ericem
Everything posted by ericem
  1. sounds to me like the relay is stuck, had the same problem, just directly go up to the abs and unplug it then replug it in, that usually fixes it, worked for me, that also explains why the abs light is on, because ur niece may have pulsed the brakes.
  2. i bought this stuff called plastix polish, works AMAZING looked 5x more clear and WAY more smooth.
  3. Im surprised he got a 300C SRT8 instead of keepping his 05 STi, why wouldn't he keep his subaru? maybe the memory.
  4. I hate it when i hear problems with BRAND NEW subaru's, seems so frequent now a days. Just let the dealer mess with it.
  5. i already have that The one im looking for is ontop like snowman just said, i just refer the look of it, and its much easier to clean, than dry cleaning the carpet, its a really good thing in the summer, because my mom likes her plants And i like my mud and snow in the winter :cool: i think when i got to subaru dealer they got a bunch, ill try them and see if any fit. Thanks guys.
  6. I have been looking for a cargo tray for a while for my 1993 Legacy Wagon but still did not find one for my particular year. Was there ever a accessory like this available? Thanks. https://www.subarugenuineparts.com/product_info.php?cPath=22_27&products_id=754
  7. yup its 5F its pretty dam cold in -15C. But getting the inside of the cabin up to temperature, could be better for sure, but once it gets up to temperature IT STAYS hot, and even with the fan at 1 and full hot it is boiling hot in the car. I usually leave it at 2-3 and turn down the temp after 10minutes.
  8. ok, im guessing bosch makes these sensor's so can i go to NAPA? because my dealer is crazy!! 150 PLUS 14 percent tax. Online its 50 bucks.
  9. Mine works up in less then a few minutes and its -15C.
  10. I just checked it and it is cracked, but no CEL, so what now? subaru told me 151CDN for the knock sensor and its in stock........ Should i go get it? I just checked this website and its $51US which is still ALOT cheaper then going to the dealer. https://www.subarugenuineparts.com/oe_parts_cat.html
  11. how difficult is it, to get at? And the o2 was replaced not to long ago.
  12. I torqued mine to 140FT-LBS with blue locktite, and has not come loose. Subaru told me to torque it to 140ft-lb's and they torqued it for me, because i didnt know if it was a good idea, but i watched the guy, and it worked.
  13. i guess your right, but im still filling up about 40 liters when i go fill up:confused:
  14. I know!!! mine is the same way, i dont understand, i only use 1/4 of the tank and did 156 KM then when i got fill up i only did 270km Im getting 350KM max before i fill up???? What is wrong here? It runs just fine, and my mom is the main driver, most of the time, and she drives well, you know how a women drives Pretty good but slow, but she doesn't have a steady foot u can say:rolleyes: Maybe the fuel indicator is dropping off, and i don't see it, because when i went downtown once(lots of traffice and 40km drive) i drove tehre with a empty tank and then came back still empty and made it home. Must be a fuel indicator problem. I know nipper suggested something you pour in the gas tank, to clean the sensor.
  15. try here https://www.subarugenuineparts.com/oe_parts_cat.html i had to get a entire assembly for my subaru and i let my dealer install it, working like a charm.
  16. I never forget And heres how it turned out, right headlight pictures were not cleaned with toothpaste, left side headlight with toothpaste 1 pic with flash 1 pic without flash, i don't know if u can see the difference though, i should have used my camera, not camera phone. This is another before pic, before i used the tooth paste with my camera from a while back. Hmm, ill take better pics when it gets warmer here its like -20C here
  17. I threw that tooth paste on with breath strips in it, and made a improvement, from clear, clearer Tommorow ill try again, ill buff it much harder and rinse instead of just wipe, then apply some cleaner. Ill take some pics of before(looked fairily clear) after(little more clear)
  18. yay!!! you must feel pretty good now, knowing that bad boy came out
  19. If it does fall off, you will still make it home, dont worry, just no AC or alternator, or power steering, but then its not worth driving
  20. deloreans just suck, i mean where do you get parts for them, heck the doors don't even close properly. SVX is better. No a Brat is better
  21. Well what if i get a TAD bit of binding on dry asphalt, but the rear wheels don't engadge? And my fluid is full, and red, not smelling burnt, and the the power light comes on for a moment then turns off checking normal and did a diagnois for the TCU and no codes, shows up normal, but when i checked previous codes, it said VSS #2. What do you think? And i never replaced VSS #2.
