Everything posted by ericem
Well i beleive the torque bind issue was solved as off pre 97 mid so dont need to worry about that, although the solenoid can still die. Do they both run very very well? And if they are the same price just 1 year apart maybe a legacy would be better just because its a larger vehicle. And make sure to go a carfax.com report on these vehicles to make sure theres nothing hidden. Also check the transmission to see if its low on oil or if its brown or smells burnt the oil, because i heard that if it goes low screws up clutches and if its burnt the clutchs got very hot and it burns the oil. Just little precautions. Make sure he has a history report on oil changes, check to see if the timing belt has been dont as well, and are we talking about a 2.2l engine or 2.5?
New to Subaru
ericem replied to a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Your clutchs for the AWD system seem to be ok if with the FWD fuse in theres no problem. This means the solenoid is alright, and the clutch packs arent melted. Definitly go for a trans oil change or flush. ANd with a used car its good to change all those things listed above timing belt, seals etc, oil changes for the transmission, diffs, engine. And things should be fine. -
Might be a loose valve which is simple to fix. My 93 leg had the same problem, so my dad's in the HVAC buisness, so he was able to get a hand off R12 refrigerant, and he used his leak detector and found no leaks except the valve, and now it has been 2-3 years and still freezing cold air. But ur going to need guages, the refrigerant and a leak detector is also good. You might be better off taking a trip to a dealer.
ouch...
ericem replied to photo2001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Ya does suck, some pics would be cool.
