Everything posted by TomRhere
Exhaust Y pipe- welded the Y part
This article may help you some in your calculations. http://www.jodel.com/index.asp?p=exhaust&engines
Clarification on Hyd lifter adjustment?
Yes, there is still pressure on the pushrod and related parts, but it is not, or shouldn't be, enough to overcome the valve spring tension which would cause valve to open. I started the engine after I did the adjustments, but before putting the rocker covers back on. Makes for a nice mess on the garage floor by the way. Did so, just to make sure I didn't have one to loose causing it to tick, or to tight causing a miss. This was the 1st time I ever had a rocker cover off an EA-81 engine. I had swapped heads, due to busting most of the intake bolts off while swapping intake manifolds. I jumped to the assumtion that because there were adjusting methods on both the old heads, and the new ones, that these were the solid lifter type. My bad.... Wasn't sure if this was original '84 engine, as one cover had the do not adjust sticker, the other one never had one on it that I could tell of, and it had two different bolts holding it onto engine. Lot of things help lead me to making the wrong dicision on what type lifters were in that engine.
Engine Locked
Welcome to the Board! Couple of things I can think of off-hand are; Coolant in cylinder, caused by bad Head Gasket. This will cause the engine to be Hydraulicly locked, as you can not compress a liquid. Pull spark plugs and attempt to turn engine by hand, watch for coolant from plug holes. If you see any, you've blown a HG, and it needs replaced. Thrown connecting rod. This is not good. Engine will need to be replaced. Thrown Timing Belt. Possibility, albeit extreme, of a T-Belt breaking and getting wrapped around the crank, and other parts there. Could have gotten wedged, locking engine. Pull the outer ends of the T-Belt covers, see if belts are still there. If one is missing off cam sprocket, you need to replace your T-belts. These are non-interferance engines, so no valve/piston damage if a belt breaks.
The "zero point", is also known as "zero lash", meaning there still should be some tension on the pushrods. If you can get your fingers on the push rod and try to spin it, it shouldn't turn after you get to the "zero point". Just went thru this myself on the '84 BRAT I had. Took me some doing to get them right, mainly due to me mucking it up the 1st go-round. Good lighting while your're adjusting them helps emensly, you can see movement of valve much better.
removing rust from chrome trim rings
If it's just surface rust, Turtle Wax will remove it, takes some elbow grease but it works. You want the liquid type, not the paste. If the rust is deep, you won't get it all without removing the Chrome in that area
!brake light out?
Few things come to mind that could be culprit here. Bad connection in bulb socket, Bad connection further back in wiring harness, which on the BRATs, there's a couple but I'm not real sure on yours. Bad/broken contacts in turnsignal switch, providing yours has same bulb filament for TS/Brake
Switching doors- anyone got instructions
If you're doing this by yourself, a floor-jack under the outer edge of door bottom is a great helper in both removing and installing. Don't want alot of pressure of jack on door edge, just want to help hold it up is all.
my wagon caught fire!!!!!!!!!!
That sucks!!! Big time... You just park it, or had it been sitting awhile?
I too have a mouse
I've had the pesky li'l varmits in 3 of the BRATs now. I used Murphy's Oil Soap to wash down everything but the carpet and seats. Gets rid of odor, and leaves a real nice almost new car smell behind.
Hmmm, going to have to up-date signiture soon
You got it!!! To quote a line from a ZZ Top song, "She might get out a nightstick, and hurt me real real bad, by the roadside in the dessert."
Seems my Subaru supply has grown some. Recently purchased an '86 2WD/5-spd Sedan from Miles Fox, $200.00. This is "parts car". Got an '88 2WD/Auto GL-10 Wagon from CIS Subaru, this is the one he did the CIS conversion on, (he has kept engine and CIS parts). Car was free, but I gave him $100.00 to tow it up here from his place. This be a "fixer-upper", and may very well be M-I-L's "new ride", if she really wants it after I'm finished fixing it. I'll be making a road trip to 86subaru's place this week-end to get the '86 BRAT I bought from him up here to my place. This will be Wife's "new ride", she has stated so. Also this week-end, I'll be taking the '84 BRAT (in my sig), down to 86subaru. I'll be trading it for the XT-6 he recently bought. The battle has not been decided on yet as to just "who's ride" this will be. Wife is claiming "hers", but I'm decreeing "mine". (we shall see how that pans out, after I get out of the hospital, if I survive the battle that is).
If I were to EFI a carb'd ea82, could I use a non soob EFI System?
http://www.fortunecity.com/silverstone/subaru/1/CIS/
exhaust backfire frustrations (update)
Went thru this meself when I ditched the cat on the '82. You need to block the steel pipes shown in your pic, either at the exhaust port/Y-pipe connection, or where they go into the piece shown in pic. Did mine at the exhaust port. GeneralDisorder often stated that a quarter would fit enough to block port, just put in in-front of tube, where it attaches to exaust port. I just cut the tube and welded in a section of a bolt that I had cut down, in the tube, close to fitting.
Anyone ever rig an O2 sensor on a carbed y-pipe?
Take the spare Y-pipe down to a local Muffler Shop. They can install O2 fitting for you.
picking up a '87 Brat Saturday..... pic added
Nice, me likes.......
trash4door? SILVER FOX II
Looking good! Gotta ask though, that the same one you've been up here with? Always been dark out when you get here, so never got a good look at what you were driving. BTW. Noah delivered the '88 GL-10 Wagon yesterday. Looks good. Sorry to say, but the Sedan I got from you, will be sacraficed to fix Wagon........... I'll pull and store engine for you...............
Turn signals and Emergency signals not flashing
If the front and rear TS bulbs are lit, it would point towards the flasher(s) being bad, (or missing). There's 2 flashers, 1 for TS, 1 for E-Flashers. And yes, they are "fun" to get to... Now, (some FYI here), if the rear TS bulb is blown, your front one and the dash indicator will light but not blink. If a front one blows, the rear and dash indicator will blink rapidly. This is only for the TS system. The E-F will/should blink regardless if a bulb is out. This is providing that the flasher unit(s) are good. You can use either flasher unit in either circuit. Putting an E-F unit on the TS will slow the blink rate slightly. Putting a TS unit on the E-F will speed up the blink rate. I usually use the heavy-duty E-F unit on both circuits. This will be benificial if you tow a trailer, as the TS bulbs on the trailer will change the blink rate due to added load on circuit. School is out now.......
engine puter
Carb + 'puter = Feed-back carb on engine. California models were that way, along with some others. Should have/had O2 sensor on Y-pipe. Not sure what the all 'puter controls on these things, so I can't help you much there. Honestly didn't think one would run without 'puter hooked up though. Hey, if it works that way, why worry!! Could be that the 'puter went FUBAR on you. Not sure if it would swap in, but the '82 had one in it, I don't need it anymore. Yours if it'll work.... Anyone got input on that?
Newbie, any tips?
Just wanted to say, Welcome to the Board! We used to live in Midway, '91-'94. Wife has Family there. And yes, these are awesome vehicles, I'm hooked along with the Wife.
No lights.... HELP!!!!!!
Would also check the connections under the fuseable links. Lost headlights on my old '86 BRAT, found wire broken/corroded off under link box.
Won't Run
It's possible that the Driverside Timing belt has jumped. Follow the steps in the Haynes manual for doing the T-belts to check this. The instructions there are good, but slightly mis-leading as it shows both cam marks at the top, when actually one side will be up, the other side will be down. Doesn't really matter which one is up, as long as other side is down, when you have the crank lined up with the T-belt timing indicator lines.
temp gauge or overheating
My 1st thoughts on this would be defective T-stat, as the radiator was cool, hoses warmish, and engine hot. In my book, that means bad T-stat.
Help me find my tinker-bell!
The '86 BRAT I had would lose the dinger on occasion. I would also find that the horn wouldn't work, along with the dome light. Can see the relation between dinger and dome light, but not the horn. Don't have any wiring info here to go by, but I'd like to know the answer to this one myself. The '84 don't ding most of the time, and the dome light has never come on when I open the door, works by switch though.
guys with er27s?
Trying to remember how the XT-6 was set up, been over a year since I pulled the ER-27 out. Do believe, that there was an upper one on the top engine/tranny bolts. If nothing else, just do a custom fabbed mount for one. Hmmmm, maybe I'll just fab the front one into my design instead. I'll be putting a Bash-plate on the front to help protect the engine and other vitals located there. So I'll have something in the area to mount it to anyways.
still having cooling problems... im stumped
Not wanting to cause you anymore agravation here. But the exhaust fumes burning your eyes, is a good sign of a bad vacuum modulator on the tranny. Means you're burning tranny fluid. Quick check on that is to pull vacuum line off of modulator at the tranny end. If ATF comes out, it be bad. You may have some trapped air in the cooling system still. That may be the cause of the coolant wanting to "push-out" of the radiator.
