regardless it is still a great car very quiet, smooth, handles great etc again still not as fast as a wrx 265 or sti but again very very good because of there resale IMO.
