91 Legacy Driveability Problem
Legacy777 replied to Duckman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the CEL stay on, or is it off, and those were the codes that showed up? What I'd do is clear the codes, drive the car for a little bit, and see what codes come back. That will help narrow down what the culprit might be.
Legacy777 replied to Duckman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmight be the coolant temp sensor.
Speedo stopped working, stalls
Legacy777 replied to Clutchbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt depends if it's the speed sensor or if it's the gauge cluster. Usually the ECU will accept some margin of error when it comes to not receiving a speed sensor signal. However if it goes on too long, you will get a CEL. The AWD won't work either.
questions on 94 turbo
Legacy777 replied to whippet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo a compression test. Add a squirt of oil to the cylinders and then check again. If the pressure is the same, then more then likely it's the valve guides. As for it cutting out. Only thing I can think of is that your hitting fuel cut. Everything worked out good with the tranny swap. It's done and up and running. I've got a write-up for it, if you want to take a look. www.surrealmirage.com/subaru/swap
'92 dressed for success
Legacy777 replied to Qman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt has rear discs.
Legacy777 replied to Qman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLookin nice Ken.
Legacy777 replied to whippet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked compression ratio? How many miles are on the car? What's your gas mileage like?
Legacy777 replied to Clutchbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, probably the speed sensor.
AT change -- amount / bubbles
Legacy777 replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm....I wouldn't think engine speed signal would cause the issues you are seeing. I guess what I'd want to see is a wiring diagram, and make sure the engine speed signal is coming from that one wire from the ECU. I'd then verify that wire is good. It might be that the engine speed signal is just a bad code when it freaks out. Yeah I'd suggest checking the ECU codes, and see if anything correlates.
Replace OEM O2 Sensor with 3-wire?
Legacy777 replied to 99obw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought I had an email with the part #, but I can't find it. Email oxygensensors.com and just ask them. They should be able to help you out.
Legacy777 replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd reset the computers, and see if the codes come back. If they do, you're going to most likely need to replace them. The O2 sensor isn't super urgent to replace, but I'd do it at some time. The MAF sensor is probably what is causing the stalling. Check that wire and see if it's good. If it's not, you might want to replace it, reset the ECU, and then check to see if the MAF sensor is throwing a code.
Bands adjustable on '98 4EAT?
Legacy777 replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this link http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/transbrakebandadj.jpg If that don't work, try this https://www.mail.experiencetherave.com/subaru_manual_scans/FSM_Scans/transbrakebandadj.jpg https://www.mail.experiencetherave.com/subaru_manual_scans/Subaru_Service_Bulletins/1991/4EAT_FWD_and_4WD_Brake_Band_Adjustment_On_Car_Servicing.pdf
Free Fun
teague's sells maf adapters www.boxer4racing.com
Sensor location
Legacy777 replied to dale47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry again. I've been having issues with my server. I had a real close lightning hit the other week, and I think it might have fried my router. I spent last night reconfiguring the router, and trying to get my laptop NIC to work properly. I think I may have issues with my cable provider, but I'm not sure which issue is causing the intermittant issues.
Free Fun
In reality....there's really nothing you can do that won't adversely affect how the car runs. Remove the snorkel in the fender if you haven't. That's super cheap (free), and should make the car feel a little more peppy.
2003 Outback is also a PIECE of JUNK!!!
Legacy777 replied to rem14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can understand clutch issues....but what's up with needing two new pistons??
tranny shifting slow
Legacy777 replied to bugite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm pretty sure the 2-3 shift is controled by the brake band, so it may need to be adjusted.
Sensor location
Legacy777 replied to dale47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCam sensor is located on the driver's side, just behind the cam pulley http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/DCP_2699.JPG Crank sensor is located just below the alternator http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/DCP_2703.JPG More pics for your viewing pleasure http://www.main.experiencetherave.com:8080/subaru/images/timingbelt This should also help http://www.surrealmirage.com/subaru/files/swap/elect_unit_loc/6-3_electrical_unit_location10.jpg
check engine light on
Legacy777 replied to tdecker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm assuming you have a first gen legacy 90-94 with MT. I would probably ignore code 12. The hard starting symptoms are analogous to a bad temp sensor, which is code 21. They can be had for about 20 bucks or so at www.1stsubaru.com I'd start with that and see how things work.
1991 Legacy runs jerky on highway
Legacy777 replied to zwempa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBeing that your car is carburated and has a distributor, that brings a lot more things into play that could be causing it. Unfortunately, I'm not super familar with subaru engines that are carburated. I'd probably start with the fuel filter, maybe spray some carb cleaner in there. One of the jets might be plugged. You should probably check the distributer cap & rotor for wear, as well as check ignition timing. PCV = positive crankcase valve. I doubt this would cause your problem though.
Friends Subaru problem
Legacy777 replied to StockRaider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook at this scan http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AT_front_differential.jpg item 13 is the speedo drive gear.
Legacy777 replied to StockRaider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGotta be an axle. The speedo is driven off the differential gear. So if the speedo is working, that means the tranny is moving and working.
First Post - 2 Easy Questions?
Legacy777 replied to ggray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsteady blinking means no codes. Mine does what you describe occasionally with the idle. I chalk it up to the idle air control valve freakin out. It's not really a big deal...so I just live with it. Your other issue is regarding the tie rods. They are supposed to be able to pivot back and forth. As long as they don't have slop, they should be fine.
Legacy headers-anyone heard of them
Legacy777 replied to sixiron's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe 90-94 legacies had dual port heads. The 2.5 headers will work, however you will need to have a shop work up a custom pipe to fit how the angle of the header dumps into the intermidiate pipe where the cats are. Ultimately, you'd probably have to replace the section where the cats are.
WRX MAF on my RX?
I really doubt you'd be able to use a WRX MAF. Different MAF sensors have different levels of flow and a corresponding transfer function/lookup table in the ECU. Because of this, swapping MAF's isn't really something you can do.
