1999 forester namual trans.- changing the "low" ratio???
Legacy777 replied to pinister's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat exactly do you want to do? Does the overseas foresters come with a dual range 4WD transmission? Is that what you're talking about by changing the low range?
AWD 5mt question
Legacy777 replied to XSNRG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah i think the center diff is the same.
Check Engine Light (Code P0172) - what could cause it?
Legacy777 replied to Adnan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMight just have been a hiccup in the fuel injection system. I'd just watch it, and see if it happens again.
92 FWD Legacy, which Differ. dipstick???
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe yellow one is typically the atf dipstick. My 90 FWD auto had a black handled dipstick for the differential. It's possible in 92 they changed the coloring and stuff.
where can I look up parts interchange?
Legacy777 replied to kidwired's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChris, There is a parts book that subaru uses. I picked up an old one on ebay a couple years ago. It's very handy, however I don't know of any manuals on cd. What parts are you wondering about interchangability?
Legacy prices across the USA, any opinions?
Legacy777 replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt really depends on your locale. Down here, you wouldn't get more then $2000 for it. Up in your neck of the woods, probably $3000 or tad more....again, this depends on the condition, and locale.
Question on codes
Legacy777 replied to beezer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSince replacing the coolant temp sensor.....have you had the other two codes come back? It's possible they could have been erroneous codes caused by the engine running lean/rich.
Air Suspension 94 Legacy Ls... Am I Crazy?
Legacy777 replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd highly recommend just replacing the suspension. You're not going to get a huge jump in height or anything....it's far from being an "off-road" type air suspension that you can get more height. If you really want more height, get a set of outback struts and springs, and install them. If you want to spend any money on trying to fix the system. Have the shop run the diag. procedure for the air suspension. Here's what they need to do, and the codes. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AirSuspension_diag1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AirSuspension_diag2.jpg If they find something simple, fix it......if it's going to be several thousand dollars to fix....just swap to a conventional suspension.
Need some brake parts
Legacy777 replied to quailman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour subaru dealer, or any subaru dealer should be able to get rebuild kits.
Engine Problems in 1991 Legacy 2.2L
Legacy777 replied to DeanB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's six screws. Did you get all six? If you did, just work at it a little more, it'll come off.
1990 Legacy 2.2L Engine Vibrations
Legacy777 replied to SuzzySubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo to my site, notes & tips, engine related, and pull the ECU codes. If the cel comes on, a code will be stored, and you can read it yourself.
Legacy777 replied to DeanB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you pulled the engine codes to see what is causing the check engine light?
Front brakes issue on 2005 Legacy GT
Legacy777 replied to silvergt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe brakes were more then likely not bed in properly. What happens is pad material is unevenly distributed on the rotor, and when you heat up the brakes good, the coefficient of friction is different between the pad material on the rotor and the rotor itself, so you get the shudder you're experiencing. I'm assuming your GT doesn't have too many miles on it, so I doubt it's a "warped" rotor. To properly bed brake pads, you need to do about 10 consecutive 60-10 mph stops by applying firm/medium brake pressure. You don't want to jam on the brakes, but you don't want to do light stops either. Drive around for 15 minutes to let the brakes cool, (during this time, try not to leave the brakes applied for an extended period of time, like at a traffic light. This is a contributor to uneven brake pad deposits.). After that 15 minutes of cool down, repeat the 10 consecutive stops, and cool down.
95 2.2l legacy sedan making high pitched whistling noise
Legacy777 replied to BulletRide's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's gotta be something related to the drivetrain. You could try putting the car on jacks and rotating the wheels by hand to see if you can hear anything weird.
Valve JOB
Legacy777 replied to tfarm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.seafoamsales.com
I Need Expert Advice
Legacy777 replied to SubyZoom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're looking for just a direct swap "plug n play" type thing.....the engine should probably be from a 90-94 legacy. Depending on MT or AT, that will have some effect on what is plug n play vs a little swapping of sensors, etc. Tranny...depending on mt/at, will determine what will work, and what won't.
Legacy777 replied to BulletRide's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat condition is the muffler/exhaust in? I had a whistle, which I swore was coming from the engine. I was in the car revving, and had someone stand outside to listen where it was coming from, and sure enough it was the muffler.
92 legacy lack power hard start worse cold
Legacy777 replied to 05mustang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm. So it's worse when it's cold? Might be the coolant temp sensor, but the symptoms your experiencing are pretty severe for the coolant temp sensor. It's a $20 item though, so it might be worth the money to eliminate it. Have you tried running d-check mode? It's a more "active" diagnostic method. Instructions are on my site. other possibility is that the ECU is not working properly.
Online subaru wrecking yards
Legacy777 replied to Kidcapri73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can try these guys http://www.4subarusuzukikiaparts.com/ http://www.superrupair.com/
Valve JOB
Legacy777 replied to tfarm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year & model subie do you have?
HELP! Crank Sensor Issue 94 Legacy
Legacy777 replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpersonally....I wouldn't pay for the part unless they gave me the old one back. Did you tell them you wanted the part back before they worked on it?
How much does a 2.2 EJ22 weigh?
Legacy777 replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWeight of my motor with a bunch of boxes was like 400 lbs. There was around 100 lbs worth of other boxes on the pallet......only saying what I've seen....
EJ22 doesn't want to start when cold.
Legacy777 replied to schspeedster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe coolant temp sensors can be out of whack and not have the CEL come on.....it's a $20 item.....replace.....I bet it'll fix your problem.
Legacy777 replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpost the part # when you find it out. More then likely the sensor they tried to get in was the wrong sensor.
Legacy777 replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy bad....the weight I gave was more for the ej22t motor, since that is what I just had shipped to me.
