Everything posted by ericem
finally got some new tires for bert
ericem replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, definitly a good investment, and as a suggestion, pickup some bridgestone blizzaks.
how do I remove the woodruff key??
ericem replied to '86 oopsie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy dad had to get mine out, you got the timing cover on or off? my dad did if while on, he got pliers, and didnt come out, then we got a hammer and flat screw driver, and made it aim more up. Remember its shapped like a banana, so it needs to slide up and out. Then we got it aimed up enough, and pulled REAL hard came out but dropped it in the timing cover So we got a magnet that we extended in there timing case(didnt want to remove timing case to lazy i guess ) and got it, then we got a new key for few bucks from dealer and spend a few hundred on a new pulley. Now all is good. Also remember, when you go to torque the front crank bold do it to 140FT-LBS, yet everyone is going to say thats wrong, but in my mind its right, because Subaru Canada, Subaru Of America, and my Subaru dealer said 140ft-lbs, and i did it, and it DOES NOT strip the threads. At 70ft-lbs( as stated in the haynes manual i guess) it isnt enough, and the bolt loosens over time, and then your pulley wobbles, and the key way, and the key shreads, and everyone, including me gets angry. To torque it down to 140ft-lbs i let subaru do it, because i didnt feel safe, i torqued it to 100ft-lbs(thatts all i could do with a pulley holder(thing with belt that wraps around pulley) ) so the guy did it for free, and did it right infront off my, with no issues. This is my experience, good luck!
Is anything worth saving?
ericem replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh noo!!! if that broke, then? is that engine interference? Hopefully there is no internal damage, i wonder if doing a compression check on the pistons would determine whether the engine is worth your time, and/or the valves are bent. Wait do i see the crankcase cracked? or no lol, i dont know what im looking at.
Cheaper Shocks create more interior noise?
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTill it impossible to fix it? lol, im never going to sell it. Im to close to this car(meaning i have spent to much that its not worth selling.).
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXeverything is original except the strut(lol, ya didnt think, thinking about my rc car) Next time im ready to work on the car, new struts with bushings and new top hat, total rebuild will be done from and rear. Should i replace the springs as well? There is maybe a dot of rust on them.
Best wipers for my Outback?
ericem replied to rushsteve's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 basically any off the never ones are very good, ask long as there is no metal frame, that seem to freeze and cause streaking in the winter, the elastic type wipers seem to be the best.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXagreed, but i dont see tire manu/ recommended is.
1991 Legacy Turbo electrical
ericem replied to golfmasterii's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdefinitly.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIll run by what subaru recommends and that all, i think its 29 rear normal pulling, and 31-32 front? ill check it later.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh, because i went 4psi over the recommended, so ill try that out, thanks, i think ill go for OE struts, just because mine lasted SO long.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlol, i don't even know what im asking what im asking, is do cheaper struts create more noise, when you hit a bump, compared to OEM struts, and the GR2's. Oh, and i was wondering, should i go back to OEM struts? i can get them, but do the GR2's make the car more controllable and smooth, or are they the exact same, just OEM lasts longer. Why did i get my struts, because off my noobie mechanic, and me not searching up how much GR2's cost.
No RWD
ericem replied to quantum500's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthats the best thing to do, but they usually replace the entire casing, and everything, well atleast here they do for the same price converted, i should have did that instead of going to a dumass tranny shop with crappy MF's!
I was wondering if cheaper shocks make the car more louder when hitting bumps, because its pretty loud inside, like after i have my shocks changed(front ones) i notice a difference, but they were cheap ones, you think the KYRB(can't remember the name) shocks are good, overall like what i mean mostly is noise wise, and OEMness and mileage. And id being doing all the bushings, top hat, what ever around it, but im not sure if i should do the springs as well, and of course ill get alignment done. Thanks guys
Occasional ABS light(broken CV boot,grease?)
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh, well i think your right on the mark here, because this started now that its cold(-10?C) Should i give Subaru a shout, you think im covered?
ericem replied to golfmasterii's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou must have blown a whole lot of fuses, because i would think if the TCU werent gettings power you would need to shift manually, altough im not sure if it would work, but i guess it does.
Broken Nose 56k Beware
ericem replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit was a hot car man! to bad you its totalled by the way, you look EXACTLY like my cousin, if he were a little older, and if you had a italian background:-p Anyway, i dont think at 70mph you would have just lost it, you much have had a tire blow out, i can't see you just loosing it on a dry road, ive cornered at 90MPH once(please don't do this, very unsafe, but i was angry) and the car was very controllable even with the 14" steel rims, and no rear sway bar. :-\ I guess you should pick up another legacy JUST like that one, maybe just not turbo, and swap everything, and your good to go. However your probably a little dramatized now, don't worry it will wear off. Good luck.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh, well, wouldn't that be more in the lines off the battery if it can't hold its charge overnight? If im near a shop, ill get a load check done.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno, it does it when u turn on the car, not driving.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvoltage at idle, 14.10V highest 14.2V lowest 14.08V, alternator is giving 14.2V battery was at 14.08V, now im guessing this is a battery issue then. Right after you shut off the car, the battery goes to 13V right on, it might have been dropping a bit and caused that issue. I don't know, what do you think? Must be the battery right?
Untint the indicator light to clear?
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell ill definitly clean them before baking, does a heat gun work by any chance? I think i got the ok, because my mom and dad LOVE the clear look. YAY!! But ill probably mess it up, hopefully not
No RWD
ericem replied to quantum500's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell for 300 bucks can't be perfect, but i know everyone is going to say do a couple transmission oil changes, which ill say as well. OR get the AWD unit replaced,because i guess if the clutch wears down so much it can't engadge at all, also possible the drive solenoid can jam, its unlikey, but i guess it can happen. Another test i would do is jack it up while in the air and give it gas see if all four wheels turn. There is also a post around here to you can make the AWD run when you want it to, so check it out, if i find it illl add the link, so this way you can choose 4WD or FWD and if it works in 4wd, then i dont know:-p
Let's design a do-it-yourself DCCD!
ericem replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, lets find a scrapped WRX STi shouldnt be to hard to find? Then we will have our own STi right guys? Well i already know everyones subaru is a STi
Jump starting questions.
ericem replied to photo2001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi definitly wouldn't want the solar panel around my engine bay or front grill, i think your better off hotwiring the front or rear lighter.
ericem replied to photo2001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh yaa, your correct, how would you get around this? Anyway you can disable the alarm? unplug it something?
ericem replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpossibly its a simple system, maybe all we need is the TCU, and controller which adjusts the split between front and rear diffs. But then again the STi can do 40/60 so more rear wheel drive power. SOmeone with more experience is hiding some where
