Legacy777
Moderator
    8
  1. Yeah I think there's a couple more along 99 in that area. It's been a while since I lived up there, but there were a couple in the south end of Everett too.
  2. This thread has some info regarding chains. http://www.ultimatesubaru.org/forum/showthread.php?t=47740
  3. The newer ones "should" work. Only thing you'll need to verify is the final drive ratio. You need to find one that has the same final drive ratio as your 96. If not, you'll need to swap out the rear diff to match the final drive ratio in the transmission.
  4. In 2000 subaru switched to a MAP based setup. http://www.cobbtuning.com/tech/airflow/ I would personally try and find a 99 ECU so you can use the existing car wiring setup for the MAF system.
  5. The info I have says the 95 AWD has a 3.90 final drive ratio. I would "guess" the 94 is the same. However you may want to confirm that on NASIOC. There's bound to be people that know.
  6. This thread has some info http://www.ultimatesubaru.org/forum/showthread.php?t=46240&highlight=chains%2A+tribeca
  7. I guess I'm confused as to what you're doing? The car that you are swapping the engine into, is it MAF or MAP based? Does it have all the wiring and associated parts with it? The engine you have, is it MAF or MAP based? It shouldn't matter....just swap over all the sensors and that jazz from your old engine.
  8. Are you looking for a size that will raise ground clearance, or just want a taller tire? May want to paruse www.bbs.legacycentral.org as well.
  9. Cory, I don't think the long block really cares whether it has a MAP or MAF. Just hook all the stuff up from your engine, sensors, intake, etc and let 'er rip.
  10. I would check all the fuses first. Not sure how they would all be related....other then possibly fuses.
  11. I wouldn't say it'd trash your front gears. It just won't provide as much protection. The main difference between GL4 & GL5 is the EP (extreme pressure) additives. GL4 has EP additives.....GL5 just has more.
  12. I'd recommend replacing the shifter bushings. Kartboy makes replacement bushings that really help the feel of the stock shifter. They also sell short shifters. However the bushings are what help improve the precisiveness of the shifter here's the site www.kartboy.com
  13. What year & model subaru do you have? Any more details on the problems.....is it just not working?
  14. I'd suggest searching over on NASIOC http://forums.nasioc.com/forums on what some of the guys are using over there. There's A LOT more WRX owners over there.
  15. I've got a scratch in my driver's side mirror. If I were to replace it with a redi-cut mirror, does the plastic housing need to be removed, or can you remove the mirror itself without removing the plastic housing or guts?
  16. Just to note, I put fresh coolant in when I finished my motor, and drained it after like 10 miles of driving.....there were particles in the coolant.....coolant's cheap, just put new stuff back in. But if you don't want to, yeah collect it in a clean container and dump it back in.
  17. I'm assuming you have a manual transmission. The switch is along the side of the transmission. You can see a diagram here http://www.surrealmirage.com/subaru/files/swap/elect_unit_loc/6-3_electrical_unit_location07.jpg You can see them here http://www.surrealmirage.com/subaru/images/swap/14/DCP_3338.JPG
  18. There are several threads dealing with this. Please try and search. Basically, you need to match the rear diff ratio with the front. Other then that, most newer non-vtd type subaru transmissions should work
  19. Electrical device for rust proofiing? Can you provide any info on this device? Rectifiers and sacrificial anodes are used for underground pipelines, but I don't see how that would work for a car.......
  20. Try and pull the codes from the ECU. See what comes up www.surrealmirage.com/subaru/engine.html
  21. Yeah I'd agree the first gen 90-94 legacies were some of the best built cars subaru made. As for differences between the 90 & 92 model years.....and is it worth the extra cost.....probably not. In the states, about the only I'd prefer on the 92-94 model years is the headlights. But overseas should have gotten the better headlights on the 90-91 MY's. If you're looking for specifics on the first gen legacies, you can check out www.bbs.legacycentral.org Tons of info there.
  22. They should be. The info I have says the digit that changes indicates the year it came out of. For the first gen legacies 1 was the first year, indicated 1990. In 95 when the 2nd gen came out, A probably indicated the first year 1995, B would probably indicate 1996....etc. So assuming Subaru kept the same decoding scheme, and they didn't change anything between the 95 & 96 MY's, the tranny's should be interchangable.
  23. Remove the glove box. It's two screws and when you do that, you'll be staring at the connector for the resistor pack. It's the thing in this pic. http://www.main.experiencetherave.com:8080/subaru/images/accomp/DCP_2945.JPG remove the connector, and two screws. Pull it out and swap it for another one.
