Everything posted by calebz
So, theoretically, why wouldn't a turbo on a carburator work?
Soo.. Just curious.. What do we do for the 21st century(thats where we are now)
86 gl-10 carrier bearing??
I think your best bet would be to go to a wrecking yard and just pull a complete driveshaft.. would probably be cheaper too
Anyone wanna guess what I got?
Yeah, I always thought it was cool that they named a car after STDs..
Leaking oil pump?
mine leaks from around the crank as well.. don't think that it is too uncommon
quick gauge Q
I personally use the illumination lead for my stereo when hooking up aftermarket guage lights..
lower springs ya got any
calebz replied to cammy 2001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck on the older generation board.. Look for DR RX. He had an 87 RX with the WRX 2.0. Can probably give you some pointers.
Engine Compatability for 84 subaru...
Its NOT a VW.. there is nothing even remotely VW that will interchange.. the only thing they have in common is that the engines are flat. Thank god it doesn't sound like a VW either. Your best bet for turbocharging is to find an original turbo car.. I believe turbone has an 84 or so turbo coupe for sale. Your next best bet would be to find a weber for it The EA81 motors are strong, reliable and fairly easy to find.. look around in the marketplace.. I'll bet you can find someone that has one for sale
Higher CR pistons in an EA82T engine?
Been done.. Look for WJM's car
The tiresome tire debte
Even If they didn't fit, you would still have all that fender room for flex when out on the trail with your smaller tires
convertibles
There were a few dealer installed convertibles made.. But as far as I know, they were all done on coupe bodies.. if you saw a hatch convertible somewhere, it was probably someone with a sawzall and too much time on their hands
check out this racing 360. only $20k !!
Old saab sonetts, 95 and 96 came with a 3 cyl- 2 stroke motor. theres a guy in oregon that ralleys the 3 cyl sonett.. But then again, he also has a sonnet with an EJ18(?) maybe EJ22.. can't remember which
Who is near Dallas, TX? ElectrycMonk?
Too Cool. OK city isn't too far away. That would be fun.
How's this for a deal?????
calebz replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInsurance companies/rental car places/dealers call the average yearly mileage 12-15k. Still, 20k per year isn't too bad. After all it is a subaru!
Looking To Buy
Check the marketplace. there have been a few for sale there lately.. AND PLEASE DON'T POST IN ALL CAPS!!!
Quick Fix for motorized seat belts???
If I remember right, the switch for the power seatbelts is part of the latching mechanism in the door.
salvaged WRX
calebz replied to doubleyouareex's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKeep checking ebay.. i see them there quite often
convertibles
It looked like a coupe whe I saw it at the yard
Anyone want to guess????
I'll bet its a subaru!
hello..
forgot about the autos.. was thinking about the pushbutton 4wd 5 spd.. oops
hello..
Originally posted by JonOfScio either AWD, or FWD FWD or 4wd.. never seen one that was AWD.. except maybe the turbos
EA82 Oil pump seal: Will this fix my noisy lifter?
That may very well do it..a gasket like that could cause your oil pump to suck air, causing the lifters to not pump up correctly. you might try the MMO treatment as well.. get some of the crud out.
Finally the liftkit is IN ! 1988 GL WGN
I found that instead of prying to achieve the proper angles, using a strategically placed jack to move stuff around was a lot easier. Steve and I did his 87 wagon in one day start to finish... quite feat considering neither of us had done it before
Are all 1983 GL's D/R ??
Uh oh.. Now he knows they have dual range.. he's seen the lift.. $5 says he'll be asking about 14 or 15 inch wheels next:grin:
EA82 engine and transmission swap?
I like my turbo motor.. its on its second car now.. been good to me. 160k or so.. its the only part of the car I really trust:rolleyes:
Fill me in...
OHC 1.8 in the looyale/FL type body is an EA82 EA71 is a 1600. pre 1980 or so
