8
Need Help
Legacy777 replied to Steph's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You may want to check out http://www.subaru-svx.net/forum/ -
heater problems
Legacy777 replied to ACE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
http://www.bbs.legacycentral.org/viewtopic.php?t=1142 -
door trim
Hmm So is the rubber freezing and sticking to the door, and then the clips pulling out of the rubber? Try spraying a silicone lubricant on a rag and wiping the rubber down. -
Is your check engine light on? You may want to try pulling the codes to see if anything is stored in the computer. I have the procedure for pulling the codes on the legacy, but they should be the same for your 93 www.surrealmirage.com/subaru/engine.html Also, can you describe the problem better. Does it happen all the time, does it only happen when the engine is warm, etc.
Some are. The later coils from about 97 or maybe newer had the ignitor integrated into the coil pack. Those are not interchangable with the coil packs that did not have the ignitor integrated. The coil packs without the ignitor had female spark plug connections. The coil packs with the igntior integrated had male spark plug connections.
door trim
Probably not... You are talking about the weatherstripping right? Where is it pulling out? Is the rubber pulling out of the plastic clips, or are the plastic clips coming out the door? -
If the wire is intact, I would wrap each wire with electrical tape very well, and then wrap the wires together in electrical tape. If the wires aren't in good shape, you should splice in new wire. You may even want to put wiring loom around the wires I'd also wrap the wires going to the pump....the ones in the pic you sent me. Josh
I'm not sure if the newer ones are like the older legacies. But the older legacies had a pig tail that came off the radio. The connector was under the carpet right around the area where the driver's feet were and the transmission tunnel. I know there's people on here with the newer models, so hopefully they'll chime in.
I think you may be a little confused. The PP can read boost pressure, I'm doing that. It also has an optional output to control an extra injector. You can use this output to control the stock boost controller solenoid. However you have to program in all the PWM settings yourself. I'm sure with some time and tweaking, you could get it right, but for me right now, I'm not messing with it. Plus it'll probably give you a CEL.
Yes there is differences. For example, the engine electrical harness for the 90-91 n/a legacies use 3 square connectors. The 92-94 n/a legacies use 2 square connectors, while the 91-94 turbo legacies use two square connectors and one round connector.
