Throttle plate not opening 100%
Legacy777 replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo you had someone push the throttle all the way, and you could still turn the throttle plate by hand to its fully opened position? I think there's a cable adjustment, that's what needs to be adjusted. If it can't be adjusted properly, you'll need to purchase a new throttle cable.
any clues why blinking check engine light?
Legacy777 replied to turbo92subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe black connector is the ECU check connector. When it's connected The check engine light will blink with the codes stored in the ECU, or if no codes are present, it will flash in a steady interval.
Legacy777 replied to turbo92subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do you know the AWD is not working?
GT rotors on '03 Legacy SE?
If you want increased longevity out of rotors, get them croyo-treated. I've been extremely happy with mine.
1993 Legacy Engine cut out
Legacy777 replied to duallegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXehh, I don't see any reason why an aftermarket belt wouldn't work.
Legacy777 replied to duallegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe first gen legacies had non-interference engines, so you should be good to go by just slapping a new t-belt on. Only other things I'd look at are the oil seals, possibly replacing the water pump, and resealing the oil pump (depending on when the last time they were done). You may want to check the timing belt tensioner as well. See if it's leaking or anything out of the normal. The belt's failure could possible be due to the tensioner not providing enough force to keep the belt tight.
Big thing with brakes is what type of environment do you plan to use the car in.....that will help you in determining how much you want to spend. My personal advice, for a street driven car that you just want some extra braking capability, put better pads on. It's relatively inexpensive, and can really improve stopping capability over stock pads. Here's the spreadsheet I did that jamal was talking about. http://www.main.experiencetherave.com:8080/subaru/techinfo/brakemath.xls
A/C thermo switch question
Legacy777 replied to ndsnewleg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure it's not a charge issue, rather then the switch issue?
Vehicle Speed Sensor Location?
Legacy777 replied to SilverSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know for sure whether the 96 has an electronic or cable driven speedo. But check around the area where the front differential dipstick is. On the cable driven speedos, there's a base piece that fails, and causes the speedo not to work. The VSS2, which gives you your speed in the dash and to the ECU is typically driven from the front differential.
O2 Sensor and Catalytic converter
Legacy777 replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI suppose it's possible if the front O2 sensor was out, and the car was running very rich for a long time, that you might cause premature wear of the catalyst. Having the rear one go out, and not replacing it, isn't as big a deal.
More then likely you can probably just get the bracket that holds the caliper. This will move the mounting position of the caliper further out, so it accepts the larger rotor. People with the 2001 RS's will do this very thing to fit WRX front brakes on. Buy the larger rotor and the caliper bracket.
Legacy A/C conversion - R12 to R134a
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Ed. I think the only thing I would probably do different is use PAG oil instead of esther. I've had one compressor go out on me. I don't know if it was just coincidence.......and the compressor I have in now is knocking. I don't know if it's due to the fact esther oil doesn't lubricate as well as PAG oil, or the fact that the guy who pulled a vacuum on the system, didn't do it long enough. I might just be having bad luck with used compressors. I've got my own set of gauges and vacuum pump, so I know it'll be done right the next time. I'm probably going to swap out the compressor when I do my motor swap some time this summer. That or when the current compressor craps out, I'll swap it out.
new subie question
Legacy777 replied to 81wagoon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXselectable 4x4? All the newer subaru's had full time awd. Anyway, the imprezas a pretty good car, a little more base model then the legacy, but a good car still.
95 legacy knocking suspension
Legacy777 replied to twofullas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you provide any more details....which wheel? anything?
Legacy777 replied to SilverSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have an auto or manual tranny?
questions about a 92 legacy sport
Legacy777 replied to ToTalXS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think 3500 is good if it's in good condition. If it's moderate condition, I probably wouldn't pay more then 3k at the most. Check out www.bbs.legacycentral.org for tons of info about the turbo legacy.
aftermarket ignition
What model subaru do you have? All the "newer" subarus either have a distributeless or coil on plug ignition system. For the distributeless ignitions you can use the MSD Dis 2 ignition system. For the coil on plug ignitions, you really can't do anything. The rev limiter option is there, however you can't increase the rev limit because the ECU has its own rev limiter. You'd have to bypass it first.
'95 Legacy A/C ???
Legacy777 replied to Handtool's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen's the last time you've used the A/C? Did it work fine then? From what you described it sounds like the system is either under or over charged. It'd probably be worth taking it to a shop for an a/c diagnostic.
99 Subaru RS/2.5/5 spd question
Legacy777 replied to rkkepner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo it doesn't have to come from a 2.5. Any 4.111 tranny with a "push" style clutch will work.
Noisy 22T-new oil pump or just reseal???
Legacy777 replied to XSNRG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can remove the oil pump, replace the o-ring and reseal it. You can also remove the backing plate and check that the clearences between the rotors are within spec.If that is good.....you probably need to replace the lifters. They may have been gummed up due to infrequent oil changes.
Legacy to OB Engine Swap
Legacy777 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt'll bolt up.....the electronics however is a little more difficult.
94 GX 2.2. Touring Wagon Cruise Control
Legacy777 replied to knijn2007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXApparently from what Craig said, Subaru did make a kit to add cruise. I couldn't tell you whether the same kit is available in Holland, but it'd be worth asking your local subaru dealer if something similar is still available for your car.
Legacy777 replied to rkkepner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe RS may have a hydraulic clutch setup, but the clutch design is the same. Any push type clutch setup can be interchanged between cable & hydraulic.
Legacy777 replied to duallegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck for engine codes, as well as running the active diagnostic.....see if you get any response from the ECU. Whether the CEL blinks should give you indication whether the ECU is still functioning the procedure to get codes is on my site under the notes & tips section.
Auto to Manual swap
Legacy777 replied to NoahDL88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.surrealmirage.com/subaru/swap http://legacycentral.org/library/transmission/convert.htm Granted they're not a 96 OBS, but that should give you an idea of the amount of work.
