2000 Impreza A/C Recharging
Legacy777 replied to kgturner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe low pressure valve should be on the ac line coming around the back of the firewall. You should be able to buy one of those recharge cans and check the pressure the system is making, and add anything if needed.
Exhaust leak on '90 Legacy
Legacy777 replied to Zack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat guy doesn't know what he's talking about. Basically, all they would need to do is cut the bolts off with a torch or grinder. If they can't get enough room to replace the doughnut gasket, they can remove the bolts that hold the mid pipe to the muffler section, or cut them off. They can then remove the mid pipe to get enough room to put the gaskets in. All you would need new is the bolts that they cut off.
Speed Sensor 2
Legacy777 replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey Dan, It's very possible the speed sensor could have caused the duty c solenoid code. What symptoms/problems are you getting? Or just that those codes are displayed? If you're not having any problems, I'd just clear the codes, pull the egi/tcu fuse, and just keep an eye on things.
Legacy dies, intermittent fault
Legacy777 replied to Mat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if the test connecters being connected would cause your problems, but it's possible about the alarm wiring being ripped out poorly might be causing your problems.
Help car stalls
Legacy777 replied to skybren's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I'd lean towards the MAF sensor. I had very similar issues. Turned out to be the MAF.
Engine running....well, no MPGs!
Legacy777 replied to WJM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, sounds like you don't have a tstat or you have an aftermarket one that causes hell with things. Replace it with an OEM one and you should be good to go.
Legacy777 replied to Mat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnfortunately, diagnosing something like this is rather difficult. I'm not sure where I'd start with things. Have you pulled the plugs to see what they look like? It sounds electrical. What about coil pack or the ignitor....or possibly even the ECU.
I'm back...with another question
Legacy777 replied to Linda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNext time you're feeling the surge, pop the shift lever into neutral and see if it goes away. If it does, it could be transmission related. If it doesn't go away, then I'm not sure what it is....might just be not as good brakes.
Injector duty cycle
Legacy777 replied to scoobdude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn whatever injector you use or size, you should really not exceed 80% duty cylce.
fuel delivery issues SVX
Legacy777 replied to benebob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the SVX have a variable voltage pump? I know the legacies of that era just have a single voltage pump, and only have a fuel pump relay. If your setup was the same the legacy, I'd look at the ECU or possible the ignition switch being the culprit. Here's the wiring diagram for engine electrical, and you can see the fuel pump there http://www.surrealmirage.com/subaru/files/swap/6-3_engine_electrical1.jpg The factory manuals should have all the info you need. Not sure if you have them electronically or not. If so, I don't mind taking a look at things to help in troubleshooting.
2.5l into early legacy?
Legacy777 replied to mattyg41383's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJason Grahn over on www.bbs.legacycentral.com did it. Do a search over on the bbs, and you should be able to find info on it.
Wiring Diagram for 93 legacy
Legacy777 replied to almistical's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Legacyradiodiag.jpg
92 legacy running rough??
Legacy777 replied to Thornvarg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could have a poor running pump, or the pump sock could be plugged. You can get at the pump via an access panel in the trunk I've heard good things about smart service
Need Help Stylizing
Legacy777 replied to squirrel8686's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExcuse me? I said nothing about my car in this thread, and I don't recall bragging about my car in general. Regardless, you will treat ALL members with respect, which includes moderators and administrators. If you can not or refuse to do this, you will be removed!
How do you identify which car an ECU/ECM came from?
Legacy777 replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is the full subaru part # 22611AD57A You should be able to give that number to the dealer or Jamie, and they'll be able to tell you where it came from.
Torque Converter Hell
Legacy777 replied to BoostedBalls's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlet us know what you find out. I want a plasma cutter
AC and Fan?
Legacy777 replied to David C's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you talking about the blower fan for the ventilation system or the radiator fan? And can you be more specific on how it's not working.....
03 outback sport dash light
Legacy777 replied to rizzo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou would need to pull the switch out, and replace the bulb inside. You can buy bulbs that fit at radio shack. I don't recall the part # off the top of my head though.
2000 Legacy L Wagon Trasmission Failure!!
Legacy777 replied to RJC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease only post in the appropriate forum.
LSD on a Legacy!?
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe the newer RS's might have had VLSD's in the rear and 4.111 final drive ratio.....but none of the older legacies did.
LSD on a Legacy!?
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou don't need to run any additive in the fluid, in fact, running an additive will do absolutely nothing because the Limited slip portion uses a sealed viscous coupling, just like the center diff.
starting problem w/ 90 legacy
Legacy777 replied to pirata's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.surrealmirage.com/subaru/engine.html
'90 Legacy EJ22 Head Gasket Swap In Car
Legacy777 replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the engine seized due to overheating....I wouldn't even bother with it. It's possible just replacing a head gasket would fix things, but there's no telling what other stuff got warped. At the worst, you'd need a new engine. If you don't mind that option, and price is right, go for it.
LSD on a Legacy!?
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt'll look like this http://main.experiencetherave.com:8080/subaru/images/trannyswapparts/DCP_3009.JPG
Need info on repair
Legacy777 replied to drquasievil's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd say contacts too....except for the fact he said it grinds......
