Everything posted by calebz
EA82T high compression engine. Thoughts and opinions?
Manual says: Turbo: 7.7:1 Carb : 9.0:1 MPFI : 9.0:1 SPFI: 9.5:1
ARGH!!!!! bad oilpump + running EA82T = .....
If the manual is to be believed, MPFI and Carb are 9.0:1 and SPFI is 9.5:1 All EA82s have the bung for the knock sensor.
WARNING: Turbo Fitment
Its just a stock WRX uppipe. I was saving it for the next go-round, but now I'm not sure there will be one.
Galen, do you need a flange for a TD04?
Gen1 BRAT with WRX shifter!
How much of the WRX shifting mechanism did you use? Just the shifter rod? Linkage? Granted, I think it is too short for an EA81 car, but I think it might actually work for an EA82 and still leave a reasonable length shifter.
rx mods
The best mod you can do is the 'search function' mod.
Center Diff Lock
Yes, but unless he welds the center diff, it will break eventually. It wasn't designed to be the main drive gear.
BBS wheels! for OLD SCHOOL!
I saw those a few months ago, but couldn't find any info on the spacing. 136 sounds close enough to me, if one is creative enough to deal with it.
turbo 300zx injectors
Did you have the injectors cleaned/flowed? Chances are if they are old, they need some love.
Fail Safe Mode In Your Ecu
Not confused. Some carmakers (volvo comes to mind) refer to their O2 sensors as Lambda Sensors
Thoughts on alternator prob
Ding! Internal VR - easiest to just replace the alt.
1996 Subaru Leone?
Yup, FHI has been in and out of bed with Datsun/Nissan for decades. Ever wonder why our LSDs are such a good fit for the Datsun guys?
1996 Subaru Leone?
Looks like a Sambar, whic has been around in some form or other much longer than the brat.
EA82T XX=XX N/A subframe!!!
I've seen it a couple of times, but always with the xmember swap. BFH could knock the whole damn thing out of whack if applied too vigorously.
EA82 Head Gasket prices
Ever owned an old school turbo car? ..........Lcal dealer wanted $75 plus tax for a pair of OEM EA82 HGs Got them from 1stsubaruparts.com for 49/pr.. shipped
88 turbo just would not start,
Started after sitting.. That leads me to lean more toward whomever suggested the CAS. Been there.. Thats sucked. 2 weeks to diagnose. Ten minutes to replace the distributor:)
The saga of brownie
Given a choice between my 87 Turbowagon, My 05 Spactra5 and my 2001 Saab 95... My 4 year old daughter will pick the 87 Turbowagon every time. She likes working on it too:banana:
Is it turning over and not firing, or just not turning over at all?
Frustration has set in
True, it isn't necessary, but it tends to make life easier.
25 spline front axles.....where?
As was I. I reiterate Turbo manual and 4EAT - 25 spline All else - 23 spline Those are the DOJ side Axle spline counts. There are no 'squillion' options or combinations. As far as the outer/hub side goes, they are all the same. Of course, again, this applies to EA82
Nope - 23 spline. You need 25
Turbo manual and 4EAT = 25 spline All else = 23 spline (applicable to EA82 only)
Installed MX6 steering wheel, need help on wireing up cruise control.
That looks bad rump roast. When I get back to the house, I can check the FSM for the soob wiring. No idea about the mazda wiring though. I do know that I need a new steering wheel (mine is coming apart). And now I have another option BTW.. did you hook up all the airbag sensors?
PM'd
can't get it up!!
Aftert I replaced my clutch cable I had what sounds to be the same problem. On some models, there is a spring mounted under the clutch pedal. It is not there on all years or all models. As far as I can tell, it is unnecessary. It actually caused more problems in my wagon that it helped. A proper return spring up topside with be more than enough to deal with pedal return. This may not be relevant to your problem at all, burt you never know. Besides, it beats the hell out of replacing the pressure plate.
