Everything posted by ericem
Impreza for my daughter?
ericem replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell i beleive the torque bind issue was solved as off pre 97 mid so dont need to worry about that, although the solenoid can still die. Do they both run very very well? And if they are the same price just 1 year apart maybe a legacy would be better just because its a larger vehicle. And make sure to go a carfax.com report on these vehicles to make sure theres nothing hidden. Also check the transmission to see if its low on oil or if its brown or smells burnt the oil, because i heard that if it goes low screws up clutches and if its burnt the clutchs got very hot and it burns the oil. Just little precautions. Make sure he has a history report on oil changes, check to see if the timing belt has been dont as well, and are we talking about a 2.2l engine or 2.5?
Auto Transmission Slipping
ericem replied to Pooparu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlways giving the bad new eh?
Torque Bind Fixed!
ericem replied to smokey12's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYa that makes sence, but that would be in a straight line it would bind as well.
Seatbelt Problems on a 1990 Legacy Wagon LS
ericem replied to Uber Subar Man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust wondering , can we see pics of the damage, im just curious to see how only 1 door got hit.
Helllppp !!!!!!
ericem replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid u hurt him badly? I mean ur subaru is totalled. Well hmm. Must be scary.
New to Subaru
ericem replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour clutchs for the AWD system seem to be ok if with the FWD fuse in theres no problem. This means the solenoid is alright, and the clutch packs arent melted. Definitly go for a trans oil change or flush. ANd with a used car its good to change all those things listed above timing belt, seals etc, oil changes for the transmission, diffs, engine. And things should be fine.
A/C Not Working
ericem replied to Chiefzon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMight be a loose valve which is simple to fix. My 93 leg had the same problem, so my dad's in the HVAC buisness, so he was able to get a hand off R12 refrigerant, and he used his leak detector and found no leaks except the valve, and now it has been 2-3 years and still freezing cold air. But ur going to need guages, the refrigerant and a leak detector is also good. You might be better off taking a trip to a dealer.
197,000 miles- change ATF or not?
ericem replied to jjou812's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo to drain the fluid is it like oil change just no filter to change? I never acually inspected to see how u do the oil change. So is it a plug on the pan, and to refill just pour into the top off the tranny somewhere?
windsheild wiper bangs against post
ericem replied to bluebird's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI doubt its the nut for the wiper, i remember i had to do to the dealer and get bushing and a complete wiper rebuild, fixed it up good. Cost me like 300CDN.
Long term use of FWD
ericem replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI seem like a rear diff problem, nevermind the tranny.
Which engine mount do I need to replace?
ericem replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tryed that in my auto 93 leg in manual mode. I downshift early but it doesnt seem right.
2006 outback limited problems
ericem replied to tiw57's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI suggest u complain to the acual subaru subaru not the dealer then call them and say WTF!!
Help:Parking lights staying on when key off!
ericem replied to epike7915's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDont worry Eric. All eric's make mistakes. Im a Eric and i make mistakes lol.
ericem replied to epike7915's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe should make a sticky eh?
Vibration increasing during cornering and with higher speeds?
ericem replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMight be better for u not to drive the car at all, because you will kill your solenoid sooner, or is that overrated? And like nipper said definitly get a tranny flush.
New "turbo-Acura" Outback rip off!!!!!
ericem replied to williamhilow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYa Subaru Rule The World!! Ill Be Waiting!
ericem replied to tiw57's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is really wierd, could be a bad apple. Try different dealers. Maybe ur over reacting.
Subaru Overheating.....!! different guy
ericem replied to vt_tj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell arent u happy.
ericem replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell usually its for diagnostics when testing lets say a dyno test or reasons like this.
Oil leaking from differential vent???
ericem replied to akjruthies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYa my dealer told me the same thing, go point you made snow can get in there. But they told me barely anyhting will come out so i wouldnt worry about it for another 20,000km.
ouch...
ericem replied to photo2001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYa does suck, some pics would be cool.
Problems Shifting out of Park
ericem replied to Ddub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo u have a little override button infront like a button around the shift so u dont need to have the engine on or hit the brake to shift? Its not on the shifter itself its around the casing(well on my legacy).
The Great WHite Face Experiment
ericem replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSHH quiet man.
ericem replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh i see. i get it.
ericem replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust wondering u planning on doing 140mph? But i understand how much fun it is, usually sometime my dad would take it up to 125mph takes some time but it gets there and its super fun, however illegal. :burnout: good luck on your 140mph speedo.
