Park light Fuse Keeps Blowing
Legacy777 replied to scam22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLike I said, you've got a short some where. If the dimmer switch keeps things from blowing, then the switch may be shorting out, or one of the interior illumination wires or bulbs could be shorting out. Either way, you need to have it fixed, and fixed properly. Electrical shorts are not something to take lightly as they could burn your car to the ground.
Stumble, 1998 Forester S
Legacy777 replied to Randall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, only after the car would sit overnight or for extended period of time...AND....if you just put the car in gear and kept your foot on the brake, and didn't touch the gas pedal.....it wouldn't do it. I say that because I brought it to the dealer and they just started it up and did what I said, and it never reproduced the problem. Once you touched the gas pedal is when it would stumble, and then it'd be fine. I really don't know what the issue was. So on yours, do you get the problem when the car is "warm" as well? My car was originally FWD AT & normally aspirated. It's not AWD, MT, & has a turbo legacy engine. So way too much stuff has changed....however I have supspicions it might have been auto transmission related.
2005 Forester Lurching Problem
Legacy777 replied to Lesley's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwelcome
115MPH fuel cut and 92 Legacy wagon
Legacy777 replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, mines probably 5mph off or so at least due to tire size differences. There's a shop in the seattle area that can make adapters to correct speedometers, even mechanical. So if my speed is off a certain amount after I change my tire size, I should be able to have it corrected.
94 Legacy- Sputtering, rough idle, bogging on highway
Legacy777 replied to TROGDOR!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith the car running, pull each spark plug wire and see if the engine dies or idle changes. These engines use a wasted spark ignition system, so if one side of the coil is dead that means two cylinders are going to be dead.
Legacy777 replied to Randall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you let the car warm up or just drive off? I had similar issues. If I let the engine warm up, it wouldn't do it. You may want to try changing brands of gas. I never found out what was causing it....it eventually went away or went away when I did all my swaps.
Windshield Washer question
Legacy777 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust go to a junkyard and buy a tank for 5 bucks or something. It should have the motor with it.
Legacy777 replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst gen's have no sort of speed limiter other then drag I topped mine out, when it was fwd & at at around 130...or that's what the speedo said.
Legacy777 replied to scam22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like you have a short somewhere. It could be the bulbs, wiring, or possibly the switch. Does the fuse blow when the switch is off, or just when you turn the switch to turn the parking lights on?
Re: Please help the new guys out
Legacy777 replied to broke subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend searching on here for head gasket issues, you will find numerous threads with similar issues. That may help you in deciding what you want to do.
99 Legacy GT problems
Legacy777 replied to kushwa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe starting issues could be explained by a bad coolant temp sensor. You may want to replace it. It's only like 20 bucks.
check engine light- need advice
Legacy777 replied to saranham's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee what the dealer says. I'm not overly familar with that code, but it sounds like either the air pump for the emissions stuff, or the idle air control valve. Find out which one or what it is, and go from there.
90 legacy wagon to 91 sedan interchange , also free hulk near Olympia WA
you are correct actually the whole front end changed, hood, fenders, lights, etc
Late 90's Legacy Question
As for how many manuals there are....couldn't tell you. But a lot of the mods are interchangable between the impreza & legacy.
'95 Legacy rear rotors
Legacy777 replied to SeanC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad you got it squared away.
93 Legacy Wagon driveshaft center bearing
Legacy777 replied to ekmissal98SUS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think you can replace just the bearing. I've actually got a 91 driveshaft sitting in my garage if you still need one.
'03 Question
Legacy777 replied to Spacinjason's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Legacy777 replied to Lesley's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat you describe sounds normal because of the high idle. Chances are if you let the car warm up, so the idle returns to where it should be, you won't notice it. As for the lugging thing. How many miles do you have on the car? Have you checked the trans fluid?
Threebond 1215 equivalent?
Legacy777 replied to craigusoz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfor future reference http://www.main.experiencetherave.com:8080/subaru/techinfo/subaru_sealants.gif
EJ20 (Legacy 2L non turbo EFI) spluttering
Legacy777 replied to habib99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo you actually get flames out of the tail pipe? Have you modified the exhaust/removed the catalytic converter? I'd say you're probably running REALLY rich for flames to come out. As for why....I couldn't tell you without some more info. You may also want to post on www.bbs.legacycentral.org
Anyone tried these?
Legacy777 replied to dlc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey will alter the beam pattern to where they will blind on-coming vehicles. The filament placement (hot spot on HID, since they don't have a filament) is not the same between HID's & halogen bulbs. This completely changes the optics of the headlight.
hi eweryone
Legacy777 replied to oskar_subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board Oskar. Check out the offroad forum about lifting your legacy. You can check out my write up on a trans swap www.surrealmirage.com/subaru/swap You may also want to check out www.bbs.legacycentral.org
90 legacy xmsn question. Trans x any good?
Legacy777 replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't heard anything about the trans x stuff. However if your trans is really on its way out.....no amount of additives will help.
cough/stumble 99 GT
Legacy777 replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the bosch plugs with ngk copper plugs. Subarus don't like bosch plugs as much.
dashboard r&r
Legacy777 replied to johnceggleston's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo get the dash out, you'll have to remove the misc parts in the dash, and then take the rest out as a whole. To swap carpet, you have to remove the seats and all the inner guts. It's not too bad. I had mine out when I rewired my stereo http://www.main.experiencetherave.com:8080/subaru/images/stereorewire/
