Fwd
Legacy777 replied to freakus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah you should be able to convert over to AWD relatively easily. You will need a new tranny, but all the wiring "should" be there.
EJ22 doesn't want to start when cold.
Legacy777 replied to schspeedster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXprobably is the coolant temp sensor.
How much does a 2.2 EJ22 weigh?
Legacy777 replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt'll probably be around 300 or just a little less.
95 Legacy Auto Trans Shifting Problem
Legacy777 replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour car doesn't have an overdrive per-say. it is a four speed transmission. Fourth gear is overdrive. What you're feeling is probably the torque converter locking or un locking. Have you checked your trans fluid level?
90 legacy transmission dead
Legacy777 replied to biscuitb32's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah...check your fluid.....does it smell burnt? What color is it? More then likely your tranny is in need of some service if the fluid looks ok and is at the correct level.
HELP! Crank Sensor Issue 94 Legacy
Legacy777 replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsensor is exactly the same. It might have just been seized in the hole. Or if they were banging the old one out, they might not have gotten the outer shell removed.
ej22 engine pulley problem
Legacy777 replied to Soobarooboo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah fsm states 65 ft/lbs. You need at least 110 ft/lbs.
Legacy777 replied to sregor13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSensor is the same. If he drilled too far, he could have damaged the crank gear. It can be replaced, but you have to take the timing belt covers & belt off. Here's some pics to show what I'm talking about http://www.main.experiencetherave.com:8080/subaru/images/timingbelt
trans "hunts "in drive 90Legacy
Legacy777 replied to jozh7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes the trans is electronically controlled. I'd make sure that all the connections are secure for the electrical connectors. Is the check engine or power light on or blinking? You may want to reset the ECU & TCU. maybe something got changed when they had the motor out. Instructions for resetting can be found on my site under the notes & tips section, engine related.
Legacy777 replied to biscuitb32's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it an auto or mt?
Fwd
Legacy777 replied to freakus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did an AWD & 5spd conversion on my legacy. To convert it to AWD, I had to swap over the hubs, struts, rear crossmember, add rear differential, add rear drive line, swap out the transmission to an AWD 5spd transmission, as well as swap transmission crossmembers. I've got a pretty detailed write-up with pictures, if you want to know more. www.surrealmirage.com/subaru/swap
Questions re: FWD only, Torque Bind
Legacy777 replied to DooMeSuuby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen's the last time you changed the tranny fluid? If you don't remember I'd suggest changing it. Worn tranny fluid can cause the binding as well.
Fwd
Legacy777 replied to freakus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure I follow what you'd like more info on. Can you try to explain a little bit more? Thanks
Legacy777 replied to Soobarooboo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can see some pics of the covers and other such stuff here http://www.main.experiencetherave.com:8080/subaru/images/timingbelt
Fwd
Legacy777 replied to freakus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe FWD cars are identical in terms of engine, reliability, etc. The only difference is the transmission, rear drivetrain, and suspension. My car was FWD for most of it's life....and I had about 178k miles on it before I swapped, so I'd say it's pretty reliable.
Feedback Score
Legacy777 replied to SevenSisters's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/showthread.php?t=31500&highlight=feedback+system
Legacy777 replied to Soobarooboo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure you're looking at the timing belt, and not the normal belts? The timing belt is hidden behind plastic covers. The pulley coming off isn't an uncommon thing...unfortunately. It's due to mechanics/people not torquing the pulley bolt correctly. It needs to be torqued to 110 ft/lbs at the least. I also apply locktite when I do mine. As for your problem. As long as the pulley did not damage the keyway of the crankshaft, you should be able to put a new key in, put the crank gear and timing belt back together, put a new pulley on, and be good to go.
Fwd
Legacy777 replied to freakus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you don't mind it doesn't have AWD, and it's in good shape, I'd say go for it if you need a new car.
Brake conversion
Legacy777 replied to Dangerdave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe FWD rear hubs are different then the AWD ones, so no they won't work. Sorry.
Dual exhaust on ej22?
I'm going to close this thread, so all your replies are kept in the thread you started in the new gen forum.
Legacy to Impreza brakes
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit'll work fine.
Dual exhaust a good idea?
Legacy777 replied to 300td4x4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt won't do anything for you.
does a 1991 legacy AWD have a thermal sensor?
Legacy777 replied to fgug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it does have an engine temperature sensor, that the ECU reads.
Part identification help..something to do with throttle
Legacy777 replied to Happyhighguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmind telling us what year and model car it is.....might help
Fuse for Front-Wheel Drive
The jist of it is you can wear out the duty c solenoid prematurely, and you won't really gain any fuel savings due to the fact you're still spinning the rear drivetrain.
